Question about Gateway FPD2275W LCD Monitor
Emergency Light using 9 or 11watt energy saver lamp
I would like to get a circuit diagram which i can use to creat an emergency light so when power goes off then light comes on. It obviously must have abattery and must be rechargable as well
Thanks
Wayne
  • 1 more comment
  • mekpig Feb 06, 2008
    I have a problem of posting of the screen which with the demarage parrait clear and at the end of two second solidifies and becomes very white. And the same thing occurs when I always relight it.
  • Derek Lawson Feb 07, 2008
    AC Mains [email protected] ][ |> /<|
    120V relay @ ][ | / |
    AC [email protected] ][ | / |
    1 2
    Use 1 and 2 as a switch to turn your light on. When AC is applied, it keeps the light turned off. If you use 12 volts, the relay is available from Radio Shack. you wan the coil to pull in at 120VAC and the contacts rated for at least 12 volts, iif not 24.
  • Nobb Feb 07, 2008
    Hi Ini yes i would like the circuit. I want to make backup for emergency light between 9watt and 56watt lamps. For atleast 4 hours.Thanks
    Wayne
    [email protected]
  • 44 Answers
My dear can you tell me how much backup u want. you can build it up to 8hour back up with charging circuit & reverse battary buck boost voltage while running on battary. this may increase your backup time. and the circuit is very simple. if u really want to make it then reply, i will sent u a circuit.
Posted on Feb 07, 2008
6ya staff
SOURCE:
Instaling a new pilot light assembly inBryant 234B boiler. The wires to the emergency shut off are not color coded in wiring diagram. Does it matter which wire (only 2 wires)goes where?
Hi Anonymous.
An emergency shut-off loop will almost always be set up so that the circuit is closed during normal operation, with a press of the emergency off button breaking, or opening the circuit. It's set up that way so that if a wire in the emergency circuit breaks, or gets disconnected, the system will shut down, rather than allow operation where the emergency off won't work.
Functionally speaking, if you only have two wires to the switch/button, then which way you connect them won't matter, since the switch will complete the circuit regardless of which way you flow the current. From a Code and consistency standpoint, one of the wires will be ground, and one of them will be hot. Most switches have leads indicating ground and hot on them, and you should be consistent with that. If nothing else, if someone else is later servicing or replacing the switch, also not knowing which wire is which, then they have less risk of mistaking a hot wire for a ground and getting zapped.
Depending on the setup, and whether it's AC or DC on the loop, you should be able to use either a voltmeter or an electricians hot-wire-detector to tell which lead is the hot lead.
Hope this helps, and good luck!
D
Nov 19, 2015 | Electrical Supplies
69 turn signal problem left turn signal not working. right turn signal causes both to falsh
it's the grounds if they're both flashing fast it's definitely grounds take a test light and see if its got power goes through the test light grounded to the frame and if the light comes on then it's definitely your grounds
Jul 29, 2014 | 1969 Pontiac Firebird
My 99' chevy tracker has power surges and interior lights on dashboard do not come on and radio time goes very dim when automatic headlights come on
Do you know how to test automotive electrical circuits ? Checking B+ voltage an grounds ? Voltage drop testing ? Do you know what a electrical wiring diagram is ? How to use one to pin point testing spots in a electrical circuit ! A couple simple test's using a DVOM - digital volt ohm meter is probably all it would take to find the problem . High resistance in a power or ground circuit is probably all it is .
Electric Testing Techniques You Need to Know
Voltage Drop Testing the Charging System
The Trainer 47 What measuring voltage on the ground side means
watch these videos , if this isn't something you could do your best bet would be to take it to a qualified repair shop that can . Free wiring diagrams at http://www.bbbind.com/free_tsb.html
May 19, 2017 | 1999 Chevrolet Tracker
I just bought a 1989 Chevy Suburban 2500. For some reason the back lights and backup lights are not coming on. Brake, blinker & emergency lights work fine. - any suggestions. Also where is the high...
if the bulbs are good then you may want to check for power at the bulb sockets. the circuit boards on the brake light housing goes bad and looks for ground on an adjacent circuit.
Jul 26, 2011 | 1989 Chevrolet Suburban
I"m working on a project to create a solar powered
Hello. Think I found the necessary information you require. Check out this link:
http://www.solarpowerwindenergy.org/2009/04/26/how-to-build-a-small-solar-circuit-wiring-diagrams/
There are schematics for each stage.
This one is a ladder diagram schematic only:
http://electroschematics.com/5988/outdoor-garden-solar-lights-circuit/
Good luck, and if this helps, rate it a four-thumbs up please. Thank You.
Apr 21, 2011 | Atlantic Water Gardens SINGLE LARGE LED...
I have a 1595-SWTTRWCC4 switch. None of the wiring diagrams show the two black wires coming from the switch. I am using the switch to turn on a light above the sink and use the outlet for counter top...
If the wires are coming out of the switch portion & not the outlet, 1 goes to power the other goes to that color wire that goes to your light. All you are doing with a switch is cutting one side of your power, putting switch in completes the circuit when it is turned on. Or breaks the circuit when it is turned off. The other wires, power in & back to light get wire nutted together.
Sep 04, 2010 | Pass & Seymour #TM818WCC6 15A White...
Kill power to light and emergency single light does not turn on also with power on push test knob and emergency bulb not come on
Hello Ramon, Check the power back (battery cell) as without a functioning battery pack, the emerbency light won't function.
Typically the batery packs will need to be replaced periodically every 4-5 years, depending on the istallation location and ambient temperatures.
When you kill the power to the emergency lighting circuit the PSQ is switched to operate automatically on battery power only. The same thing occurs when you press the test button; it disconnects the lighting from the electric power that keeps the battery charged and ready for service. You might also want to check the bulbs with a test meter (remove the bulbs from the fixture and test with the Ohm setting) While rare that these bulbs burn out, since they aren't usually illuminated often, only during a power disruption/outage, etc.
Here's a link to the Lithonia site with the spec sheets for the PSQ series of emergency lighting products, for your use and reference.
http://www.lithonia.com/product/advSrch.aspx
I hope you find this Very Helpful and best regards!
Nov 24, 2009 | Lithonia Lighting Psq500 Power Sentry...
No brake lights or dash lights
You obviously have a hard fault in the circuit. Somewhere in the system the power is grounding out before it is supposed to. I would download a diagram from autozone.com in the DIY section. There you can trace where the power is supposed to go and look for chaffed or bare wiring.
Jul 31, 2009 | 2004 Isuzu Rodeo
Benq Q7S3
Video Graphics Card in Computer "BAD" !
Nov 15, 2017 | BenQ FP567s 15" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
151 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
