Rank: Apprentice
Rating: 100%, 2 votes
Thank you Debajit for the wonderful solution. Please refer to solution no# 5. I iam providing the steps:
1. open the url
http://192.168.1.1 (BSNL provided Nokia Siemens WLAN Router) with username 'admin' & password 'admin' (default).
2. click on WAN link under ADSL nad from the table on the right side 'edit' the first connection settings.
3. in the 'connection type' screen select 'PPP over Etherner (PPPoE) instead of 'Bridging' (which is selected by default i.e. set by the BSNL setup guy) and click 'next'.
4. This section is new as it would now ask for the credential to connect. The credential is same that is used for connecting through the icon on the windows network connectivity section, which is again provided by the BSNL. Also apart from the credential you need to type something (i have put 'BSNL') in the field 'PPPoE Service Name'. Now click next.. next.. next & finally save
5. Now you would be in the same configuration screen for WAN from where you have started editing the configuration. Only difference you would notice is only for the top row settings (which you have edited) the 'IP Address' field be with an IP address leased from BSNL server and others below that wuld be blank as before.
If you do no see the ip address then reboot your modem/ router once and check again.
When you can see the IP address there try browsing directly from your computer.. no need to click on the PPPoE connector before browsing the internet.
if you need further help do call me at 9830011178
Regards,
Nilanjan
