Hi I have a NETGEAR wireless ADSL router
Working correctly with three wired computers and the wireless light is on
I have a Toshiba TE 2100 laptop which I am trying to connect wireless to the netgear router
I cannot seem to get it connected
Any sugguestions
Thks
Heather
I have a laptop toshiba te2100 and my laptop dsnt read theres wireless cause i just formatted it got all the drivers except 4 wireless and wen i tried to put the driver the computer dsnt exept it and in device manager it dsnt even say there wire less but i opened the wifii card and its there plz help
I have no answer as I have a laptop that I cant even get the switch to move and stay when I try to get the wireless lan light to come on.
Go to the control panel. Open wireless connection wizard and configure it by giving the proxy setting of the router. There must be a DNS server to get you connected with the Domain.
First your os xp or vista
if u xp means go to network connection and see that tab, wireless network wizard and click next to open to next to next and click finish. It will appear in network connection windows. But u want to take airtel broad band wireless net key, and u open the tab if u finish ur network wizard tab. And it will open the icon it ask for key, u give it key to continue. It will ready to access the network, so this is the way
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
More detailed troubleshooting steps:
Does your computer 'see' the network?
Does it see the signal? If it does are you pulling a valid IP address (192.168.X.X)? Also known as connected, no surf.
Check your Internet connection with a another computer.
Check for firewalls or security software.
Are parental controls turned on (controled through your browser or firewall)?
Check your browser.
Try to completely re-move and re-create the connection.
The computer 'sees' the signal but does not pull a valid IP address.
Are the WEP Key and SSID entered correctly?
Are you using connection profile software?
Check the adaptor Configuration.
Up-date the adaptor drivers.
Check the adaptor.
The computer does not 'see' the signal at all.
Try from differant locations in the park.
Check the adaptor.
If you went through the steps above and still having trouble, chances are good the Computer Guys Live need to remotely fix your computer and we would be happy to chat live online athttp://computerguyslive.com
or call our tollfree number 866-300-8181 to speak to a live tech now!.
Good Luck
i have the wireless signal on the netgear router but not on the laptop
i cannot seem to get the wireless setup to do anything
Hi priyabrat
I still cannot get this laptop to connect wireless
it goes through the network wizzard and nothing
the wireless light never comes on
I have tried everything to no avail
hi i just want to know how to turn on the wireless connection for toshiba 2080. i already configured it and I was using it for months now
i was about to choose the network list to connect but
then a wireless connection message appeared on my laptop saying that the wireless switch connection must be turned on before i can connect.
how can i resolve this? i already press the function key and F8 (wirelss key) but still i can't connect to the wireless network. i've tried it in all place with wireless internet but nothing happnes. i also tried to check and used the troubleshooting, repair options, etc.
hi,
this is surbhi.I still cannot get this laptop to connect wireless
when connecting what problem ti giving
for the toshiba te2100 it actually doesnt come with wifi installed it comes with lan connection it is wifi upgradable i had this same issue bought it thinking it would be wifi ready but sadly i had to buy a card for it
i was working ok on work wireless now cant connect
