Question about Lexmark T630 Laser Printer
Selecting a default paper source for a specific program
I need to set a default paper souce for use by our Sage MMS program as tray 2 (so that we can print invoices exclusively from this tray). However, other packages need to default to using tray 1 - so that we don't get "ordinary" data typed on top of invoice paper.
How do I do it - every time I try and set Tray 2 as the default source via "Printers and Faxes" I get the message "There are one or more conflicting settings. One of the conflicting settings is Paper Source: Tray 2 Tray 2 not installed".
Any ideas would be gratefully received!
  • Anonymous Mar 22, 2014
    How do I set the default paper tray?
  • 167 Answers
That what you want is not TRAY 2 it is Manual feed!! That is need to select to be default or you can empty Tray1 and feed Tray2 and select feed automatic! This both solution will work you choose witch appropriate to you!!!
good luck
Posted on Jan 30, 2008
6ya staff
SOURCE:
How do I change the default on my HP P30005dn to Tray 2?
Normal default on HP is tray 2, however if you do not have that tray set for plain paper letter size the printer will default to whichever tray has letter plain paper installed. You should also check your print driver default settings to ensure that tray 2 is set as default tray.
Aug 14, 2014 | HP LaserJet P3005dn Printer
4200 PRINTER Only wants to print out of tray 1
First you need to verify that tray 2 will print from diagnostics test. Use the arrow keys to scroll down to diagnostics and press arrow key, then use arrows move to paper path test and press arrow again. The default paper path test is tray 2 single copy so just select print paper path test and see what happens. If printer prints from tray 2 then we know tray 2 works and that means you either have a print driver that is forcing printing from tray 1 or your settings on the printer for tray 2 are not correct for what you are printing. Check to make sure the paper size shows correctly and make sure that the switch on the right side of the paper tray towards the back is set for standard and not custom.
Aug 04, 2014 | HP LaserJet 4200 Printer
I am using Sage to print invoices, i installed a dot matrix printer to do this. The model is Panasonic KX-P2023. The problem is when i print an invoice, the invoice for some reason keeps printing the...
you need to change the paper size or font size in the software that creates the printout. if you can, do a print preview before you print to see if its going to try and print to one page
Mar 16, 2011 | Office Equipment & Supplies
My HP 2420 is taking so long to print a document. Seems like it pauses between each page rather than printing at it's normal rate. Any suggestion?
This could be a problem with the memory in your computer too many programs running at once. Go to start then click run in the box type msconfig this will open a system configuration box click on startup and uncheck programs you don't need running DON'T STOP the firewall or virus checker. Most programs don't have to run they will start when you click on them. after unchecking the ones you don't need running click apply and press OK your computer will have to be restarted and when it starts back up put a check mark where it says dont show me this message again. You could try more memory and always clean out unwanted trash and old files the link is below.
http://www.ccleaner.com/
Aug 14, 2009 | HP LaserJet 2420 Printer
Printer picking wrong tray for print
From the start menue to printers and faxes go to your printer right click and select properties label the 4 drawers as to paper type and select continue, or auto continue to off.
-Carl, please let me know if this helps.
Jun 26, 2009 | Xerox Phaser 8560MFP Laser Printer
Keeps reseting to Tray 1
Printer Defaults button? what magical land is that found in?
Here is the real solution:
In Printers and Faxes, right-click the printer
Click Printing Preferences
In Paper Source drop down, select Tray 2.
Peace!!
d(-_-)b
May 14, 2009 | HP Office Equipment & Supplies
How do I stop daily reports from printing? How do I change the default tray for fax reports?
To program a default paper tray to print fax reports, perform the following:
1. Select Utility/Counter.
2. Select User Setting.
3. Select System Setting
4. Select Paper Tray Setting.
5. Select Print Lists
6. Select the paper tray for the fax reports to print from.
7. Press OK.
8. Press Exit on the lower left side of the display to return to the copier screen.
to set the activity report to not print daily
1 touch the utility button
2 touch administrator settings and enter the password 12345678
3 press fax setting
4 press report settings
5 select activity report and change to off
6 press close then exit
Mar 17, 2009 | Konica Minolta bizhub C250 All-In-One...
Paper tray?
Two possible solutions;
1) Check the settings in the printer driver for the default tray. The other user could very well have changed them and set tray 1 as the default tray.
2) Check the paper size settings in the paper tray. Pull tray 2 out and check the paper guides. Make sure the paper guide in the front and left of the paper tray are set for the correct media type (letter, legal, etc.)
The printer reads the tabs in the back of the papertray to identify the paper size. If someone moved it while loading paper the printer identifies another paper size and defaults into the tray that has the size of paper required to print.
Hope this solves your problem.
Nov 19, 2008 | HP LaserJet 4100n Printer
A3 size does not feed automatically from tray on HP5550
Try this::: The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
NOTE: If the issue is resolved and it is necessary to print on another type of paper, load the new paper type into the product and then repeat steps 2 through 7 for the new paper.These changes do not change the default print settings. The print settings return to the default the next time the program is opened. Let me know if it helps or I can research it some more.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 13, 2008 | HP DeskJet 5550 InkJet Printer
Won't print to right tray
I had this problem and solved it like this:
  1. Right click on printer driver in printers and faxes.
  2. Select printing preferences
  3. Choose paper quality tab
  4. Set paper size (A4 in my case)
  5. Set paper source to printer-auto-select. This is different from the default "Automatically select"
As long as tray 1 is empty, tray 2 should now kick in. Setting the paper source as tray 2 didn't work at all.
You seem to have to set this on each client computer though - even if you are sharing the printer over a network (4200n).
Sep 23, 2008 | HP LaserJet 4200 Printer
Lexmark T630 Laser Printer Logo
1,007 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
