Question about Samsung LE40R74BDX 40 in. LCD Television
HOW TO TAKE OUT THE STAND
I'M TRYING TO HANG MY TV BUT CAN'T FIGURE OUT HOW TO TAKE OUT THE STAND. PLEASE HELP...THANKS
    Sergeant:
  • 261 Answers
Usually it is in the owners manual, but if not, try removing the screws on the back bottom of the base. Just lay that LCD on a flat surface like a bed and then you should be able to see how to remove the base. usually 4 screws. I haven't seen this exact model though. Good luck. Jay
Posted on Jan 31, 2008
Cannot figure how to attach stand to TV. Please help
Hi Carl,
Attaching a stand to a TV is a very simple job. You have to put or slide the stand in to its slot and tighten a few screws. Please try it I am sure you will do it.
Aug 04, 2015 | Proscan 19LA25Q 19 in. LCD Television
Cant find how to remove the stand on our newly purchased Soniq QSL323CT1 anywhere in the manual. We are trying to mount it on the wall.
1. Disconnect all cables.
2. Cover a level and stable surface with a thick and soft cloth.
3. Gently lay the TV, face down, onto the cloth. Make sure the Table-Top stand is hanging over the edge.
4. Rotate the cable holder 90 degrees, and pull it out completely.
5. Remove the screws (3 or 4 in rear next to cable holder, depending on which model wall-mount kit you have) being sure to hold the Table-Top-Stand firmly while removing the last screw.
6. Do not remove any other screws from the TV.
They also say not to remove the stand for any reason other than wall-mounting the TV. Their should be instructions with the wall-mount kit.
Hope this helps!
Thanks
Smith.
Sep 07, 2009 | Televison & Video
GPX hm3817dt - How do I get the ''removable'' stand off?
Ok, nevermind, I fixed it. You just stick a flat head screwdriver in the little slot at the bottom and pop the stand off. Thanks anyway!
Aug 29, 2009 | GPX Audio Players & Recorders
The screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
May 26, 2009 | LG 42LG30 42 in. LCD HDTV
Putting the tv stand back on the tv
these are removal instructions should be helpful though
Open up the panel on the back of the TV which covers the various input connections. At the bottom of the area previously covered, there are 8 screws (two rows of four screws). Remove them, and the entire stand should now slide right out of the TV. You can then replace the screws back in their holes, so you don't lose them. You do not need to disassemble the stand to do this.
Mar 09, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Need to know the WEIGHT of Sony TV: KV-27EXR25
most tv stands have a large range of rating. most range in increments of 100 lbs. The tv you have is around 40 lbs. so if your stand will support up to 100lbs. your good to go. also you didnt specify if this is a hanging stand or floor stand. I am asumming the previous as being a hanging stand. with that make sure you get the bolts into a stud as drywall will only support about 20 lbs. before ripping out.
Dec 28, 2008 | Sony Televison & Video
Cannot figure out how to remove stand so I can mount TV on wall
did you figure this out? I only ask because I need the stand for my TV. Could you sell me yours?
Thanks
Anthony
amsaxo@yahoo.com
Dec 02, 2008 | Sylvania 6620LDG 20 in. EDTV-Ready LCD...
Can't get base off 26" Insinia 720p
On the back of the set you will see 8 screws just above the stand; remove the screws
and gently slide the stand out. Wiggle it alittle and the stand will come out.
Remove the metal tab you just pulled out by removing the screws at the bottom of the tab (attached to the pivit joint) place the tab back in the bottom of the set( same place you removed it from) and re-install the screws ( don't over tighten them). You are done.
I had the same trouble with this set and the tech support was of no help. Good Luck.
Jul 17, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Trouble removing the stand
There are 4 screws lay the tv flat on it's face and leave the stand hanging over the edge of the table, put a blanket under the tv to protect the screen, hold the stand up to take the pressure of the screws and use a philips head driver with magnetism, I do this for a living and you should not be having such a problem
Feb 07, 2008 | Samsung LN-T4671F 46 in. LCD Television
Remove stand from LG 50PC5D
There are four screws in the back of the TV above where the stand is. Inbetween the screws is a metal handle that pulls out. These four screws need to be removed and the metal handle pulled out. Then the TV will come off the stand.974336c.png
Oct 16, 2007 | Televison & Video
Samsung LE40R74BDX 40 in. LCD Television Logo
345 people viewed this question
Jerry Greenberg
Jerry Greenberg
