Sabrent TV Tuner / Video Capture Box USB 2.0 with Remote Control (TVUSB20) Logo
Posted on Dec 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The hardware wizard cannot find the drivers in my disc drive, but i can open the files through my computer and istall them. but my device is still not seen.
Anonymous
Level 2:
Scholar:
  • Expert 51 Answers
  • Posted on Dec 31, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
51
Questions
0
Helped
22588
Points
166
Hello!
Use the below link to download the drivers for your device.
http://www.sabrent.com/#section=Drivers&itemName=&itemID=0
This will bypass you needing to use a disc.
After you install, the device should be ready to use!
If this doesn't work for you, please leave a comment below and I will be more than happy to help you resolve your issue further!
Happy New Year!
Feedback is appreciated!
  • Anup Kodlekere
    Anup Kodlekere Feb 28, 2014
    Does it need a hardware to use? I mean, I have no TV tuner. I just downloaded AVertV 3D and I get this error: Device is not ready to use". Should I first get a TV Tuner?
2helpful
I don't know how to install my built in webcam on my msi u135dx laptop
Run the "Add a device" application, accessed by clicking on the "Start" button, opening the "Control Panel," and then double-clicking on "Add a device." The "Add a device" window will open and Windows will search for devices connected to your system but not installed. Click on the webcam name that shows in the search box and then click "Next."2 Choose whether you want Windows to search for the webcam device driver using Windows Update over the Internet, or if you'd prefer to have the device manager search for the driver using a disc supplied by your laptop manufacturer. Most drivers can be found on the system recovery disc included with your laptop, if you choose to add the driver from the provided disc. Place a check in the box next to your choice and then click "Next>" to continue.3 Wait while indows searches from the driver using Windows Update, if this was your choice. An active Internet connection is required for Windows to successfully do this. Allow the computer to install the driver and then reboot the system for the webcam to become recognized by the system.4 Otherwise, you can use the system recovery disc or a driver downloaded directly from your laptop manufacturer to install the driver without using the Windows Update search feature. 5 Open the CD/DVD-ROM drive and insert the system recovery disc, or place the driver downloaded from the manufacturer in an easily accessed file directory on your PC, such as on the desktop, or in your "My Documents" folder.6 Choose the option "Install the software automatically (Recommended)" in the "Add a device" application, and press "Next>" to begin searching for your webcam driver. The hardware wizard will search the system recovery disc and install the driver automatically. Press "Finish" to close the wizard and then reboot the computer to allow recognition of the webcam. Choose the option "Install the software manually" in order to browse to the driver location where you saved the driver and install it from there. Use the opened file manager and locate the driver. Click the "Next>" button to install the driver, then reboot the computer to add webcam functionality
Istalation de mi cam
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Why can't i istall my webcam to my laptop im using windows 7
1helpful
2answers
Am getting error no 41 i.e my laptop is not recognozing my dvd
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you might see a yellow question mark ? right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
1helpful
Windows Media Player cannot play the file because there is a problem with your sound device. There may not be a sound device installed on your computer, it may be in use by another program, or it may not...
this problem happens when sound driver is nt installed or nt installed properly
in this case if the driver is installed then uninstall it from control panel restart pc and then install the driver again
after istalling driver restart ur pc
this will definitely work
and if not then uninstall driver restart pc
right click on my computer
then on properties - hardware tab - device manager
check out here any device marked by yellow icon right click on it and then select install or update driver and new hardware wizard opens select install from internet and thats all ur problem will be solved
Error 39 canot load the driver
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Uninstall and reinstall the driver
Uninstall the driver from Device Manager, and then scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
1helpful
2answers
I have downloaded driver for philips 170c monitor but when i go to zip file there is no driver there
These are the steps you need to follow to install the driver: Download from the link below:
Philips 170c Monitor
It is a zip file so you will need to unzip it into a separate folder. Once the files are unzipped you need to locate the 170C8.inf setup information file. Once you have located that file right click on it and you will see the option to Install. Click that and it will ask you to open it. Choose open.
If that fails you can do the following:
Installing a new device
1.Open Windows Device Manager. In the Device Manager make sure the device you're attempting to install is not already listed from past install attempts. If the device is found highlight it and remove it from Device Manager to prevent any conflicts during the install.
2.Once Device Manager looks ok reboot the computer.
3.As the computer is rebooting an install new hardware wizard should appear if Windows detects the new hardware using this wizard you should be able to point Windows to the folder containing your drivers either on the CD, diskette, or the folder containing the files you downloaded.
If Windows does not detect any new hardware open Control Panel and double-click the Add hardware icon to run the hardware detection wizard. During the steps you will have an option to tell Windows you have a disk containing the drivers for your new hardware device, at this point Windows to the directory containing the drivers for your device.
Once drivers have been installed reboot.
I’m happy to help further over the phone at https://www.6ya.com/expert/jonathan_828b54f422cbefdd
Audio and video drivers
when you are in the device manager have the computer search for new hardware and see if the devices show up. As for the drivers the ones off the manufacturer website should definitely run the hardware.
Before you search for hardware in windows get into bios and make sure the devices are enabled. If the devices are enabled and the drivers off the man. website do not work the shotgun will. Well it will make you feel better but your video and sound won't work
1helpful
2answers
Web cam istallation
I have the image of the original driver CD, anyone and everyone can download it FREE.
http://www.geocities.com/guate6/Phillips_PC_Cam.zip
1helpful
How to install driver
How do I install a computer driver?
Answer: Microsoft Windows users Depending on how the driver has been packaged is what determines how the driver will be installed. Below is additional information about each of the methods developers use to distribute their drivers and how you would install the drivers in Microsoft Windows.
General driver tips
Below are some general insights to help prevent any additional frustration that may be encountered while installing drivers.
Drivers on CD or floppy diskettes:
Almost all computer and hardware manufacturers include a group of drivers for different hardware devices and often for each of the supported versions of Windows. For example, the driver CD you receive with your printer likely contains the drivers for dozens of different printers. Not just the printer you purchased, which means when installing the drivers make sure you're installing the drivers for your printer, not another printer model and that you're installing it for the version of Windows you're running on your computer.
Below is an example of how a file structure may look on your disk.
CD Example:
-PrinterA100
--Win9x
--Win2k
--WinXP
-PrinterA200
--Win9x
--Win2k
--WinXP
-PrinterB100
--Win9x
--Win2k
--WinXP
If for example you had a PrinterA200 and were using Windows XP you would find your drivers in the PrinterA200\WinXP directory.
Downloading drivers:
Almost all drivers you download are going to be a single file if the file is not an executable file it is almost definitely a compressed file that contains all the driver files. In order to install the driver you will first need to uncompress the file. Additional information about how to uncompress a compressed file can be found on document CH000506.
When extracting / uncompressing the drivers make sure to remember where you place the folder containing the drivers as you will need to point Windows to this folder when installing the drivers. We usually recommend users install the driver files in a folder on their desktop as it's an easy place to remember and locate.
Finally, the single file and/or the files extracted from the compressed file can be deleted after you have finished installing the drivers.
Executable
Many computer and hardware manufacturers today are pre-packaging their drivers into executable files or have the drivers installed through the setup file, which means simply double-clicking the setup file or the file you download should install the drivers to the computer for you.
Note: Many developers may package their drivers in a compressed file, which means before looking for the setup file you may need to uncompress the downloaded file. Information about doing this was explained above. If after uncompressing the file it still does not contain an executable file, some type of setup file, or does not install your hardware device continue with the below recommendations.
Finally, if you were successful in installing your drivers make sure to reboot the computer after the drivers have been installed.
Using the have disk option
Often computer manufacturers and hardware manufacturers will also simply place the drivers on the CD, diskette, or download for Windows to find and use during its hardware detection. Below are steps on how to install drivers for a new device and upgrade a devices driver for this type of setup.
Upgrading drivers for pre-existing device
  1. Open Windows Device Manager. Information about how to do this can be found on document CH000833. In the Device Manager make sure the device you're attempting to install is not already listed from past install attempts. If the device is found highlight it and remove it from Device Manager to prevent any conflicts during the install.
  2. Once Device Manager looks ok reboot the computer.
  3. As the computer is rebooting an install new hardware wizard should appear if Windows detects the new hardware using this wizard you should be able to point Windows to the folder containing your drivers either on the CD, diskette, or the folder containing the files you downloaded.
If Windows does not detect any new hardware open Control Panel and double-click the Add hardware icon to run the hardware detection wizard. During the steps you will have an option to tell Windows you have a disk containing the drivers for your new hardware device, at this point point Windows to the directory containing the drivers for your device.
  1. Open Windows Device Manager. Information about how to do this can be found on document CH000833. In the Device Manager locate the device you wish to update the drivers for.
  2. Right-click the device and click Properties.
  3. In the Properties window click the Driver tab.
  4. Click the Update Driver button.
  5. In the Hardware Update Wizard point Windows to the location of the updated drivers on your hard disk drive
Install through the .inf file
Finally, if the above recommendations do not work the installation instructions for drivers and hardware devices are always contained in a .inf file that is located within the drivers.
Locate the .inf for your version of Windows right-click that file and choose the option for install. Note this is a very raw form of installing a drivers and it is important that you make sure you're installing the correct .inf file and not a .inf file for another device or for a different version of Windows. Additional information and tips about locating the drivers was explained earlier in the general driver tips section.
Once you have right-clicked and installed the driver reboot the computer
One of the above three recommendations should have installed / updated the drivers successfully onto the computer. If you're still having difficulties getting the device to install it's possible you're not encountering a hardware issue and not an issue with the drivers. Refer to the troubleshooting steps for your hardware device for additional help and information.
Dont for get to Vote
Merry Christmas....Good Luck!
Top Sabrent Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Sabrent Televison and Video Expert? Answer questions, earn points and help others
