Question about Tricity Bendix TM310W Electric Dryer
Water tank not filling
The water tank is not filling fully. I drained the resorvoir at the back but after the next cycle water flooded onto the floor.
  • tapsy Feb 21, 2008
    water tank is not filling up and the my dryer is blowing cold air
  • Anonymous Mar 30, 2014
    i have a upright vax carpet cleaner its leaking fron the bottom of the water tank waters just comming straight out onto my carpet can you help
  • 126 Answers
Probably it is lint in the condense pump.
Posted on Jan 30, 2008
How do I drain the water tank
Anon, Make sure gas or breaker(power) is turned off to the Heater so it will not come on during draining,connect a hose onto bottom valve of water heater, run hose to a floor drain and insert, turn your water main off so as not to fill tank while draining, open water heater drain valve, water will then drain from attached hose into floor drain until empty. For water to run faster you may open a near by hot water tap, this will allow air into tank as you drain it, do not forget to turn this tap off before refilling tank. You then can turn main back on for a bit if you would like to do a flush of sediment from the bottom of tank.
See links below for more instruction and video.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Drain Water Heater Today Homeowner
How to drain water heater
http://www.bobvila.com/articles/how-to-drain-a-water-heater/#.VxqJ6NQrJxA
Apr 22, 2016 | Water Water Heaters
Float switch dripping water onto floor while dishwaser running
You will find that the flood switch will be operating due to the leak, it will most likely be from one of 2 places:
1. Around the door seal, Give it a clean and check for splits/damage, and make sure screws on door hinges are tight.
2. Check the rollers that screw onto the inside of the dishwasher cabinet, The screws on these can come loose and cause water to run down into the base, check they are tight.
Hopefully this helps.
Mar 04, 2012 | Dishwashers
Water spills over tank onto floor
check for object in the drain hose going to the water pump or the pump going bad also check drain hose make sure is not blocked
Jul 30, 2009 | Amana Washing Machines
Kenmore series 90 washer keeps filling with water and won't stop during to move on to next cycle
If overfills onto the floor , then the waterlevel switch hose came off the switch behind the control panel . You have to remove the 2 side screws and tilt panel to see the hose and switch . If the water keeps filling , but doesn't go on the floor , then you have a syphon problem at your drain . As it fills , water is being sucked out by your drain due to no air able to get in around the drainhose and drainpipe . Pull drain hose out of drain and only insert about 4-5 inches into drain . If hose is tightly in drain , a parts house or home depot should have a syphon break in stock .
Jul 22, 2009 | Kenmore 22422 Top Load Washer
Ice maker water line doesnt shut off
If the icemaker did not stop right in the spot where the water fills the tray, without completing the cycle, you have an icemaker problem, but that is highly unlikely. More likely is that the water fill valve (the part right where the water line hooks onto the refrigerator) will have to be replaced.
Jul 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
If I do a small load after a large load, on the rinse cycle teh water gushed up through the drain in the floor and floods the floor. The plumber snaked 50 feet twice and poured down acid and it still
Since the plumber snaked 50 feet, one must conclude that the blockage is beyond the 50 foot mark.
Shame on the plumber who stopped at 50 feet. he should have snaked all the way to the street system if you live in a city or to the septic tank if you live in the country.
I would call him back and tell him that he needs to finish the job.
May 21, 2009 | GE WWSE5200B Top Load Washer
Frigidaire Gallery washer is flooding the house
Try turning water faucets off. Does it still flood when done? Does your drain hose empty into stand pipe that is at least 30 inches from floor? Make sure drain hose does not go anymore than a few inches into pipe. If it is pushed too far in, unit can syphon water back into unit.
Nov 22, 2007 | Washing Machines
Tricity Bendix TM310W Electric Dryer Logo
172 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
