Question about BenQ PB6100 Multimedia Projector
Projector shutdown Hi I have a Benq PE8720 projector It shuts down about 5 minites into the picture I restart the projector and it appears to work fine, and can watch the rest of the dvd. thanks
  • 104 Answers
Your air filter of your projector is dirty, try cleaning it. tnx
Posted on Jan 30, 2008
Benq MX761 stays on for only 2 minutes and then shuts down after genuine Benq lamp replacement. Picture flickers colour just before shutdown. Lamp timer has been reset to zero.
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. Check to see if your TV is still under warranty first though.
Nov 29, 2014 | BenQ Projector Lamp for MX760 MX761...
Benq pe8720 service manual
8720 Went out just prior to playing. Now will start up, go to benq logo then lamp goes off. on top of projector lamp light is red. repeat lamp does go on seems as bright as ever but shortly after benq logo goes off. By my recollection lamp is not beyond it's 2000 hour range.
Feb 18, 2012 | BenQ PE8720 DLP Projector
Projector shuts down ca 20 sec from start.
sounds like you may have the wrong bulb and it is being overpowered.
Dec 15, 2009 | BenQ PE8720 DLP Projector
My benq projector keeps blowing lamps.
first, blow out any dust with canned air. dust keeps in the heat that the projector is trying to expell. next, don't buy cheap lamps from random websites. you get what you pay for. and make sure you have the correct lamp that the manufacturer states. also make sure there is sufficient space around the projector. the vents cannot be blocked. lastly, reset the settings to factory default. many times there is a low power/full power setting. the fans go on full on high power. there should be at least 2 fans. one for the lamp, one for the optical engine. may be one for the power supply. if the one near the lamp is not blowing much, replace it.
Nov 29, 2009 | BenQ PE8720 DLP Projector
Shutdown & error led blinking 2 times
Shut off your projector by swith on the back near the AV inputs, leave it off for about five minutes. Then switch it back on, manually press the power button, let it start for about 5-10 seconds then continue to hold power button until picture appears. It worked for me, good luck to all.
Mar 24, 2009 | NEC HT1100 Multimedia Projector
BenQ MP612c projector has three orange flashing lights
you can go to the BenQ website and download a manual for your particular projector. It should tell you what the lights indicate.
Feb 01, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Nov 17, 2008 | BenQ PB6110 Multimedia Projector
Lamp time
Hi
You will have to reset the lamp timer as follows :
Hold down the up arrow key on your projector for a couple of seconds - projector must be switched on.
You'll see a on screen message appear in one of the top corners on the image....then just follow the two basic steps as requested on screen.....your lamp timer will now be reset.
Then shut down the projector and restart for changes to take effect.
Oct 25, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
BenQ 8700 projector solution
Hi Rick
The upgrade is the same one used for the BenQ PE8720
Whoever told you this obviously did'nt know this.
You'll be needing Flashloader and the RS232 cable that came with the Projector.
It is absolutely cheeky of them to suggest that you should just use the Component input for all your applications on this Projector.
Make sure they understand that this was a top of the range Projector when you bought it and that it is not a good enough answer.
Apr 02, 2008 | BenQ PE8700 Multimedia Projector
BenQ PB6100 Multimedia Projector Logo
377 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
