Question about Toshiba Satellite P15-S479 Notebook
Unable to copy file to CD
When I try to copy a file to a CD disc I get a message stateing
"D:\ is not accessible.Incorrect function."I have copied many files in the past and never had this problem.
  • Rick Boyd Feb 01, 2008
    Hi Coldcut.Thanks for your response.I cleaned the lens and rebooted.but I still can't copy.What did change is I started to get a message,"Calculating the time required to copy the file...."When I insert a disk and hit copy I continue to get the message,"D:\is not accessible.Incorrect function."
    The CD/DVD drive was replaced under warranty several months ago.Since then I've played many CD's and DVD's without any problems but this was the first time I tried to copy anything.
    The drive is built into the front of the Laptop;I'm not sure about what you mean by "removable."
    Thanks Again...I'd appreciate any other suggestions...
    Bhrel2
  • Anonymous May 23, 2008
    Same issue! very frustrating. Happens constantly now.
    Genius:
  • 1,554 Answers
Have you rebooted recently.
Be certain that cd can still read disks first.
clean the lens.
If the cd drive is removable , power off and reseat it. look for the lock s for it on bottom.
Posted on Jan 30, 2008
  • Karl Whisenand
    Karl Whisenand Feb 01, 2008
    Try making a data disk using another program that they may have given you like nero or Roxio
    I assume that is still can see and play CD's
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
TROUBLESHOOTING
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Unable to Boot
I think you burn into CD\DVD is incorrect. Recopy any Software is OK using ISO, but to find out that your burn that into proper ISO also, It will not work. To burn is again is extracted from ISO back to Bootable Windows Vista DVD.
Here is a a tip, use another program like Nero to burn into image, the file is .NRG or .ISO...
Or for easy tip, try COPY DISC for assurance that it will run again as is.
Sep 13, 2009 | Computers & Internet
PC can't read a blank CD
try using a different brand of the blank cd. some computers wont recognize some brands
Jan 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
Earsing a disk so i can copy over it how do i do this
U NEED CD-RW DISC TO ERASE AND REWRITE IF THE DISC READS CD-R IT WON'T REWRITE, U CAN NORMALLY JUST DELETE THE FILE OR REFORMAT THE DISK WITH THE WINDOWS FORMAT FUNCTION, USE UR HELP AND SUPPORT FOR HOW TO ACCESS THIS FEATURE.DEPENDING ON HOW U R TRYING TO ADD SOME APPLICATION ADD INFORMATION IN OPEN /CLOSE SESSION WHICH MEANS AFTER THE APPLICATION CLOSES ONLY IT CAN ACCESS THE INFORMATION
Aug 10, 2008 | KHypermedia (2826000000) 100 Pack 52x CD-R...
Dvd
dear,
u need SUPER drive for this. b'coz if u have COMBO or Writer then it can copy only the CD not DVD.
regards,
need ur rating.
Jul 25, 2008 | Dell Dimension 3000 PC Desktop
Toshiba satellite pro ... need to know how to get it to get online to a wireless internet system. I know have ir configured for dial up.
I cannot seem to copy a file to my CD drive on my Toshiba Satellite Pro - I keep getting the message D:/is not accessible Incorrect Function. What is the deal? Can anyone help?
May 06, 2008 | Computers & Internet
The hard disk in drive D: is not accessible
My Toshiba lap top when i try and copy pictures to a disc it will not let me it says D:/is not accessable.incorrect function
I also tried downloading pictures from a cd and it would not read it though it did read a pdf file for documents on another disc
Mar 02, 2008 | Samsung Super-WriteMaster SE-S164L DVD?RW...
D:\is not accessible incorrect function
- Please try this ... http://support.microsoft.com/default.aspx?scid=kb;EN-US;315350 Please revert back with the results
Apr 06, 2007 | Dell Dimension 8200 PC Desktop
Toshiba Satellite P15-S479 Notebook Logo
109 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
