Question about Philips 50P8341 50" Rear Projection Television
Tv volume fades in and out
My philips 55p8342 volume fades in and out
  • 934 Answers
The common failure for that symptom is the SSB or small signal board, Philips p/n# PH3912725871 or 313912725871
Bill
Posted on Jan 30, 2008
I need free driver Philips SAA7134 TV Tuner for Windows 7 X86
I have one error message in windows7 need SAA7134.I have honestech TVR .How I can solve this problem.
Nov 28, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Volume fades out then may come back on-Proscan TV Model#PS35690LW
hello,
this will require you opening the back cover of the television.
Check for dry soldering and re solder in the audio section of the printed circuit board....
Good luck...
May 24, 2010 | Televison & Video
Picture fades as tv warms up
impending lamp failure
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Philips Magnavox TP3285C 32" TV
Philips big screen tv
THE PICTURE IS FADED, IT HAS LOST ITS BRIGHTNESS ANG LUSTER. DOES THIS MEAN IT NEEDS NEW BULBS
Oct 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 55P8342 Bow in picture
Replacement IC's suspect...did you use generic ? For all my repairs where originals are STK392-110,120 or 150....I use the
up-grade STK394-160E Mfr by SANYO with Hitachi part number
CZ 01341...they are expensive,but NO RE-CALLS ! Also,did
you check the resistors close to the IC's for over-heat damage ?
...........................................T.
Feb 21, 2008 | Philips 60P8342 60" Rear Projection...
Philips 55p8342 chassis ptv916
To get a new remote call a local TV service company or you can order directly from the manufacture. The cloudiness of your colors are caused by possibility of two things or both: 1) The mirror and lenses inside your TV need cleaning (use window cleaner & soft cloth) spray liquid onto cloth, 2) The fluid in picture tubes need to replaced. To replace fluid (ethylene glycol) take tubes out of unit, drain fluid, clean fluid chamber, add new fluid. How you can tell if fluid is cloudy? Take off screen assembly look into each light (red, green, blue) the picture should be clear. The red tube, light, is normally okay, so use as referance.
Feb 16, 2008 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
204 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
