Question about Seagate (ST3300601U2-RK) (ST3300601U2RK) 300 GB Hard Drive
Seagate 300GB ST3300601U2-RK
There is no power showing to the external hard drive, when connected to cable the green light on the power supply lead/ black box flashes, but the drive will not start?? When you disconnect the power supply cable from the hard drive the green light on the power supply lead/ black box remains constantly on (as it always used to be when in operation).
Is this a problem with the cable/ power supply or the hard drive??
The drive is about 15months old?
thanks, sanyu
  • 1 more comment
  • sanyu Jan 31, 2008
    Its not worked, theres no difference when i tried a new USB cable!!!
    The hard drive has a seperate power supply cable, and when you remove the cable from the back of the hard drive the green light on power supply box (unit that converts 240v to 12v) remains constantly on like any normal power supply unit/ cable. However as soon as its connected to the hard drive the light starts to flash!! There is no evidence that the hard drive is getting power as it will not switch on?? is there something wrong with the cable/ supply or part of the hard drive?? what would have caused such a thing to start happening??
    thanks
    I havent tried openig case as thought that would be risky!!! not sure how to either as it seems well sealed and cant see how it could be opened without damaging the casing!! what do you suggest???
  • drcapheonix Sep 30, 2008
    I Have The Same Problem, I Have The Seagate 7200.10 External Out The Case And tried Placing It In A Standard Pc Tower, The Tower Wont Power Up, So I Will Buy Another Hard Drive he Same Model And Swap The Controll Boards And Try And Transfer All My Dater
    Sergeant:
    Champion:
  • 226 Answers
Usb cable provides power to your hard drive.
try to use new cable.
hopes it works.
pls. confirm
Posted on Jan 30, 2008
Why wont it power up and just clicks
Hi Lisa,
Unfortunately a clicking sound coming from a hard drive is usually a sign of impending hard drive failure.
In such a case it would be advisable to confirm this at your local PC repair store & purchase a new hard drive. If however you have valuable data stored on the hard drive you would have to take it to a specialized data recovery company but this is usually a costly procedure.
Best wishes,
Graemevm
Jan 24, 2012 | Computers & Internet
Hi, I have a seagate ST3160203U2-RK problem with turnng it on the power adapter has a green light but when turn power supply on the hard drive, the green light on adapter goes out - the hard drive does not...
It sounds like the controller for the drive is shot. You will probably need a new enclosure as long as the drive itself is OK that should do it. What is probably happening is that the controller in the enclosure is broken and trying to pull too much power.
May 17, 2011 | Seagate (ST3160203U2-RK) (ST3160203U2RK)...
I have a Assembled Computer with Processor Intel Dual Core (R) @ 270 GHz, 3 GB of RAM equipped with Microsoft Windows XP Professional Edition version 2005 service Pack 3 with Wi-Fi Netgear 108 Mbps Lan...
yah you must buy a Y-USB cable for your external hardisk. this is connection both ends are one is for hardisk and the other two cable is for USB slot of computer. why it two wires connection to usb because one wire is for Data and the other is for Power. If doesn't work..it might be a problem in your Operating system. i recommend to you to reinstall your Windows OS.. theres a 4 reasons why it happen appear the error... deffective USB cable..corrupted driver of USB device for seagate, virus infected of your systems..and maybe your hardive is deffective. Please rate if this is HELPFUL..thanks
Aug 22, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
External hard drive wont stay connected to computer
This depends where the failure is.
If your controller board for the external casing or your power supply have failed the drive can be removed from the casing and placed in a new one($30-$40), then it should work fine. If the circuit board on the hard drive or an internal circuit for the drive has failed then you may require the help of a pro.
Reply back if you need a recommendation for a pro, include your location.
Chris
May 19, 2009 | Seagate (ST3160203U2-RK) (ST3160203U2RK)...
System will not detect my Seagate ST3500641CB-RK 500gb external hard disk
if your system some virus hope it is not read......better you try any other some card reader or pen driver if it read you try other OS ....
Jun 07, 2008 | Seagate (9Y7275557) 400 GB Hard Drive
Maxtor one Touch 300GB no steady green light
The USB Isn,t supplying/providing enough Power to the device.
Search e-bay or similar for a 2 into 1 USB Cable.
Then power the unit with 2 USB Ports on the Computer.
2 x USB Into 2 x Sockets On P.C. 1 x Into Device Drive.
This will be enough power to operate the Device Correctly.
I,ve done this on several external Drives, never failed for Me.
Mike @ compurepair.
Mar 16, 2008 | Maxtor OneTouch II external hard drive...
Power supply for Seagate 400GB
Ebay or seagate.com may be a solution.
I've used those Seagate portables and 2 have caused problems.
Or disassemble the unit, remove the drive and buy a portable case or USB adapter.
Oct 16, 2007 | Seagate 400GB 7200rpm External HDD Retail...
Power indication light flashing
Hi, you may want to try connecting it by USB if you're currently using firewire or the other way around and see if it works. If this fails, you are probably better off using diagnostics by Seagate @ http://www.seagate.com/ww/v/index.jsp?vgnextoid=7f4e19e0babfd010VgnVCM100000dd04090aRCRD&locale=en-US#. Try to use the Troubleshooting or FAQ or if you feel comfortable using their utilities, download SeaTools. Hope this be of help to you. Good luck.
Apr 23, 2007 | Seagate 300GB Pushbutton Backup External...
Seagate (ST3300601U2-RK) (ST3300601U2RK) 300 GB Hard Drive Logo
521 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
