PRINTER WON'T RESPOND
MY PRINTER WON'T WORK WITH MY LAP TOP,JUST WON'T RESPOND EVEN WHEN TRYING TO PRINT A TEST PAGE ,OR CHANGE THE INK CARTRIDGE.I AM USING WINDOWS VISTA BASIC,AND A EPSON STYLUS COLOR 480 SXU,PLEASE HELP
    Genius:
  • 1,601 Answers
Blueleaf, I checked the EPSON website and there are no VISTA drivers on there. Your printer will not work without the proper drivers. I am afraid that you will have to get a new printer. Just being honest...
Posted on Jan 30, 2008
  • 3 more comments
  • Thomas Christopher
    Thomas Christopher Jan 30, 2008
    blueleaf, Please rerate this as FIXYA, as it answered your problem and there is no fix for it.. Thanks.
    Thomas Christopher Feb 02, 2008
    Thomas Christopher Feb 09, 2008
    Thomas Christopher Feb 13, 2008
    please rerate to FIXYA.
    Thanks
    Thomas Christopher Feb 19, 2008
    Did this work for you?
    If so, please rerate to FIXYA.
    Thanks
Canon Pixma 420 won't print after cartridge is replaced
make sure you are using good quality ,correct number cartridge and insert properly?
switch off printer and change data usb cable, then switch on the printer, it will work, again same ,,must be check ink carriage cable is damage?
Apr 20, 2017 | Canon PIXMA MP780 All-In-One InkJet...
How do I make a test page for my printer to check color.
You need to clarify :
1. Your printer cannot print color even though it prints color well from a test page;
2. Your printer cannot print color in a test print page.
If it is the first one, then you have to set it properly in Window Print Configuration page of that printer;
If it is the second one, then you have to check whether you have installed the color ink cartridge properly in the printer. If the color ink cartridge is installed properly, try to replace another new color ink cartridge. Finally it is still not work, then you have to bring back to the repair center.
Jan 19, 2013 | Dell V715w All-in-One Wireless InkJet...
The black ink on my Brother DCP-130C won't print and it's a brand new ink cartridge. I thought it was a defected cartridge so I bought another one, same thing. The other 3 colours print ok though....
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
Sep 08, 2011 | Brother DCP-130C InkJet Printer
My HP Deskjet F380 will only print blank pages. There is plenty of ink left in both cartridges. I've been on the HP help site. It didn't help. It won't photocopy either. It printed the top part...
the body of text of the test page is black ink. From what you describe, the print heads are clogged. Most HPs use cartridges that have the head built in, but if not used for an externded period they can dry up and clog.
Try repeated head cleanings (10 or more) see if any change. If none, try new HP ink cartridges
Jul 12, 2011 | HP DeskJet F380 All-In-One Printer
I have a f4480 hp deskjet. How do you reset settings when you refill the ink (black) cartridge? Because even after injecting the ink, I still get the exclamation mark and orange light. And when even...
Some Hp printers, like Epson, require the cartridge to be reset. There is a chip on the cartridge that needs resetting.
This might work;
Place the HP 60 cartridge on a covered surface so that the metal contacts on the cartridge are facing you. Put tape over the top metal contact in the second column from the left-hand side, making sure the other contacts do not get covered. Put the HP 60 cartridge back into the HP printer. Print a test page when prompted. Take the cartridge out of the printer. Leave the tape on the contact that is already covered and also cover the top contact in the column at the far right, making sure no other contact gets covered in the process. Return the cartridge to the printer again. Print a test page. Remove the cartridge from the printer again, remove the tape from the metal contacts, and return the cartridge to the printer. Print the test page and the printer should read the cartridge as full.
Jun 18, 2017 | HP F4480 All-In-One Printer
New brother laser printer hl-2140 with new ink cartridge . All printed pages are covered with black ink. Slide the cleaner and even change cartidge, but same problem.
Please try to re align the print heads and service the carraige assembly of the printer ( Place where you slot in your cartridge). if it doesnt work then there is a leakage on the ink piping system.
Replace the Ink service station.
Sep 23, 2010 | Brother HL 2140 Laser Printer
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Printer problem with 6210 all in one.
Try to print a self test page from the printer itself, do these:
  1. Press and hold the Cancel and the Color buttons at the same time.
  2. Release both buttons.
  3. The Self Test Report will be printed.
and check if it is the same output, if yes then follow the steps below:
  1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below:
  2. Verify that there is plain white paper in the Input tray.
  3. Press Setup .
  4. Press c00712200.gif or c00712201.gif to select Tools and then press OK .
  5. Press c00712200.gif or c00712201.gif to select Clean Print Cartridge and then press OK . The unit prints a test page.
  6. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again
  1. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step.
  2. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels.
  3. Open HP Solution Center .
  4. Click Settings .
  5. Click Print Settings .
  6. Click Printer Toolbox .
  7. Click the Estimated Ink Levels tab
  • Replace any ink cartridge that is low on ink.
  • If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage.
    1. Open the front of the unit to access the ink cartridges.
    2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process.
    3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them.
  • With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges.
  • Allow the cartridges to dry before reinserting them.
  • Close the unit, and plug the power cord back in.
  • Print a self-test page to check the results. Follow the steps below to print a self-test page.
    1. Press Setup .
    2. Press c00712200.gif or c00712201.gif until Print Report displays and then press OK .
    3. Press c00712200.gif or c00712201.gif until Self-Test Report displays and then press OK . The self-test report prints.
    If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s).
    IF THE SELF TEST REPORT IS CLEAN, THEN TRY TO PRINT FROM ANOTHER SOFTWARE LIKE PAINT, NOTEPAD AND IF THE OUTPUT IS OK THEN THE PROBLEM IS ON THE SOFTWARE THAT YOU ARE USING
    Dec 19, 2007 | HP OfficeJet 6210 All-In-One InkJet...
    Computers & Internet Logo
    101 people viewed this question
    Alun Cox
    David Payne
    David Payne
