Question about Tricity Bendix TM310W Electric Dryer
Condense Pump on TM310W
Can anyone tell me the easiest way to get at the condense pump on the TM310W.
My tm 329 condensor drier , the power is on but no action will happen i used it alot the past 2 days and then this happened i have cleaned all the vents and the water tank is fine the water tank isnt even on
Posted on Aug 10, 2011
  • 126 Answers
Remove the side panles, an locate the pump. Then look if you can get it out without removing the backpanel.
Posted on Jan 30, 2008
Malber WD1000 wont condense the water that is fed through during the drying cycle
Since it drains properly during the wash cycle, we know the drain pump and its impeller (propeller) work, and the coin trap (you called it a filter) and hoses are not clogged. By the way, turning the rightmost knob to "4" will start the pump-out cycle, so you don't have to open that trap-door at the bottom. To condense, the machine needs COLD water (spritzing on an internal screen) during drying. Make sure your cold water hose is connected to the outside (outboard) connection on the back of the machine. As a long shot: If the gray drain hose is pushed too far down into your home's drain pipe (more than 8") there could be a "back-siphon" where dirty water siphons back into the washer. It's a long shot, but it does happen.
Lastly, the controller board (mounted at top of right side) could be bad, and not sending on-off commands to the pump during drying. During drying, the drain pump should cycle on and off constantly, every few minutes. Do you hear it running? If you remove back (about 12 Torx screws), at your lower left you will see the pump. There are only 2 wires (120 VAC) and they can be connected either way. Stick a meter on the terminals and see if power is cycling on and off. If not, the controller board is bad.
You can order one from Malber (in NYC) by calling Nancy at 516-323-5299. Tell her Mike, in Wash. D.C., says hi.
Mar 06, 2015 | Malber WD1000 Front Load Washer/Dryer
I need to know where the orange wire hooks up to
The orange wire is usually the reversing valve for a heat pump. If this is an air conditioner, you don't need it.
Welcome To the Best HVAC
Oct 08, 2014 | Heating & Cooling
To replace the condense of A5 VW Golf 4 cylinder air conditioner and change oil in pump
To change the condensor undo the lines and mounts and remove.Replacing is opposite proceedure. Replace the air dryer/ receiver at the same time. There should be no need to change the compressor oil as it moves trhrough the system with the gas and there is no sump as such.
Mar 16, 2013 | Cars & Trucks
Why my heat pump is condensing a lot
If on the air conditioning mode, it will be normal to condense if the relative humidity is above 45 percent. The higher the humidity, the more condensation the AC unit will produce. You can lessen the condensation if you set the thermostat a bit higher.
Apr 29, 2011 | Heating & Cooling
04 ENVOY,REPLACED SECONDARY AIR PUMP AND BLEW OUT SYSTEM, REPLACED FUSE AND STILL PUMP IS FILLING WITH WATER, CHECKED ALL HOSES AND FOUND NO CRACKS, WHAT ELSE SHOULD I CHECK
The water comes from exhaust system /condense/ because the check valve does work properly. The check valve is located on left top side of the engine where the hoses from the air pump connect to the exhaust.
Apr 01, 2010 | 2004 GMC Envoy
Condensation running down old vent pipe running to roof.
This is a condensing furnace and is ment to condense. You will need to pipe away the condensate using a hose and maybe a condensation pump. It is unclear where the combustion air pipe is going? Are you using room air? or do you have a second pipe going up the old vent as well?
Jan 05, 2009 | Goodman GMS90703BXA Heater
Water tank not filling
Probably it is lint in the condense pump.
Jan 30, 2008 | Tricity Bendix TM310W Electric Dryer
Washer dryer is no longer drying
two things to check take rear half of cabinet off and check the dryer duct (lhs from front) is not blocked. this is very common check water is being taken in during dry - the water is used to condense steam from the drying clothes. easiest way to check this is to see that some water is being drained during the drying cycle. i assume that drain is operating ok
Jun 03, 2007 | Zanussi ZWD1270 Front Load Washer / Dryer
Tricity Bendix TM310W Electric Dryer Logo
164 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
Marvin
Marvin
ptpumpman
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
