Question about Envision EN-7100e 17" Flat Panel LCD Monitor
Want come on
The monitor works great once you get it to turn on after cutting it on and off for 2-4 minutes. What can I do?
  • smashlolo Jan 31, 2008
    I have the same problem. Monitor just started to have difficulty coming starting up and turning on. punch the power button off/on off /on about 30 times and pray... and then it comes on and works great all day.
    Anthing to do to fix?
  • 180 Answers
Thats would something to do with main baord . Try looking for some capacitor which pop up.
Posted on Apr 24, 2008
My riding mower stops moving forward after 30 minutes of cutting it starts right up the blades engage properly and cuts great it will just stop moving
Check under the seat under the battery box there you should find the drive pulleys for the rear end the belt could be worn out and turned inside out causing it to slip or stop pulling once it heats up mine was installed inside out from Lowes when I purchased the mower causing me to replace the belt hope this helps
Sep 16, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Screen goes black for a second or two every few minutes
This indicates the inverter transformer is going or a capacitor issue.
May 08, 2012 | HP LP3065 Monitor
Trouble with my BenQ monitor
You have LCD panel failing issue or it is not getting the proper voltage to the panel. Look at the power supply and logic board section first for failed caps (leaking/bulging tops). check ribbon cable between the logic bd and the LCD panel. If it is vertical stripes, the the T-CON board, part of LCD panel, then you will need new panel.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Service manuals: http://elektrotanya.com/?q=showresult&megnev=benq%20&megnev2=fp71g&kategoria=&kat2=all
May 14, 2010 | BenQ FP71G 17" LCD Monitor
As a general rule, this is a panel failing.
The panel is working for a few minutes until it heats up then begins to breakdown. Blowing air onto it wont help since the area in question is under another panel inside the monitor.
The video control board (inside the monitor that converts signals between your PC and the physical panel) could be failing.
Another source of the problem, though rare, is the capacitors that filter power for the panel's power supply (on the main powerboard) begin to break down and that is enough to cause the issue.
Because this is a BenQ, it may come back to life if you replace any capacitor that looks even remotely suspect & resolder all the main components on the powerboard.
Be warned, there are dangerous voltages stored by the main filter capacitor that can kill even if the monitor has been unplugged for several hours.
Peter
Mar 26, 2010 | BenQ FP71G 17" LCD Monitor
When turn on color is great..after a few minutes turn blue and green
Sounds like the lcd is bad but here is a way to verify that. Hook up a known working monitor to the computer, if the colors stay great after a few minutes then you know the original monitor is good.
If the colors turn blue and green after a few minutes with the working monitor then you know for sure that the video card is bad and the video card would need to be replaced.
Aug 23, 2009 | Vision V1721B (Black) 17 inch LCD Monitor
HP Pavilian external monitor color problem.
The easiest thing would be to check your cable for a bent or loose pin. Next put another external monitor on the laptop. The circuitry to provide video to the laptop screen and the external monitor are separate except that they share a video processor and video memory. There can be bad electronics involved.
Apr 08, 2009 | HP Pavilion dv6000z Notebook
Picture won't stay on.
The problem is with the backlight inverter driver. It thinks that one of the CFL lamps is bad. I fixed mine by opening it up and cutting a track in the inverter board (with the power off!!). But you need to be a bit of a geek to undertake this fix. I you want more details email me at lmann1952@yahoo.com
Jul 24, 2008 | MegaVision Hyvision MV177 17" LCD Monitor
Starts up looking good then in 3 minutes, all hell...
Go to the ViewSonic site and read through their knowledge base on your monitor.
Then once you familiarize yourself with electronics safety by reading through a basics manual once or five times, and once you've got it, open up the monitor cold and/or hot, and find out where they spilled Coca-cola down the back or whatever might be suggested by the ViewSonic knowledge base.  Lather, rinse, repeat; when the monitor acts right, then stop.
Dec 09, 2007 | ViewSonic VA520 15" Flat Panel LCD Monitor
Envision EN-7100e 17" Flat Panel LCD Monitor Logo
Top Envision Computers & Internet Experts
Steve
Dimitar Todorov
Paul Bade
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
