2007 Chevrolet Tahoe Logo
Posted on Dec 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hooked up subs in my 07 tahoe radio plays but truck wont start
  • Anonymous Mar 30, 2014
    Hooked up subs and amp and when I went to go hook battery up at the end the suburban start with out key moving the key
fkuk
Level 2:
  • Expert 311 Answers
  • Posted on Dec 31, 2009
fkuk
Expert
Level 2:
Answers
311
Questions
Helped
100936
Points
797
When you turn off the radio and subs does the car start?
do other things work in the car like headlights indicators brake lights
i sugest you turn off the radio and start car or unplug the subs from the battery and try
Why is my Chevy Tahoe 07 Overheating ?
check coolant level and and fan operation
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Chevy Tahoe truck want start
Tahoe starting problems - YouTube
? 1:07
www.youtube.com/watch?v=Mqxd3fE5Ct8
Jan 16, 2013 - Uploaded by TLRMADE
Tahoe starting problems. ... 2007 Chevy Tahoe Engine Part 4, Dissection - EricTheCarGuy - Duration: 11:25. by EricTheCarGuy 84,439 views.
Fix error code 8 for 2003 tiburon radio
your not use any menual. this control is cpu control by remote or" panel switch.
2004 chevy tahoe cd goes into radio and display
Yeah you need a new CD player common on those trucks but be careful the RDS radios must be programmed if get a used factory radio
2helpful
I want to hook my IPod directly to the aux port of my radio and I want it to charge the iPod as well as play the music. Is there a cable that does both music input and power charging? I have a 2001 Tahoe...
You can get a Peripheral PXDX and connect it to you AUX port on the back of you radio. The interface can be tucked behind the dash with the docking cable being the only part hanging out-to connect your ipod to. You can change songs from your radio control head-or steering wheel controls-if your vehicle has them. The docking station charges your Ipod while it's connected. Peripheral has a website you can read about the interfaces. They are available on ebay for under $100. I have the interface in two of my vehicles. The only problem is, you can't see which track is playing on your radio, but you are able to skip through tracks either by Ipod control or radio head.
My 93 Boneville CD Player does not work, the radio works fine but it will not play CD's, also how would i install a set of speakers (subwoofers)
the cd player is bad and you can hook up subs through a rca hook up that you can hook to your speaker wires in the trunk the adapter is like 20 bucks at radio shack or local sound installer or buy an after market cd player cause yours will never work again and run rca's off the back of the radio to your trunk
Electrical ?
I have a '96 tahoe. Look for a code on the battery to see when it was installed. L09 would be december 09. if it is less than 3 years old have it charged and then try.
Installing cd players
YOU HAVE THE ILLUMINATION WIRE HOOKED INTO THE RADIO
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
