Question about Broan-NuTone Broan Range Hood Accessory
Replace Broan Model K260A Range Hood Light Switch Slider Assembly
The light switch slider on the switch assembly (part B06105519) the controls the lights, blower on/off and blower speed broke and we can no longer turn the hood lights on/off.
We purchased another complete slider assembly from Broan (no electrical parts involved) and we're not sure how to install it into the hood. It seems like the old slider assembly should just pop out and we should be able to snap the new assembly in its place.
I really don't want to start taking the hood apart if I don't have to.
  • 15 more comments
  • Anonymous Mar 11, 2014
    Once installed and put into the slot i turn it on and it lights up fine, get to the desktop and then wham... keeps restarting and loading retarting and loading . im on xp with a 1.6ghz processor dont know why its doing it
    how do i take the airplane mode off my huawei cell phone
    hp probook 4430s
    left hand side etb socket is jammed in the closed position. with no belt installed .I removed the belt and cartridges and closed front panel to do cold reset, opened door and discovered the problem
    My galaxy s4 has hundreds of synced photos how do I remove
    just got van today and previous owner swears of "not knowing" . i only drove 20 km and van ran sweet but on way back home i noticed the van heat gauge went up when i turned headlights on
    My accord shows engine light and VSA indicator on dash. Computer diagnostic says code DTC P0010 VTC oil control solenoid malfunction. Can i use the car. How does one fix it?
    can just had labtop fixed by yahoo yesterday facebook keeps saying wrong password
    I plug in power cord and screen comes on with Hisense logo, then letters VGA in upper right hand corner, then No Signal makes a trip around the screen, then a little box says "No signal. The power will be turned off." Then the screen goes black and the whole thing starts over again - automatically.
    My Brother 8460n printer displays Machine Error when I switch it on.
    My casio edifice EF527D-1AV the crown keeps poping out from its normal position. The seconds hand will move but the hour hands do not. Does not tell time
    I need to know how change the date on my watch. I have trouble with the stem!
    have tried many times to get into my email account keep getting told that its the wrong password so i make a new one then they phone me with a new code i put that in then they tell me to go to my email account to retrieve the email to prove that i am the person to be on this computer they tell me to look in my junk mail of course it is not there as i think my account might be frozen by now please can u help me get this mess sorted out thanku
    HP 2420d printer slow on mac osx
    philips 47PFL5603D/27 SIDE PANEL DOSE NOT WORK & WAS SHUTTING OFF & TURNING BACK ON & remote does not work at 100%
  • Anonymous Mar 12, 2014
    my Broan L300KMG stops somewhere past half rotation of the switch. Want to control the fan through the full rotation of the switch. Also don't want the possibility of the switch on but the fan not turning.
  • Anonymous Mar 23, 2014
    i need to replace a fuse for the 2 lights on the right
  • 4,102 Answers
Hi if the new part has no screw holes or place for clip and it is only push in connector ie you dont need to solder the wires to it then it will just pull out use a small screw driver under the edge and gently pry free you cant damage it anymore than it is anyway can you.
Also on the side of the new switch if their is no groove cut into it for a push on clip to hold it in place then it will just pull out and push the new one in.
Posted on Jan 30, 2008
Best (Broan) K260A - I tried to change the bulb as well....completely inaccessible to change with hands (bulb is set deeper in hood, not even flush) tried gloves, rubber jar opener but cannot get access to...
The lamp holder assembly snaps into a hole in the range hood with spring clips. To remove the light bulbs, you simply push and turn, like older, bayonet style automotive turn signal bulbs. It seems you have broken your lamp holder assembly. Just break the trim ring so it can be removed, or you can try to take it out reverse polish style by releasing the spring clips from the middle inwards. Once the trim ring is loose, you can extract the body of the lamp holder through the hole... the wires will be barely long enough to stick out the hole if you are lucky. If you are crafty, you may fashion a repair on the separated lamp socket assembly. If not, your replacement part number is SV16569. just call nutone-broan at 800-558-1711 and they will be glad to ship you a new lamp shell socket trim assembly.
25439092-xipalmoknr3fbjmp51kycajc-3-0.jpg Retail on that part is around $50.
Feb 16, 2015 | Cars & Trucks
Light button blinking why
The fan light switch blinks when it is time to clean the filter. Clean the filter, then press and hold the switch for 3 seconds to reset it.
Jun 22, 2014 | Broan-NuTone Broan Elite E661...
How do nyou replace the key tumbler on a 1992 jeep cherokee
this is covered in the FSM. best is to ask a lock smith, (no kidding)
it is also cover at all 3 top online fsm sites (vitrual fsm)
and chiltions online.
the tumbler just dont fall out, it has protections from thieves (weak)
most cars, you must remove the key assembly
the pull the tumble pin, hidden and blocked by the mounted assembly.
those are generic words.
the steps can vary if car has steering wheel, vert adjustment option.
here is a non Air bag quote
Without Air Bag The ignition switch is located on the lower part of the steering column.
  1. Place the ignition in the LOCK position.
86748g34.gif Ignition/dimmer switch assembly
  1. Remove any components necessary to access the switch.
  2. Remove the two switch mounting screws.
  3. Disconnect the switch from the rod.
  4. Disconnect the wiring and remove the switch.
To install:
  1. On non-tilt columns:
    1. Move the ignition switch slider to the OFF unlocked position (move the slider all the way down, then back two clicks). The remote rod hole in the ignition switch slider should now be centered.
    2. Insert the remote rod in the ignition switch slider hole and install the ignition switch on the steering column. Tighten the attaching screws to 35 inch lbs. (4 Nm).
  2. On tilt columns:
    1. Insert the ignition key in the lock cylinder and turn the cylinder to the OFF unlocked position.
    2. Move the ignition switch downward to eliminate any slack and tighten the attaching screws to 35 inch lbs. (4 Nm).
  3. Install any components removed for switch access.
Dec 12, 2013 | 1992 Jeep Cherokee Limited
Exhaust fan and lights do not work
see this steps and fix it. God bless you
Switch If the range vent hood fan and light are not working the switch might be defective. Watch our video on switch testing and test this switch for continuity.
Selector Switch If the range vent hood fan and light are not working the selector switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rotary Switch If the range vent hood fan and light are not working the rotary switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rocker Switch If the range vent hood fan and light are not working the rocker switch might be defective. Watch our video on switch testing and test this switch for continuity.
Switch Kit If the range vent hood fan and light are not working the switch kit might be defective. Watch our video on switch testing and test this switch for continuity.
Micro Switch If the range vent hood fan and light are not working the micro switch might not have continuity. The best way to test the switch is with an Ohm meter. See our switch testing videos for help testing this micro switch.
Thermal Fuse If the range vent hood fan and light are not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Main Control Board If the range vent hood fan and light are not working the main control board may be defective.
User Control and Display Board If the range vent hood fan and light are not working the user control and display board may be defective. Check other causes before ordering this board.
Oct 02, 2012 | Dacor Millennia DHI602 Kitchen Hood
I have a Broan 2736 Eclipse downdraft blower system. When I push the button the downdraft rises but then immediately goes back down
Gail was spot on. That worked for me until the unit would go up and/or down on its own. The problem was traced to the double microswitch called the 'Lower Switch Bracket Assembly' ($24. thru Lowes ). To replace these switches is not for the faint of heart as it is deep within the assembly. A good weekend mechanic can look at the exploded parts diagram and see what / where. Found grease residue on- and slightly within- the microswitchs due to Broan not properly design shielding and protecting these critical switches from grease. Did not find any ghosts, however.
Nov 08, 2010 | Broan-NuTone 273603 Kitchen Hood
My Range Hood (Best by Broan K260A) is just two years old in a new house. WHen I use it, fat & grease drip down from the left and right edges against the wall. Can someone tell the problem?
grease accumulation, remove the fours screws on the lower plate, to remove excess grease. further you can unscrew the bolt that are holding the assembly and unplug the unit. after remove fans with allen key and remove motor , clean and reassemble , make shure to put motor the right back the same way. reassemble the same way , problem should be solve for at least 7 years depending on cooking.
Mar 15, 2010 | Broan-NuTone Broan Range Hood Accessory
WS3 Broan Allure Range Hood Premier 36 inch
Hi shealy,
I'm Harvey the Master Plumber.
Your problem is: This hood worked fine until a light bulb blew out. Put in a new light bulb, but the lights will not turn off. Is the light switch bad or is there a problem with the control panel? The fan still works fine but the lights will not turn off or adjust dim or bright.
You're on the right track. The light control switch needs replacing. You might try utilizing the Repair Directory to find a repairman. If you have the tools and ability just remember to turn off the electric first.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Sep 08, 2008 | Broan-NuTone WS330 Kitchen Hood
Its forsure 100% guaranteed to be the control board. Its located right behind where you push the buttons. You must remove the sticker (button pad) to access the three screws retaining the control board to remove it. The new control assembly comes with a new stickers.
Part # R111632
Price: $110.00
p.s i do service calls for Broan-Nutone
Jul 25, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Broan allure II range hood
Did you ever find out what blew the fuse originally? Do the lights have a dimmer feature on them? If so, the reostsat may be bad, or the switch that controls the light intensity, 1,2,3. ect. Something caused the fuse to blow, maybe a wire on the bulb or switch somewhere.
Dec 20, 2007 | Broan-NuTone Broan Range Hood Accessory
Random fan speeds and light levels???
I have the same issue. Have to reset the breaker to make it stop. Bet it is a bad controller (design fault).
Nov 13, 2007 | Broan-NuTone Allure III QS330SS Kitchen...
Broan-NuTone Broan Range Hood Accessory Logo
1,595 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
