Question about ASUS VW192S Monitor
Change settings and hold them on vw 192 T asus monitor
I use a vw 192T monitor
i can change the settings, but I cannot lock them, they
revert back to default settings every time i press the spledid button
how can i change the settings and lock them
paul berg
Melbourne, Australia
e mail< paulberg@optusnet.com.au>
  • Anonymous Sep 20, 2008
    I'm Carles from Barcelona.
    I have VW 192 monitor.
    What happens is that the screen it doesn't show anything but an "Out of range". I try to go to menu and fix it by pressing its boton, buts still have the same "out of range" into a square and it doesn't appear the menu to fix the ranges.
    What can I do?
    Thanks
    Novelist:
  • 103 Answers
Hi Paul,
Hope this solves your problem same I met before. There are a lot of queries it may involve here to streamline the problem. Well, first try to reset the monitor setting manually in OSD mode, then select different frequencies there and try each. To much with your PC video card frequency try changing the video adapter frequency properties on PC GUID or operating system video card panel. Try lower frequency first..
If the problem persist, like you've said it changes back to default setting when pressing the monitor setting buttons, there must be some problem in the circuit board of the monitor it cannot hold the frequency settings due to cold solder on control processor section and buttons. Other major defect is the CMOS chip to hold the settings and or bad caps.
Posted on Jan 30, 2008
Can pl i get asus vw192t monitor drivers
Posted on Feb 17, 2009
How do I stop the aspect ratio from auto changing on my flat screen set up as the monitor for my computer?
When you set it to just scan the source will determine the scan. I would remove the bose from the unit and connect the cable or sat box directly to the hdmi in of the tv. if the problem persists check Samsung web site for software upgrade. If upgrade does not fix replace the main circuit board.
May 07, 2014 | Samsung Televison & Video
My SyncMaster 192T wiill not switch on . All connecting leads are plugged in correctly
The problem is in the power supply board, there is one or two capacitors that open and sometimes has a bulge at the top, "easy to spot"
Apr 07, 2012 | Samsung SyncMaster 192 T (Silver) 19" LCD...
My monitor is of AOC " e2043Fsk " . When I try
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Jan 03, 2011 | ASUS Computers & Internet
Problem with geforce 8400 gf video card and asus vw 193f monitor. Monitor doesnt work properly.
The native resoltion for this monitor is 1440 x 900 @60Hz for best picture. Are you able to set your PC resolution to this number?
Sep 23, 2010 | ASUS VW193T Monitor
I cannot type a 0 on the keyboard and numbers are coming up when I type
You have the number lock on (Num Lock). Just hit the Num Lock key and it should revert to normal. If this does not work hold down Fn and then hit the Num lock key.
Regards.
Mar 20, 2010 | ASUS Eee 4G Notebook
NO SIGNAL PROBLEM
Please check whether the monitor is set to the correct settings. If you feel its incorrect, most LCD/TFT monitors come with an auto set up button which will restore the display to one that usually works. In case it still doesnt work, you might need to connect your pc to a different monitor and check the display settings. You could also try to download the drivers for this monitor and then re-connect the monitor and see if it works.
Jun 02, 2009 | ASUS VW192S Monitor
Vw asus monitor
Download the correct driver for the VW193T monitor. Match your windows version.
http://www.asus.com/products.aspx?l1=10&l2=87&l3=545&l4=0&model=1686&modelmenu=1
Jan 03, 2009 | ASUS VW193T Monitor
More Auto Adjust
na moiom monitore vw 192 s kartina desktop podvinulas na pravo. kak mne etu problemu reshit? iz meniu eto ne poluchilos.
Jun 19, 2008 | ASUS VW192S Monitor
ASUS VW192S Monitor Logo
1,194 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
