Question about Honeywell 2-way Oscillating Ceramic Heater
Honeywell programmer gone dead
My honeywell programmer went bonkers yesterday - the time on the clock and the settings were completely wrong. Then this morning it is totally blank.
There is a sign on the junction  box above about batteries.  Does the programmer contain a battery and could it need replacing? If so, how do I get the programmer apart to do this?
Or is it some other problem?
thanks for your help Elisabeth
    Top Expert:
  • Honeywell Master
  • 12,744 Answers
Lift the face plate off and change the batteries
Posted on Jul 07, 2017
SOURCE: Honeywell RTH230B
This my situation exactly.  Changing from a 6 wire manual round Honeywell thermostat to a 5 wire Honeywell programable.  Is there a way to maintain all functions?
Posted on Nov 25, 2008
SOURCE: rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Posted on Dec 29, 2008
  • 3433 Answers
SOURCE: unlock Honeywell TB7220U1004 Ultrastat Commercial
Pull off face and remove batteries and reinsert.
Posted on Jun 01, 2009
SOURCE: how do i remove my st699 honeywell programmer from
Because there are no apparent screws to remove the front of this unit it can be very confusing if you have not done it before. Underneath and to the right hand side you will find a small notch in the plastic, it can be difficult to see when the unit is on the wall, using a small terminal screwdriver push upwards on the plastic tab which locks the front in place and with a slightly larger flat bladed screwdriver prise the front off bottom first then the two locking tabs at the top.
You will probably find that the back case is fastened to the wall with two screws.
Replacement is simply a matter of snapping the front back into the case.
Posted on Sep 22, 2009
SOURCE: Even after replacing the battery, the programmable
Turn control to off. Remove the batteries for at least one hour. If the display message still reads "bat lo", leave control off, batteries out, and disconnect the red wire on back and wait another hour. Reconnect red wire, put new batteries in and turn system on. It's like a reboot.
Posted on Apr 13, 2010
I can't set my time zone on my Honeywell Automatic Clock
Please see this answer:
Mar 06, 2012 | Honeywell RC182WR Atomic Alarm Clock - Red
Why is the clock losing time on my THR860SUK programmer, loses approx 2-3 mins per month.
This is Honeywell digital thermostat.
Warranty is 1 year for workmanship
call Honeywell Customer Care at 0845 604 2893.
Settings are saved with back-up feature, so external power outage or intermittent short should not affect internal time clock. That says the internal electronics are causing issue.
Instruction manual does not have troubleshoot section:
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | Honeywell Water Heaters
Hi I have a Honeywell st699 programmer for central heating and hot water. The only problem that we have is that we can not change the time on the clock. This means that we cannot set any programmes. Is it...
Go to
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Aug 17, 2010 | Honeywell Programmable Thermostat Heater
I have a very old manual Chronotherm thermostat.
No. The clock is just the set back timer. Pull the battery and use the stat manually.
Jan 26, 2010 | Honeywell Electronic Programmable...
EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Oct 01, 2009 | Honeywell Electronic Programmable...
My daughters honeywell ch/hw digital control resets to zero
have the batteries died have you got the programmer set back to timer control or is it still in the set mode
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Heater on when not programmed
sounds like a bad t-stat , they have a 5 year warranty on them
Dec 28, 2008 | Honeywell Programmable Thermostat Heater
Can't Program Clock for Honeywell RTH230B Thermostat
After you set the hr, min, and day, press the mode button.
Oct 05, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
77 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
