Question about PPI PC2600 Car Audio Amplifier
Ppi amp i need a manual for my ppi pc2600.2 amp
    Scholar:
  • 80 Answers
Here is an archive od PPI PowerClass manuals...
http://narbi.free.fr/manuels/Amplis/Precision%20Power/Serie%20Powerclass/
Posted on Jun 12, 2009
4 Suggested Answers
  • 631 Answers
SOURCE: ppi pc2600
If the fuse only blows after the remote voltage is applied, the output transistors are likely shorted. To eliminate the speakers as a possible fault, disconnect the speaker wires from the amp. Also disconnect the signal cables.
If the fuse blows without remote voltage applied, either the power supply transistors are blown or the B+ and ground are reversed (or they may have previously been reversed).
Posted on Oct 17, 2007
XSdB
  • 80 Answers
SOURCE: need owners manual
Here is an archive of PPI PowerClass amp manuals...
  • 8 Answers
SOURCE: ppi pc2600
ebay
Posted on Aug 13, 2009
I have a PPI PCX-2400 and want to power two TREO subs that handle 2500 watts apiece. What is the best way to ire the PPI to these subs so that I get as much power from the amp to the subs without causing...
That would depend on the impedance (resistance) of the subs. Your best bet would be to use the full power of the amp to one channel (i.e. bridged) instead of to two separate channels (i.e. stereo). Two 4 ohm subs wired in parallel would present a 2 ohm load to the amp, which should allow you to get all 1600w out of it.
This explains series vs parallel quite well:
http://www.termpro.com/articles/spkrz.html
Mar 03, 2011 | PPI PCX-2400 Car Audio Amplifier
Tip
LPI, PPI,DPI conversions
Here is a conversion chart for DPI (Dots per inch) to LPI (Lines per inch) or PPI (Pixels per inch)
180 DPI................31 lines/inch or 68 PPI
360 DPI................63 lines/inch or 138 PPI
720 DPI................127 lines/inch or 280 PPI
1440 DPI..............255 lines/inch or 561 PPI
2880 DPI..................510 lines/inch or 1122 PPI
If you plan to enlarge your image, it is better to enlarge it when you're scanning rather than in your application. Each time you modify
an image, you lose some quality. Keep in mind when you enlarge a small photo, such as a 35 mm slide or wallet-size photo, you'll need
to scan at a high enough resolution to retain your image quality, but not so high that your file size is too large to be efficient. You must
manually adjust the resolution (dpi) to maintain the same image quality when you resize your image. For example, if you have a 300
dpi 2 x 2-inch image that you want to enlarge to 4 x 4 (a factor of 200%), increase the Scale setting to 200% or change the resolution to 600 dpi.
on Jul 19, 2008 | Epson Perfection V200 Flatbed Scanner
My ppi 2200 power light flash's on and off
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Feb 03, 2010 | PPI PCX-2200 Car Audio Amplifier
Amp A404
If you are looking for a schematic, I am sorry, but there aren't any. I I have been studying these amps for years, and PPI holds that info very close to chest. It is possible to work on the amps without one though, if you are familiar enough with them. What kind of problem are you having? I have fixed many of them in the past, maybe I can point you in the right direction.
Apr 04, 2009 | Car Audio & Video
How to bridge a ppi amp
The PCX-1500 is a single channel amp, it can't be bridged. I realize that it has two sets of speaker outputs but electrically it only has one output. The connections are actually paralleled inside. Electrically it only has one output. Physically there are just two sets of terminals to allow more convenient connection of 2 speakers. You can use either one or both. If you use both you need to take into account that they're parallel to each other. Connect 4 ohms to each set the amp sees 2 ohms. Like wise with 2 ohms to each set, the amp sees 1 ohm.
Hope this helps.
Mar 29, 2009 | PPI PCX-1500 Car Audio Amplifier
Hi guys i need PDF Manuals for the PPI PC range 1) PC 450 2) PC 250 Thanks for your time :)
Here is an archive of PPI PowerClass manuals
Feb 25, 2009 | PPI Car Audio & Video
Need owners manual
Jan 30, 2008 | PPI PC2600 Car Audio Amplifier
PPI PC1400
Since it's an intermittant problem and a relatively expensive amplifier, you should have it checked by a qualified tech. If you keep trying to power it up, it will eventually blow out the power supply transistors which will add as much as $100 to the repair bill.
Oct 19, 2007 | PPI PC1400 Car Audio Amplifier
Sub hook up to PPI D3000 amp
I'm not familiar with this amplifier but in most cases, if a mono amp has more than one positive speaker terminal and more than one negative speaker terminal, the positives are directly connected and the negatives are directly connected. So  as long as you connect the speaker positive to a positive speaker terminal of the amp and the speaker negative to a negative speaker terminal of the amp, it will work properly.
Oct 12, 2007 | PPI D3000/1 Car Audio Amplifier
Car Audio & Video Logo
213 people viewed this question
Top PPI Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
hoyzee1
Are you a PPI Car Audio and Video Expert? Answer questions, earn points and help others
