Question about Matsonic 8328E (MS8328E) Motherboard
Front Panel wireing Dia for 8328E required
Hi, has anyone a manual for this mobo., I am haveing problems wireing the front panel, The pins are not marked..HELP..
    Problem Solver:
  • 7 Answers
1 VCC 2 VCC
3 USB0 4 USB1
5 USB0+ 6 USB1+
7 GND 8 GND
9 Key(no pin) 10 USBOC
Posted on Jan 30, 2008
Front Panel Audio Pin Connections
http://www.driverscape.com/manufacturers/matsonic/laptops-desktops/ms8328e/74851
Aug 06, 2013 | Matsonic 8328E (MS8328E) Motherboard
Question I am not sure I know how or who to ask. I am 75 yrs old, very hard of hearing, and am building my third computer. The first two went easily and great. I really am not concerned with having the...
http://downloadmirror.intel.com/15210/eng/D845GVSR_TechProdSpec.pdf
That is a link to the manual of the board...page 56 tells you which pin is which.....now for your case?? Well I have ran into that quite frequently.....and basically you will need to know where the wires are going to the front panel....I have had times where they were not even labeled at all and had to remove the front just to see where each wire went on the front
Aug 06, 2011 | Intel D845GVSR Motherboard
Hi, im trying to connect motherboard intel D865GVHZ front panel to connection J9H3, i need a diagram for it. Thank you for your help
I may be confused with your problem you posted mar13974.
I thought Jumper J9H3 was for the Front Chassis Fan.
By your post, it leads me to believe you want the pin assignments for the Front Panel header on the mobo.
At any rate let's go to Intel Product Support, and the download page for the motherboard manual, for the Intel D865GVHZ desktop mobo,
(MOtherBOard),
http://www.intel.com/support/motherboards/desktop/d865gvhz/sb/CS-010872.htm
Click on the blue file name - D865GVHZ_ProductGuide01_English.pdf
After you click you may not see anything happening for up to 30 seconds. The file is downloading in the background.
(Took 16 seconds for me just now with a medium speed DSL connection)
Page 33 shows the location of the Front Panel header on the motherboard.
(C)
Page 34 details the pin assignments
Page 36 shows the Front Chassis Fan header location (Chassis front fan)
3-pin header, doesn't state the pin assignments.
With a 3-wire fan cable,
A) 1 wire is the Power wire. Generally Red
B) 1 wire is the Ground wire. Generally Black
C) 1 wire is the speed sensor wire. Reads how fast the fan is spinning in Revolutions Per Minute
(RPM) Generally Blue, but it's up to the individual manufacturer.
If the above isn't what you had in mind, please state in a Comment.
Regards,
joecoolvette
Oct 17, 2010 | Computers & Internet
I can't find where the connections of the front panel are on the motherboard or where they go?
The eMachines T2893 desktop computer uses an Inte G845GVSR mobo. (MOtherBOard)
Intel Support>D845GVSR>Motherboard Manual,
(Intel's name - Product Guide),
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008823.htm
I would like you to left-click on the top file.
Click right on - Product Guide - PDF, in blue.
(File name underneath it is -
File Name: D845GVSR_Product Guide_English.pdf )
May take up to 30 seconds, before you see the first page.
(You will be staring at a blank screen until the first page comes up. The file is downloading in the background)
Took 5 seconds before I saw the first page, and an additional 12 to fully download, using a medium speed DSL connection.
The Front Panel header on the mobo is shown on Page 31. (C on the illustration. J9G1 on the mobo)
The Front Panel connections are on Page 32.
Barring that you cannot download this PDF file, or do not understand the manual, I will detail the Front Panel header connections.
Orienting the motherboard so we are both looking at it the same way;
The Processor is at the top, the ram memory slots are to the right side of the mobo, and the white PCI slots are to the bottom.
There are three PCI slots. The one closest to the Processor is PCI 1.
The one closest to the edge of the mobo is PCI 3.
To the far right of PCI 3 is the Front Panel header.
It's the header located closest to the Right side of the mobo, and the bottom edge, and is directly below the
CMOS battery.
There are two rows of pins.
Four across the top, Five across the bottom.
The top row of pins are numbered Evenly.
The bottom row of pins are numbered Odd.
Starting from the Left side of the mobo, going to the right, on the Top row,
Pins 2, 4, 6, and 8. (There is No 10)
Starting from the Left side of the mobo, going to the right, on the Bottom row,
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the Harddrive Activity LED
If you have a wire with a + sign on it (Positive) it goes to Pin 1.
B) Pins 2 and 4 are for the Power On LED.
(Pin 2 to the Green LED lamp, Pin 4 to the Yellow LED lamp, if applicable with your computer)
C) Pins 5 and 7 are for a Reset switch. (If applicable)
(Pin 5 is Ground)
D) Pins 6 and 8 are for the Power On switch.
(Pin 8 is Ground)
E) Pin 9 is for the +5 Volt power.
(You are following Anti-Static precautions, right?)
Have any questions just post in a Comment.
(Believe upper right of your page)
Jun 13, 2010 | E-Machines T2893 PC Desktop
Asus P5LP LE Emery motherboard MANUAL
does your case have set pin slot sets your case manual should tell how to install your motherboard type hope this helps
Jan 04, 2010 | ASUS Computers & Internet
E210882 socket type 775, PCIe, DDR2 - Will not turn on
On the Dell board, the
CORRECT pinout for J8H1 is as follows:
1-3: HD LED (#1 is +)
2-4: PWR LED (#2 is +)
5-7: PWR ON/OFF
6-8: RESET
5,16: +5V
10,11,14,15: not connected
12,13: GND
Regards.
Jul 27, 2009 | Dell (E210882) Motherboard
Foxconn LS36 mobo , front panel (34pin) connection DETAILS needed
Dell has never published the pin-outs of their proprietary ribbon connectors to the front panel
Jun 03, 2009 | Dell OptiPlex GX270 PC Desktop
D102GGC2 will not do anything!
Hi there. Have you tried running the system as a barebone?
What I mean by this:
Disconnect everything from the mobo, all memory sticks, cables, wires, and any PCI/AGP cards you may have.
If you have more than 1 memeory stick, only put 1 back in. Connect the power switch to the mobo.
Now connect the power supply to the board.
Connect the monitor to the On Board VGA port.
Now turn it on. Let me know what, (if anything), happens.
Tim
Apr 25, 2009 | Intel D102GGC2 Motherboard
Where to hookup front panel (PIII-3754LMR - AMPTRON)
Front Panel Connector The front panel header is where the connectors of hard disk drive activity lights, case speaker, reset button, power on/off button, computer power on light, and key lock, are connected to make them function smoothly. In the past days, users always have difficulty connecting the front panel due to a lack of standard location on the motherboard. Today, AOpen integrated all these disorder but essential front panel connectors into one 20-pin connector for easy usage. Connecting the front panel would no longer be the headache of installing motherboard anymore. Below is a view of this user-friendly front panel connector of AOpen motherboard.
please rate this post.
or donate on madridtelecom@gmail.com
Feb 08, 2009 | Intel Motherboard
Front panel audio connection to asus pk5 se mobo
Hi Tracybow,
The Front Panel Audio connection should have a couple of wires to plug in into your MotherBoard. Usually, the connectors are named and all you need to know is the exact location in your MotherBoard.
I would suggest you to visit your MotherBoard manufacturer and download the manual for your MoBo. You will find in the manual a diagram of the MotherBoard which shows the location for those wires.
Hope this helps.
Best regards
Eduardo
Oct 03, 2008 | Computers & Internet
Matsonic 8328E (MS8328E) Motherboard Logo
157 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Computer Links
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
