Question about HP Single Black Refill Bottles for HP C8727A / C6656AN Inkjet Cartridges Printer
Cartridge Refill (inkject #20 and 21)
How do i Refill my Cartridges, im printing volumes of papers and my ink goes so fast, and Buying new cartridges is expensive.
  • Anonymous Mar 27, 2014
    the ink cartridge dries out very fast after printing
  • 84 Answers
Look here
http://www.refillinstructions.com/
Don't forget to vote
Posted on Jan 30, 2008
Hi, I desperately need immediate help about how I can refill HP deskjet 1050 cartridges printer. Just refilled using syringe needle but the printer won't print and the cartridges ink level is showing...
Your printer will be using either of the foll:
HP 802 Black Ink Cartridge CH563ZZ
HP 802 Small Black Ink Cartridge CH561ZZ
HP 802 Small Tri-color Ink Cartridge CH562ZZ
HP 802 Tri-color Ink Cartridge CH564ZZ
after refill, use a dry tissue paper to wipe the head....(small metal head with 2 lines for ink flow in the bottom of the cartridge)...u also need to clean the small metal dots(15 to 20) on the cartridges...(these dots are for data....trf... connecting the cartridges to the printer....)
keep cleaning till the ink flow is fast and your tissue has lot of ink marks....hold the tissue in one hand (pam) and press the head to the tissue....move the cartridge on the tissue in a manner from say top to bottom of your pam....do this 5 to 6 times till the ink starts to flow smooth....
if the above does not give you the desired result....of clean ink flow....
the other option is to immerse the cartridge head (only) in hot boilling water.....
to do this....
boil water in a bowl....remove bowl from gas stove / microwave....pour the hot water in another bowl(normal temp...it will help you hold the bowl with your hand...just the water will be hot ) and immerse the cartridge head portion in it for some mins...till you can see the ink come out....wait...... and use the above tissue clean process for some time.....re-do the process if you dont see the ink flow...in the tissue....once you note lot of ink in the tissue....wipe the cartridge dry and install in printer and do a test print.....
you can also reset the ink level....give me some tiem and i will let you knwo how do that...
once you can print.....let me know....i will tell you the reset trick....
Reg
Kris
May 07, 2011 | Office Equipment & Supplies
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
Can i refill my ink cartridge in my c6380 hp photosmart or do i need to buy new ones?
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Jan 16, 2010 | HP Photosmart C6380 All-In-One InkJet...
Cyan doesn't print
Have you had a paper jam recently? My only thought might be that a small piece of paper is stuck where the cyan cartridge prints.
Maybe get an air duster spray can, remove all inks and spray inside.
Aug 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Dell a940 error code 50c
From doing my research, I have found that the 50C Error message comes from the cartridge, usually if it has been refilled. If this cartridge is new, please return it to the place of purchase for a new one or a refund.
Here's what happens when you refill the Dell Series 2 ink cartridges. There is a sensor in them that cannot be reset.
Dell ink cartridges can only be purchased at Staples, Walmart or Dell's website.
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
if u have not refilled ur cartridge and u still get this error i suggest u buy a new cartridge.....
good luck
have a nice day
Jul 08, 2009 | Dell Office Equipment & Supplies
Black ink cartridge is leaking and black line is running down back of page
if you do your own refill the ink u are using is of the wrong density, get the right ink
May 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
How to refill hp 818 inkjet cartridge
on 818 hp cartridge five holes are there, which colour ink on which hole i have to put ink on them
Dec 03, 2008 | HP DeskJet F380 All-In-One Printer
Ink cartridge question
Try Soaking the print head in Warm water for about 3 minutes. Dry off the print head with a paper towel. If you don't see any ink on the paper towel, then the print head is clogged and it will be difficult to unclog the cartridge.
If the warm water doesnt work, then next try some Windex with amonia. Only soak the bottom of the cartridge where the ink comes out. Soak the printhead for about 3 minutes, and then try wiping off the bottom again. Press a dry paper towel on the bottom. If there is no ink then it is probably time to get a new cartridge. In the future, always try to refill your cartridge right away as soon as possible so that the ink in the cartridge/print head doesnt get a chance to dry out.
I hope this helped.
Please leave a rating if I have helped you with your question/problem.
Have a good day and good luck.
Mac =)
May 20, 2008 | HP Easy Refill Kit for (HP) Black Inkjet...
HP 57 refill problem
You are doing nothing wrong. The nozzles are clogged. Try taking a clean syringe and put your finger on one of the magenta (red) refill holes. Fill the syringe with air. Put it on the second magenta refill hole and blow the air inside. That should force out the ink that has dried and that is not letting the new ink come out. You might have to do that several times. Sometimes, it can help.
If that doesn't work, go to a refill shop, they should be able to clean the print nozzles on your cartridge, no need to buy new ones.
Feb 12, 2008 | HP Easy Refill Kit for (HP) Black Inkjet...
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
HP Single Black Refill Bottles for HP C8727A / C6656AN Inkjet Cartridges Printer Logo
78 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
