Question about HP LaserJet 1018 Printer
Status of Ink
Sir,
This is suchin ,i am facing a problem that ,i want to check the how much ink is there in a cartridge , in desktop,, i am using hp laserjet 1018.,
  • 21 Answers
Open the printer tools program in the printer editor usually comes with printer especialy HP.
Posted on May 31, 2008
Pixma 2200 series all in one
Don't use refill kits, they are no good in quality printers. Also the cartridges in the newer models have a chip in them that knows when the cartridge is empty. When it becomes empty, the chip has to be reset, and this is what those mall cartridge fillers do.
E, 1, 3 The ink may have run out. The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected. If you want to continue printing without this function, press the machine's Stop (Reset) button for at least 5 seconds. Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities. Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition. Checking the Ink Status Checking the Ink Status with the Ink Lamps on the Operation Panel The ink level detector is mounted on the machine to detect the remaining ink level. The machine considers as ink is full when a new FINE cartridge is installed, and then starts to detect a remaining ink level. If you install a used FINE cartridge, the indicated ink level of it may not be correct. In such case, refer to the ink level information only as a guide. When remaining ink cautions or errors occur, the error code will be displayed on the LED (Light Emitting Diode) to inform you of the error. Check the error code and take appropriate action. -> [ An Error Code Is Displayed on the LED ] See[Checking the Ink Status ]
Oct 27, 2015 | Canon PIXMA Office Equipment & Supplies
Changed ink cartridge on epson stylus and now keeps coming up with cannot recognize ink cartridge on one that was not changed
can you check that the old cartiage cooper connectors are clean ? cuz it is the old carrige and full of ink dirts
May 23, 2011 | Computers & Internet
How to find ink levels in hp932c printer
Print Cartridge Status The Print Cartridge Status Light flashes when one or both of your print cartridges are low on ink, improperly installed, or malfunctioning. It will also flash if you are trying to use the wrong print cartridge type. If the problem is low ink, the light will stop flashing when you open the top cover. For any other print cartridge-related problem, the Print Cartridge Status Light will continue to flash. To check the status of your print cartridges, open the printer's top cover. The yellow arrow on the print cartridge cradle aligns with one of five Print Cartridge Status icons.
Jan 08, 2011 | HP DeskJet 932c InkJet Printer
Epson stylus sx200 refuses to acknowledge black ink bought direct from epson
I believe the DX series and the SX use the same system
# Determine which ink cartridges are not recognised.
# With the ink cartridge holder in the ink cartridge replacement position, lift up the ink cartridge holder lid and take the cartridge or cartridges out.
# Check that the cartridge is a genuine Epson ink cartridge - look for the EPSON branding and T0xxx codes on the cartridge labels.
# Check that the cartridges are correct for your Epson product.
# Wipe the green Intellidge Chip on the cartridge that is not recognised.
# Check the chip contacts within the ink cartridge holder for any debris or dried ink and wipe with a lint-free cloth if necessary.
# Check that the plastic at the bottom of the cartridge has been pierced.
# Check that the cartridges are in the correct slots.
# Reinstall the cartridges into the ink cartridge holder in the correct order.
# Push the ink cartridge down firmly. It should click into place.
# Repeat this for any ink cartridges that were removed.
# Push the ink cartridge holder lid down. It should clip into place and be secure.
# Press the Stop button, this will return the ink cartridge holder to the right hand side of the unit.
# If the error light flashes after the print head returns to the home position, the ink cartridge may not be installed properly.
# If the red light is no longer displayed, but Status Monitor still reports a Non-Genuine Ink warning.
# If the red light is still on the printer, and Status Monitor indicates that an ink cartridge is not recognised, follow the steps below.
# If the problem remains, there may be a fault with the ink cartridge.
Dec 30, 2010 | Epson Office Equipment & Supplies
I have problem with my HP business ink jet 2230. Problem is with cyan ink cartridge. I put new original cyan ink cartridge in printer, after that message is display "Attention cyan ink cartridge expired"....
hello sir, hi, the ink comes out from the ink cartridge to the ink cradle where the ink pass to the paper, this is clogged, need you to clean the ink cradle, you can use warm water to soften the dried ink.
Sep 16, 2010 | HP Business Inkjet 2230 Printer
How do you check the ink levels of the cartridges on a hp deskjet 940c
If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing when the printer’s top cover is opened. When you open the panel the ink cartridges slide to the center , as far as checking the ink level find and right click on the printer icon, click properties, and find ink cartridges and ink levels.
Thanks
Shereena.
Apr 22, 2010 | HP DeskJet 940c InkJet Printer
How do I know WHICH of the ink cartridges is out?
I found this on the Epson Web Site. If you find this information helpful, pls rate me.
You can download the Reference Guide with pictures and all.
http://files.support.epson.com/htmldocs/r220__/r220__rf/index.htm
Windows
You can check the amount of ink remaining in the ink cartridges using EPSON Status Monitor 3 or the progress meter. Refer to the sections below for details.
EPSON Status Monitor 3 Access EPSON Status Monitor 3 in one of the following ways.
  • Double-click the printer-shaped shortcut icon on your Windows taskbar. To add a shortcut icon to the taskbar, see the section below.
    font26.gif See Monitoring Preferences
  • Open the printer software, click the Maintenance tab, then click the EPSON Status Monitor 3 button.
A graphic displays the remaining amount of ink.
If any of the ink cartridges installed in the printer is broken, incompatible with the printer model, or improperly installed, EPSON Status Monitor 3 will not display an accurate calculation for the amount of ink remaining in any of the ink cartridges. Be sure to replace or reinstall any ink cartridge indicated by EPSON Status Monitor 3.
Pls rate me. Thanks and Good Luck.....
Feb 09, 2010 | Epson Stylus Photo R220 InkJet Printer
My Epsn Stylus PHOTO R300 says I need to replace an ink catridge however it does not tell me which one is out of ink. How do I find out which one to buy?
If an ink cartridge is empty, the red error light will remain solid. You can check the status of the of the ink cartridges by looking at the icons on the control panel. Press the down arrow button to scroll down to MORE OPTIONS. The level of ink will be shown on the screen and the ink that will be out will have cross on it.
Please follow the steps below to replace one or more cartridges.
***NOTE***
-You cannot print if any ink cartridge is expended.
-Leave the empty cartridge installed in the printer until you have obtained a replacement.
-To ensure good results on your printouts, we recommend using Genuine Epson Ink cartridges. Epson does not recommend the use of refilled inks or 3rd party ink cartridges.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
1. Make sure the printer is powered on, and not printing.
2. Open the printer cover.
3. Do one of the following:
3a. If the red error light is on (cartridge is empty) press the MAINTENANCE BUTTON.
3b. If the red error light is flashing (cartridge is low) press the MAINTENANCE BUTTON. You will now see the Cartridge Replacement highlighted in Advanced Settings. Select OK.
3c. If the error light is off (outdated cartridge), press the DOWN ARROW MENU button to choose MORE OPTIONS. Press OK, then select INK CARTRIDGE REPLACEMENT.
4. You will now see a message on the display telling you that the ink cartridge replacement will begin. Press OK to continue. The print head will move to the replacement position.
5. Open the cartridge cover. Press in the tab on the back of the cartridge, and lift the cartridge out of the printer. Dispose of it carefully.
6. Unwrap the new ink cartridge. DO NOT touch the green circuit boards, or remove ANY labels.
7. Lower the cartridge into the holder, with the green circuit board facing the front. Gently push the cartridge down until it is firmly seated.
8. If you need to replace another ink cartridge, repeat steps 5-7 above.
9. Close the cartridge cover. Press the front corner of the cartridge cover forward to lock the cover into place.
10. Press OK, and close the printer cover. The printer will begin charging the ink delivery system. Once charging is complete, press OK to finish.
May 23, 2008 | Epson Stylus Photo R200 InkJet Printer
Reset Ink levels for canon mx310
I've heard that with canon there is a way around the ink-level chip monitoring on the cartridge by doing the following:
  1. Power off printer
  2. Hold RESUME button then press and hold POWER, the beeper will sound once.
  3. Hold POWER and release RESUME
  4. Press RESUME twice
  5. Release POWER button
  6. When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
  7. Press POWER to set data
Jan 03, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
73 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
