I havent used my ag-w1 in a while and now will eat the tape, not badly, just eject and manually respool. also last time i used it simply as a converter by hooking 2 minidv walkmans each to the in and out to transfer from pal to ntsc and it worked but the image was less than pro quality to say the least. Is this old but expensive investment just done or is there something i can do or have done?
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
Let me know if you need more information as to where to purchase these parts.
Canon NTSC ZR25 MC Digital video camcorder is eating the tape. I've loaded a new tape and get an "eject tape" message each time. Does anyone know how to fix this issue?
Your VCR is "eating" tapes, this is a common problem. First, wind the tape up by sticking a penny or other rounded object into the white "gears" on the back of the tape (with the tape hatch open by holding down the small button on the left side of the tape) and turn either clockwise or counterclockwise. Then check inside the VCR for moisture and remove any and all moisture with a clean rag. Moisture can cause the tape to stick to the VCR's internal components.
Hunnn....Eats the tapes, with salt & paper?..just a joke!
The tape runs on a guide ( sort of a tiny ledge )when it is fully engaged. The tape cartgage is loaded ' sucked ' in with gears that drop the cartage on top of other switches to give direction, so that "fingers" pull the tape towards the reading\recording heads. When the tape IS aligned properly, BUT is locked in the proper position the tape will NOT touch the upper or lower "ledge" that keeps it accross the heads.When the tape is NOT aligned the upper or lower tape WILL touch causeing damage. OPEN THE CARTGAGE ,Look to see if the upper & lower of the tape is damaged. Now when you say "eats the vhs tape" Does the tape comes out WRINKLE, CRINKLED,CRAMPED UP??? Then that could be ANY wheel with a black rubber rim. going bad. replace if you can. but they are VERY HARD TO FIND if u don't know what u are doing.
