Ovens Logo
Posted on Dec 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Automatic self cleaning turnoff
When using the self-cleaning feature, does the oven just go off automatically or do you have to turn it off?
Tom Zwiebel
Level 2:
  • Expert 318 Answers
  • Posted on Dec 31, 2009
Tom Zwiebel
Expert
Level 2:
Answers
318
Questions
Helped
157206
Points
933
Most newer ovens have to be programmed for how long the unit should clean for. usually need 3 hours to get hot enough to clean the spills. after that it needs another 45 minutes or so to cool down to allow the door to unlock and let you open it.
1helpful
How do I set the automatic clean on a Siemens Pyrolytic Oven SS that was bought in Australia 5.5 years ago? Oven code is HB76AU560A. Thank you.
i've never worked on your brand name stove but i want to tell you don't self clean it until after the holidays,when you self clean an oven it gets up to 1000 degrees,the heat can damage the electronics in the oven,if it does and you need a part ordered you won't have an oven to cook with for the holidays,after what i've seen i will never self clean my oven again with the self clean feature i use easy off just as good.hope this helps you out and merry christmas
What does code EL F1 mean
My best guest with info you provided is the door lock engaged and the door lock did not lock the door if it has an automatic door lock you can try unplugging it and seeing if the door lock motor will reset or see if there is a lever to lock the door that is manual and make sure the door is locked before cleaning. Most ovens have it in a automatic feature because of the high temp the oven goes to when it self cleans. Best bet is find the model and make and look up the code
May 18, 2016 • Ovens
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
[PDF]USE & INSTALLATION MANUAL - Smeg
www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
Jan 10, 2016 • Ovens
I used the self cleaning feature. It was tricky slide the unlock over. I got it, now can't open the door.
The Door should automatically unlock once the oven Cools down enough to Finish wiping oven out to finish cleaning.
Nov 11, 2010 • Ovens
How do you use the self cleaning opiton
take the racks out,hit the clean button, then the start button, you may have a manual lock lever right above the door, some are automatic, but the door must be locked for the clean feature to work
3helpful
The self cleaning instructions for my Frigidaire Gallery Pro Series Model FEB798WCCH do not inform how long to set timer. Any instructions would be helpful as I've never operated a self cleaning oven...
Hello- The function is automatic when clean button is pushed. Oven will lock, and turn on at full power for about 90 mins. This 'feature' can, and usually does eventually burn out circuits in the control board. Techs call this the 'self-destruct' option, cheerfully promoted by the salesman. Avoid using 'self clean'!  Scrape and clean with light soap/water. Turn on to 450deg. for about 30 min. This is about half the temp. of a 900deg. 'clean' cycle and a lot less expensive in the long run. Please acknowledge this post if info is helpful- have more if needed.- Thanks- Ed
When baking my oven door is not locked is it supposed to be?and if so how do we lock it.
The locking of the oven door is a safety feature used only during automatic self cleaning cycle, this is because temperatures during the self clean cycle can reach upwards of 600+ degrees creating a dangerous situation if the door was opened, it will remain locked after the self cleaning cycle is complete until the oven interior temperature is below 100 degrees. So no the door is not normally locked during the bake cycle. Good luck !
1helpful
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 • Ovens
1helpful
Linking F3 when trying to turn on the oven
While using the self clean feature you burned out the oven temp sensor.
Replace the oven temp sensor.
Do not use self clean on any oven unless you want to replace parts,
VDSC307-4bss how to operate self-cleaning oven
I continued a search and found a manual on line... simple process to turn on self-cleaning operation... close the door and set to "clean" ... timer on this model is automatic... runs for 3 1/2 hours.. fan continues for an additional 30 minutes ... open the door and the oven is clean. Thanks
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
