Question about Acer TravelMate 2300 Notebook
How to reset bios password
My syster forget her bios password for the futjisu siemens amilo pro v3504.
How can I reset the bios password for this laptop ?
Thanks in advance.
  • 9 more comments
  • smb2665 Feb 01, 2008
    I try the bios password and remove the battery. It didn't work. Please if someone have another solution to reset the pasword of fujitsu siemens amilo v 3504, I would really appreciate your help.
    Thanx.
  • Anonymous Apr 19, 2008
    < z
  • m32642k Jul 08, 2008
    I forget bios password
  • Anonymous Jul 28, 2008
    I need to reset bios password
  • Anonymous Jul 29, 2008
    i forget my bios password on acer aspire 5315
  • amro1969 Aug 02, 2008
    when i startup my laptop Toshiba A135-S2386 i have problem it needs bios password what can i do
    please me the result at amjad.albahou@gmail.com
  • Baku69 Aug 23, 2008
    I need to reset password on my Acer Extensa 367D.
  • udopcr Sep 04, 2008
    everex stepnote - remove large cover on bottom, remove cmos battery, set all switches on sw1 to off, power up, power down, reset switches, replace battery
  • Anonymous Sep 29, 2008
    acer travelmate 4720
  • Anonymous Oct 14, 2008
    i lost my acer travelmate 2420 bios password. please help me.
  • Anonymous Nov 21, 2008
    I have a Fujitsu c series Laptop with the same problem
Underneath the button cover (plastic cover over power button etc) there is sw1 4 switches ,
put them all to on the power laptop then off again put switches back to what they were then on again
and presto bios password is no more
Posted on Sep 30, 2008
    Novelist:
  • 60 Answers
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on May 06, 2010
I have the intel board & i forget the password plz suggest me how i remove the password
Posted on Jul 19, 2008
I have Fujitsu Siemens Laptop ,
modle amilo pro v-3515,
i need his audio drive ,
pls help me,
my id is pankaj.bagga1984@gmail.com
Posted on Oct 28, 2008
    Genius:
  • 1,601 Answers
Try this site it will show the default passwords for your laptop.
http://www.tech-faq.com/reset-bios-password.shtml
You can also try and remove the BIOS battery.
If these do not work, let me know and I will look up and see if there is a BIOS jumper to reset.
Posted on Jan 30, 2008
2 Suggested Answers
SOURCE:
  • 25 Answers
SOURCE: How to reset bios password
open the laptop and disconnect the cmos battery.wait for a minute then then replace back the battery.then post screans messages will appear.follow screen instructions.u
Posted on Aug 30, 2008
HOW I CAN KNOW LAPTOP MASTER PASSWORD
You need to temporarily remote the CMOS battery from the motherboard to reset the bootup password.
Nov 30, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
The FSC 1320D's are truely remarkable... We haev had a default BIOS password for our laptops for a while now, but it has recently started to have been guessed or found out. So of course, they needed to be changed. And suprisingly enough, the FSC 1320D will not allow you to reset the BIOS password through ANY user method so far, and we really have tried everything.
Removing the BIOS battery - This does nothing, at the best of times the system will display an error saying it has been removed but other than that the BIOS password remains.
Updating the BIOS - Most people would suspect that if you update the BIOS it compeltely refreshes the set system settings, including the BIOS password. This again, is not the case with this model, as every attempt at updating the BIOS so far has been deemed useless.
BIOS Corruption - This again, does not work. It leaves the system in a dead state, usually the BIOS resets. This has occured once, as during boot we noticed the options to scan memory had changed and it took longer, but the BIOS password remained.
Backdoor Passwords - Again, do not work. We have tried the entire list submitted by Ekse.
Reset VIA Software - There are some hacking programs out there which reset the BIOS through the Operating System. And i think we can all guess what im about to say... They don't work. It may just be for this model, as i've not tried them on others, but the BIOS password for the FSC 1320D does not get reset using this applications.
So, the verdict?
Apparently you can submit your laptop back to Fujitsu Siemens for an 'Out of warranty repair', and they will reset it for you. Assumingly by changing the BIOS chip completely. The only downside to this is that it can cost anything from £50 - £150 depending on service charges and delivery costs. My opinion, wasting time on a laptop that is past its sell-by date like the FSC 1320D is really not something you want to be doing. Buy a new laptop and sell the 1320D for spare parts.
May 07, 2008 | Fujitsu LifeBook C1320D Notebook
I craet password for bios for laptop type Fujitsu
u have to rerset your biossettings.
for that u have to open back side of aptop u see there 1 cms cell on motherbord .put away it for 15 mnutes from the motherbord.
thwen it reset .then refix cmos cel then it not need any passsword.
Mar 04, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Aug 30, 2008 | Acer Aspire 5100 Notebook
Bios
for that u hav to open ur laptop and look out a battery(Big button cell) take it out for abt 5 secs and then put it back restart ur system there u go password is reset.
Jun 19, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Bios master Problem
For a Siemens your master reset is [SKY_FOX] without the brackets.
Here is a link to all of them. Scroll down until you see the list for all BIOS makers.
Regards,
Worldvet
Jun 07, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
I've forgot bios master pass
reset ur bios buy pulling the battery under the keyboard out.. for a min or two ... that will without touching any jumpers reset ur bios ...
Nov 03, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Password
I found a website
that said
SKY_FOX
is the fujitsu password
Oct 28, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Computers & Internet Logo
6,696 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
