Question about Nokia 6300 Cellular Phone
Nokia 6300 Power on
Hi, A couple of days back my 6300 Nokia phone was working perfect. I usually put the phone in silent mode in office. All of a sudden the screen went blank. Thought the phone got switched off. I try to switch it on , but only the blue light flashes on the sides and dies after some time. Removed the sim, battery and then reconnected them. But didn't work.
  • Anonymous Jan 30, 2008
    Just experienced the same problem with my Nokia 6300. At first the wallpaper was very dark but readable. I turned it off and back on again and now it is totally blank. I have carried out several Google searches but can't find any info.
I had the same problem.
Turns out that it was a firmware issue. Had to have it re-flashed by Carphone Warehouse. I was surprised it was a software issue.
Posted on Feb 18, 2008
Charge battery
Posted on Jan 31, 2008
6ya staff
SOURCE:
Nokia 6300- no ringer/ speakerphone/ music
Welcome to FixYa
First up all Check Profile is in Silent mode/Ringer in Silent.
  • Restore Settings by Entering Phone Code[Default is 12345]
Still Trouble, This seems to your Phone's Buzzer is Damaged.Needs to be changed.After Buzzer change Problem Exist [Need Technical Experience]
  • Check Audio IC
  • Check for Damage/Break in Track or Circuit
Your Problem Is Solved now....Thanks for Contacting FixYa..
Jun 21, 2010 | Nokia 6300 Cellular Phone
How we will put some number on silent. i want to put some incoming call on silent mode. please assist
Depending on the phone model, to program a specific number contained in the phone's contacts for silent mode is usually done by going to the phone's contacts > highlighting the contact > selecting 'View' > selecting 'Edit' > scrolling down and selecting 'Ringer ID' > and selecting 'Silent.'
Each number for Silent Mode must be programmed individually and not all mobile phones have this option.
Incoming calls from phones not already programmed in 'Contacts' cannot be silenced automatically unless all incoming calls are silenced automatically.
Jan 26, 2010 | Nokia 5130 Cellular Phone
Somehow i have turned the silent mode off on my phone, and i have tried everthing to activate the silent mode back on and it doesn't work. can anybody please help me.
or by holding down the # key :) you may have changed the profile itself, so check under profiles > Silent check the settings in there are actually set to silent...
May 08, 2009 | Nokia 6500 Slide Cellular Phone
Cannot turn silent on
press power once then select silent
Nov 06, 2008 | Nokia 6300 Cellular Phone
Nokia 6300
hi, have you tried enter setup then profile then select general this should then set your phone back to normal if not then instead of going to general go to silent and change the settings under the silent profile, like turn ringtone on and select ringtone.
Try the first option first as this is quick and easy failing than then just change the settings under the silent profile then you can even change the name from silent to general then you can change one of the other profiles to silent so try it then get back to me if you need further assistance ok
Apr 25, 2008 | Nokia 6300 Cellular Phone
Nokia 6300
Try reformatting the memory card with a PC and card reader. This could solve your problem. Make sure you back up important data from your card before doing so.
Mar 13, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 (#)-button won't activate SILENT mode
The # key is pressed for 2 seconds to switch your phone from Silent to General profiles. But it seems that on the software version v5 it's disabled. type this to check your version *#0000#
The solution:
Try to "downdate" back to version 4.71 or pressurise Nokia to rectify version 5.
Mar 10, 2008 | Nokia 6300 Cellular Phone
Phone is dead?
my nokia 6300 is dead and it is within warranty period will i get it replaced.
Dec 12, 2007 | Nokia 6300 Cellular Phone
Switching on nokia 6300
Charge the battery,
Battery might have been discharged
Dec 07, 2007 | Nokia 6300 Cellular Phone
Cant get samsung cell model sch-870 of silent mode?
press and hold the pound key it is proven to work
Sep 19, 2007 | Nokia 6233 Cellular Phone
Nokia 6300 Cellular Phone Logo
291 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
ASHRAF CA
ASHRAF CA
