I have got a Samsung SP43W6HL Projection tv
Hi guys,
The problem I have is with the convergence setting on my tv.
The picture is still giving green,blue and red ghost images at the edges of the screen, and giving me a factory data settings message....
How can I either manually focus the image or Reset these 'factory data' settings please?
  • agrvassbnkst Aug 21, 2008
    convergence problem/
Shmoopy
  • 53 Answers
SOURCE: Akai PT4298HD Rear Projection
Perfect Focus and the convergence screen are for convergence, not actual focus. Real focusing is done in a combination of two ways: electrostatic and optical. And to do it right you need a good test pattern, like the convergence pattern from the Digital Video Essentials DVD. At a bare minimum turn your contrast down to half (don't use "dynamic" mode, ever).
This is going to sound scary, cuz it terrified me at first but now I'm comfortable with it:
To focus electrostatically, the front panel under the speakers needs to come off. As in actually unscrewing some screws and opening up your tv. Do all of this without cats or toddlers in the room. There are three circuit boards on which the picture tubes are mounted, and each board has a focusing knob next to the words "red," "green," and "blue." Do not touch ANYTHING other than these knobs. Twist the focus back and forth until it is as focused as it will get. The lines on the convergence pattern will get fatter or skinnier. If they get fat in one direction and skinny in the other, find the best compromise. Do not focus the blue too perfectly, as perfectly focused blue lessens the amount of blue relative to the other colors, making whites look yellowish.
Next you really need to clean your lenses, they are filthy from dust and that's why the focusing is so bad. For this tv, you'll want all three panels on the front to come off. That's about twenty screws, both on the sides of the tv and the undersides of the panels. The middle panel that covers the speakers can rest on the floor by the front panel, but the screen panel needs a resting place. An ottoman, or a chair with a towel on it, makes a good place to rest the screen (parallel to the floor).
Each CRT has a set of focusing lenses, and these can be removed. Do one at a time. They come off from four screws each. FOUR SCREWS. Do NOT unscrew anything else, as just under the lenses is a cover for the CRT. Take this off and you risk coolant leak, leading to expensive electrical problems. Do not, repeat, NOT touch either the lenses or the mirror with your fingers. One scratch is bad. Scuff marks can destroy a picture. These lenses and mirror are easily damaged.
http://www.keohi.com/keohihdtv/learnabout/generaltips/screenoptics.html
There are some cleaning techniques there. I'd only bother cleaning the top and bottom of the lens assembly. Don't mess with the wingnut on the side, we'll handle that later.
Now, with your CRT lenses back on (wingnut facing towards the mirror), replace all of the panels and rescrew the screws. Next we do optical focusing. Again, this is where test patterns from a test pattern DVD come in handy. Regardless of what TV a person owns, a DVD like Digital Video Essentials is, well, essential.
This time we're taking a panel off the *back* of the TV. Scary, huh? Specifically, the bottom one (there are two big back panels). About fifteen screws, four of which are the same ones you do to get the front bottom panel off. Get all of the screws off, pull it back, and lift it out. Don't touch any of the electrical stuff. From here, if you are careful, you can reach up under the mirror and untighten the wingnuts on each CRT lens assembly. If you are using a test pattern, use a standard definition one here, makes the scanlines easier to see.
Here's what I do to focus each gun:
1) Put on a full screen of green, red, or blue, depending on which gun I'm focusing. DVE has just these patterns.
2) Untighten the wingnut, and start making minute adjustments.
3) What you want to see is *scanlines*, as clearly as possible. Make a tiny adjustment, get back around to the front of the tv, and see how well you can make out scanlines. An all-green screen should actually be a bunch of horizontal lines of green. If you can't make out these lines, you aren't focused.
4) If you don't seem to be making progress at all, switch to DVE's convergence pattern to make sure you haven't completely lost focus on that color. You want to start from good focus, and then fine tune very delicately.
5) You may find it hard to get blue-focus perfect. That's okay, really, as blue is a filler color. Green was very hard for me to see lines on, but it was a step up from not being able to see them at all.
6) You may find it necessary to go back and forth between electrostatic focusing and optical focusing adjustments to get them right. That's okay.
7) When it seems you've done the best you can, you're done. Put the back panel back on and rescrew all of the screws.
Now you need to adjust your convergence. You can use the user convergence menu, but it will only get you halfway there, because it only controls like nine or twelve points. What you want is to access the *service* convergence menu. With the tv on, press mute-1-8-3 on your remote (not pressing them all down, just in that sequence). You should switch to a secret built-in convergence screen.
I hate to tell you this, but the only way to save settings made in the service convergence screen that I know of is with a Samsung remote, not the Akai one. This tv is actually a Samsung after all, and the Akai remote is missing some buttons that the Samsung remote has. You can buy them off partstore.com, among other places. Here are what the buttons do:
7-allows you to control red convergence
8-allows you to control green convergence (what the screen defaults to)
9-allows you to control blue convergence
+100-turns red on or off
0-turns green on or off
pre-ch-turns blue on or off
circular direction buttons-moves the cursor to a new convergence point
channel up/down-moves the convergence up or down
volume up/down-moves the convergence left or right
ONLY ON THE SAMSUNG REMOTE:
add/erase-saves settings after blinking the screen and centering the cursor
If you can find a button on the Akai remote that does that, you won't need to buy a Samsung remote.
BTW, you'll want to do this service convergence on each scan rate. So one for 480p (from a progressive scan DVD player), once for 480i (s-video source or non-progressive DVD player), and once for HD (I use my HD DVD copy of DVE).
Posted on Mar 19, 2008
Slinteriors
  • 8617 Answers
SOURCE: severe covergence distortion
I will need the model number of your set in order to help you. It sounds like a samsung with bad convergence ICs. But let me know the model number and I can help you with repairing the problem.
Posted on May 26, 2008
ladywinn
  • 5138 Answers
SOURCE: hitachi 61udx10b
Replace Both of your STK ICs they are your convergence ics they are big black ICs will have Part# on them for example STK392-110, if they are 110s use 180s, if 020s use 040s other wise replace with exact same number. To get Parts call Electronix 1-800-223-3205
Posted on Dec 30, 2008
  • 126 Answers
SOURCE: I have a Mitsubishi Rear Projection tv (vs-50705).
Well, you did the right first step. However, when the convergence outputs toast up they sometimes cause other problems. First would be the fuses that supply them voltage. These are pico fuses back in the power supply. Second would be open supply resistors that have opened up because of the excessive current draw caused by the whacked out convergence amps. When changing the outputs doesn't solve the problem it takes the repair out of the realm of the do-it-yourselfer. My recommendation is to let a professional take over.
Posted on Jun 06, 2009
welcomejee
  • 10594 Answers
SOURCE: double image, green and yellow ghosts, blurred
That means convergence out ICs are not working, requires replacement.
If you want to replace convergence out ICs, let me know to provide you technical info.
Thanks.
Posted on Aug 17, 2009
Hi guys I would like to know how old the SP43W6HL is? I have had mine for two years and would like to sell
Look in the back for manufacture date.But as i remenber these set are mostly produced in the years of 2001-2005 the high light of these tvs models.My best estamate as used and good conditon tv.Max price u could get for it about $800 max.
Jun 10, 2010 | Samsung SP43J6HD 43" Television
Samsung Projection TV - Yellow White Level and Auto Focus Failure
perfect focus is based on service mode convergence. FActory setting as it were. the set needs to converged in service mode then these values stored then it should work
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
Hi we have a model 51f500a and screen is really blurry called a tv guy he said we need a new flyback do you know how much these cost and where we can get the best price
hmm..not sure that is the proper solution...take a look at this 1st...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 14, 2010 | Hitachi 43FDX15B 43" Rear Projection...
I have wavy lines in the screen. I had a sears repair guy come out and they wanted to charge me $740 to replace the pcb. Is that what needs done and can I do it myself.. I have ran the convergence and...
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 27, 2009 | Toshiba 51H83 51" Rear Projection...
Rear projection tv screen warped
HI, this is typical convergence chip failure. you will need to replace the convergence board in this set asap. this will fix this issue you are experiencing.
May 23, 2009 | Samsung Televison & Video
Samsung HCL4715W
IF THE CONVERGENCE IS NOT ADJUSTING COMPLETELY THEN IT PROBABLY NEEDS NEW CONVERGENCE IC's . ALSO CHECK OUT THE SHARPNESS OF EACH PICTURE TUB (CRT) THESE SET ARE NOTORIOUS FOR HAVING BAD CRT''s (WHICH ARE NO LONGER AVAILABLE).
DON.
Nov 06, 2008 | Samsung HCL4715W 47" Rear Projection...
Distorted Picture
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Aug 02, 2008 | Toshiba 65HDX82 65" Rear Projection...
Samsung 52" tantus pch521r convergence panel
I found a this SITE that carries that convergence assembly for your TV.
Good Luck.
Mar 10, 2008 | Samsung PCH521R 52" Rear Projection...
Hitachi 42 hd projection tv
With out a model number to ref to just have to give this a stab. Sound like you are talking about a projection set that has convergance Ic failure, Hitachi put out a kit that has all the most common parts to repair you set, but there are about 4 kits and need a model number to get you the right one
Jan 12, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
HCM4216W Convergence Problem
the convergence problem you had before, re- occured
Sep 25, 2007 | Samsung HCM4216W 42" Rear Projection...
Televison & Video Logo
1,136 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
