Monitor problem....(blurry image and red flickking)
When i switch on the monitor,the screen flick red light frequently.then picture have small resolution and blurry image.all the capasitor have already checked,but it still wont working properly.can anyone help me?
    Genius:
  • 1,003 Answers
The only real soluton is to replace this monitor sounds like the red cathode is shorting out (basicly piture tube is going out.
Posted on Feb 02, 2008
Lens problem, no zooming capabilities and blurry images
This would need to be serviced something is wrong with the auto focus and this is inside the lens housing. I would take it into a camera shop and have the examin the autofocus.
Jul 13, 2009 | Olympus FE-230 Digital Camera
Sony vio pcg7z2L
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 27, 2009 | Sony Computers & Internet
Laptop runs but screen stays blank
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 01, 2009 | HP Compaq Presario V6000T Notebook PC
THE SCREEN OF MY LAPTOP (ASUS)TURNS PINK.Can anybody help me to solve this.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 14, 2009 | Acer Aspire 5630 Notebook
Blurry screen
There is a focus adjustment inside on a part called the flyback transformer. It's located toward the back of the circuit board, and you'll know which part it is by the red cable going from it to a connection on the picture tube. The flyback generally has two small adjustment knobs on it. The focus knob is the upper one. Slightly turning this one way or the other may improve the focus a bit, but usually a sudden loss of focus means either the flyback or the picture tube has failed. Either of these is cause to treat yourself to a new monitor. You can buy 17-inch flat screens now for less than $150 at regular prices, and sometimes you'll catch a good sale at the office stores.
If you choose to try the focus adjustment, BE VERY CAREFUL!!
1) You have to remove the back of the monitor and work with the power on. Parts inside, especially the picture tube, can give you a very nasty shock AND EVEN KILL YOU.
2) Be very careful where you are putting your fingers when working on a live set. Make sure you have a safe grip on the adjustment knob first, THEN look at the screen while you adjust it. Don't go blindly reaching around.
Aug 31, 2008 | HP Compaq FS7600 17" CRT Monitor
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Monitor Generated Image
Great picture! Big problem! i suggest is time to do a monitor change.
Sep 17, 2007 | ViewSonic VX910 19" LCD Monitor
Blurry Image problem with Mitsubishi WS-55805
Hello, if you want I can supply you with the service manual, please leave your email. Best regards, Arpi
Aug 14, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Blurring of images and text
mt, the 6 to 8 lines you were seeing were most likley the prelude to the end of the monitor. If the problem only occurs when the screen saver comes on then I could say the driver maybe being corrupted by a certain screensaver picture or program. When the monitor warms up to a certain temprature the electronics start to fail. You may want to turn off the monitor while your not right in front of it to cool it down and prolong its use.
Jan 27, 2007 | LaCie Electron 22" CRT Monitor
Computers & Internet Logo
949 people viewed this question
David Payne
David Payne
