Question about Texas Instruments TI-83 Plus Calculator
TI 83 I had a bad accident, broke my back and could not use my TI 83 for over a year. When I tried to use it, it did not work. Replaced all the batteries, still did not work. Called TI but they said hard luck out of warranty. As it was very expensive and I need it for exams, what could be wrong with it? Is it repairable? I have calculators (non-graphical) much older than this that still work well. I am in the UK. Terry email: [email protected]
  • 105 Answers
Try Adjusting contrast:
Hold down "[2nd]" key press up or down arrow repeatedly to lighten or darken contrast.
First attempt reseting:
Step 1: Remove all the batteries
Step 2: Hold "Clear" key down
Step 3: Still holding "Clear" key reinstall batteries
Step 4: Still holding "Clear" key press "On" key until home screen is displayed.
Second shot reseting:
remove all batteries including lithium ion (backup battery), wait 3 hours and reinstall batteries.
Third Shot reseting:
Step 1: Remove a battery
Step 2: Hold down "DEL" key reinstall battery
Step 3: Possible msg pops up saying "Waiting ... Please install software" IGNORE msg and take out battery again
Step 4: Reinstall battery do not hold down "DEL" key
reseting will cause the handheld to loose all of its stored memory.
Other than that you will probably need to buy a new calculator
Hope that helps!
Posted on Jan 30, 2008
Solution 3 worked for me, thanks
my problem was that when i turned my calculator on, only a horizontal line would appear no matter what buttons i pressed
Posted on Mar 03, 2008
Wow I didn't think it would help,but after trying the 3rd choice, it worked for me, thanks alot!
Posted on Feb 29, 2008
6ya staff
SOURCE:
My TI-83 PLUS wont turn on
Remove one battery from the calculator and then press and hold down the CLEAR key while re-installing the battery. While continuing to hold down the CLEAR key, press and hold down the ON key. If this doesn't work, then hold DEL and then ON. If unsuccessful, remove all the batteries, including the lithium watch battery, and leave the calculator like that for a while.
This is documented in the TI-83 Plus Guidebook, but unfortunately, not many people know about it.
If that doesn't work, send it to TI for repair. They probably won't even charge you!
Mar 20, 2017 | Texas Instruments TI-83 Plus Calculator
New batteries and won't turn on
You might want to check the batteries, and make sure that they're in the correct way. If they are, then you either purchased bad batteries, or your 83 suffered a catastrophic failure/broke
Aug 19, 2011 | Texas Instruments TI-83 Plus Calculator
My ti-83 plus is only 2 years old max. i tried turning it on one day in class and it didnt work. i've replaced the AAA batteries twice and the back up battery and i've had no luck. i tried changing the...
Try resetting the calculator. Remove all four AAA batteries. Press and hold the ON key for ten seconds. Replace the batteries and turn the calculator on. You may have to adjust the screen contrast again.
Mar 14, 2011 | Computers & Internet
TI 83 plus calculator has dim screen.
TI calculators have an annoying habit of dimming the screen when the batteries are changed. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Jul 19, 2010 | Texas Instruments TI-83 Plus Calculator
I just replaced the batteries in my TI 83 Plus and
Hello Lady Godiva,
You may try to visit the Texas Instruments FAQ and Knowledge Base to read the article that addresses your question. The article has links to additional troubleshooting.
Hope it helps.
P.S. You may not know it but the name given to a model of a bare nuclear reactor happens to be Godiva, in honnor of the historical Lady Godiva., the wife of a less famous German Burgmeister.
Nov 02, 2009 | Texas Instruments TI-83 Plus Calculator
TI-83 screen is black
The "color" on your screen reset to dark. You can adjust it by pressing "2nd" and the "up" arrow (or "2nd" and "down" arrow) repeatedly.
Aug 29, 2009 | Texas Instruments TI-83 Plus Calculator
TI 83 Plus won't turn on after battery change
I was having the same problem...I found the info below on another blog and it helped me fix my calculator problem. Take out all the batteries, hold the DEL button and put the batteries back in (keep holding the DEL button until all batteries are put back in). This will restart the calculator and restore it to its default settings...but it makes it work again!
"Reflashing the OS is probably the thing to do now. I think there's some trick that throws the calc into OS receiving mode. Hold down DEL while putting the batteries in? I don't remember if that's it. Go to 1-800-TI-CARES/[email protected] if you need specifics on getting the calc to take an OS upload given the state it's in."
Feb 24, 2009 | Texas Instruments TI-83 Plus Calculator
TI-83 PLUS
Most likely your battery is dying.
You can replace by removing 6 screws at back of calculator, but cost of battery is around 40% of buying new TI-30XA from Amazon, Staples or elsewhere.
I've used TI-30XA's for years, batteries usually last 2-3 years, then I buy new calculator. The one time I tried to replace battery, fading display still problem, so circuit board had gone bad.
So you could try battery replace and may be OK, but also may be waste of time and $$
Nov 06, 2008 | Texas Instruments TI-30XA Calculator
My ti-83 plus has OS problem
That happened to me a few years ago - my friend tried to give me his operating system, and my calculator was all locked up like that for a while. There's some kind of reset code - pressing some buttons while putting a battery in - but it's been a while, so I don't remember which buttons.
Apr 15, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
184 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Ekse
Gene Pitts
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
