Question about T-Mobile Sidekick® 3 Cellular Phone
Swivel doesn't shut. black piece in the way?
For some reason my screen is stuck in the swiveling position. It's neither open/up or shut/down. and there is a little black tab that's blocking the screen from shutting or opening entirely. This tab was never in the way before and it seems like it can recess but I can't seem to get it down. Any solutions?
  • ricky3fly May 11, 2010
    same prob,
  • 31 Answers
I believe its the flex cable, you''d have to ask expert(if you arent familiar with the sidekick) and loosen you flex cable. I bieleve it tightens wen it tries to flip. If its not that, comment baq with more detail
Posted on Feb 03, 2008
6ya staff
SOURCE:
Toyota Corolla 2006,idle at 1200 rpm,which is to high,should idle at 750 rpm,what could be the problem?
Check out where the throttle cable is mounted to the carburettor swivel, which opens and closes the throttle. With the engine running see if the swivel can be turned back to the stop position.This is an adjustable screw, typically with spring around the thread to resist undoing.
If the swivel is already back to the stop. its a simple repair to turn the stop screw back to allow the swivel to close the throttle more.
Sometimes the cable prevents the throttle from fully closing and the reason has to be investigated. Such as
weakened return spring or inner cable requires some lubrication.
Oct 12, 2017 | Toyota Cars & Trucks
I have a Craig portable DVD/CD player. It stopped playing sound. What's wrong? Not on mute.
Craig 9-Inch TFT Swivel Portable DVD/CD Player with Remote
www.amazon.com/Craig-9...Portable.../B007S71NHM
Amazon.com, Inc.
Rating: 3.3 - ‎58 reviews
Amazon.com: Craig 9-Inch TFT Swivel Portable DVD/CD Player with Remote, Black ... But keep in mind this player does not provide the highest quality in portable DVD players one can find. .... The remote stopped working within a few weeks.
Craig 10" LCD Portable DVD Player with Swivel Screen and ...
www.qvc.com/Craig-10-LCD-Portable-DVD-Player-with-Swivel-Sc...
QVCThis 10" portable DVD player from Craig comes with everything you need to help keep ... Plays DVD, CD, CD-R/-RW, JPEG; 10.1" diagonal TFT display; swivel screen design..... Couldn't start DVD unless I held down the door or it would stop.
Craig CTFT716N 7" TFT Swivel Screen Portable DVD/CD ...
www.walmart.com/.../Craig...Portable-DVD-CD-Player.../33846...
Walmart
Rating: 3.5 - ‎18 votes - ‎$59.78 - ‎In stock
Buy Craig CTFT716N 7" TFT Swivel Screen Portable DVD/CD Player with Remote Control at ... I had one of these portable dvd players but paid over $100.00.
Dec 28, 2015 | Craig Televison & Video
Easiest way to attach spring to the back wheel base?
As long as the black piece still has the "nubs" on both sides at the turn in the "L" shape and the base isn't broke then this is going to be easy. There is a groove on the main unit the little wheel fits into that groove, the "nubs" fit into small holes on the swivel down piece, and the spring fits between the small side of the "L" shape and the bottom of the swivel down piece..
May 26, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
What is a "memory swivel"?
A memory swivel (or return swivel) is a type of bar stool that swivels but then returns to the original position once a person gets up. Most memory swivel stools only rotate 180 degrees.
Jul 24, 2012 | Furniture
Hi, We can not get our TV to swivel. What to we
U have to litterly turn the tv 20 degrees to the left or to the right.If u wanted the tv move to the left or the tv move to the right.The base stand dose not move,it is a solid base stand to hold the tv in with screws.Some tv u can swivels,but only can do it up and down by 20 degrees screen base swivels that it.Take a hold tight of the LCD screen panel and push it up or down 20 degree,that is ur base swivels.
Nov 15, 2010 | LG 37LG30 37 in. LCD HDTV
Front wheel wont swivel
check for missing bearings in the swivel section
loose or worn shaft
replace the front wheel swivel unit
May 07, 2017 | Phil & Teds E3 Twin Seat Jogger
Release spring popped off when dumping the cannister.
Apr 16, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Black bakelite swivel piece shattered.
NO PARTS MADE , rebaged cheep made unit from china . call home shopping and tell them , it broke , not that you dropped it . you might get a discount or something , your not the only one with problems with this waffle maker !
Jan 26, 2009 | Wolfgang Puck Rotating Waffle Baker -...
Gateway CX2620 Swivel Screen Laptop
This is the worst solution I've ever heard. This guy is trying to steer you wrong I'm pretty sure. There is zero point in removing all the screws from under the batter/ zero point to removing the area around the power button. Absolute BS. The only part to remove is the part just above the top of the keyboard (silver strip with some black). Then by removing that you can pry the swivel black plastic cover off. Whatever you do.. do not follow Scott's writeup here. I'm telling you. It's sad it's stayed up so long.. so had to warn.
Dec 10, 2008 | Gateway Convertible CX2620 Notebook
T-Mobile Sidekick® 3 Cellular Phone Logo
Top T-Mobile Cell Phones Experts
Ekse
Trimesh
Damen Wong
Damen Wong
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
