Question about Samsung HP-R4252 42 in. Plasma HDTV
Hp r4252 white vertical stripe on left side, 5 in wide
Seems everyone is having a problem with a black stripe....mine is white. any chance it might be a fixable glitch? found the tv on the street....and i changed it to the 4;3 aspect ratio so the stripe doesent cut out any picture.....but i figured id ask........
  • Anonymous Mar 23, 2014
    wide white verticle stripe
Is there any way to disable the light going to that part of the screen? ie: make the stripe black instead of white?
Posted on Feb 02, 2008
    Champion:
  • 206 Answers
Well sound as if a segment or Ic driver has failed on the panel. And a 42 inch replacment panel can run you $1250.00
Posted on Jan 30, 2008
My hp vs 15 displays vertical color stripes that alternate different colors wether its hooked up tp computer or not what is wrong, is it junk
It may sound strange but be absolutely sure the cable is plugged into the monitor. Adapter on the computer. The serial adapter on the back looks just like video. Video actually has a faintly noticeable monitor icon rigtht next to it. Plugging into a serial can eventually blow out your monitor. Also, a.badcable can do the same thing. And if you have messed up the monitor's settings you will see the same
Apr 13, 2012 | HP vs15 15"LCD Flat Panel Monitor
Panasonic TC-P42S2 .. Transparent 2 inch wide vertical discoloration on panasonic 42 inch plasma, very left of the screen.
Fixed mine, myself! Black 3 inch vertical band (stripe) appeared after a cros country move on our PC-T50G10. Occasionally we would see white band with multicolored pixel width stripes. Took the risk of taking off the back to see if I could see anything. Found places on sides and bottoms where plastic like 2" flat cables could be seen. Guesstimated where the band was and found that I could flip down a black cover on one end of the cable. Tried to pull it, gently. Mistake. Realized it wouldn't one out like computer hard drive cables, so I took out the screws holding the plate on the other end (it's only an inch long). That allowed me remove the cable. Took it out, cleared away dust, put t back and closed the black over. It worked! Put the screws back in, back on and... we are happy (although I do have four extra screws!). Just be gentle.
Feb 17, 2012 | Panasonic TH-42PD50U 42 in. Plasma EDTV
I have a permanent dark/black 4.5" wide vertical line on left side of plasma TV. It seems as if it is 4:3 display mode on left side only. Any help would greatly be appreciated. I have no problem changing...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER .
BUT IF OTHERWISE CHECK
x driver cables 10 ohm resistors have loose connections
Hope this will help...
Jun 14, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Bottom half of screen is black
its ur diaplay problem.. go for a change of new display...
Jun 30, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Right half of screen is Black with a White vertical stripe
Yeah, I have this exact same problem, except my mom slammed my laptop shut in frustration around half an hour ago, so that's why it's like this. The right half of my screen is black with two colorful stripes (mostly white), but the left half is visible. I've researched a bit and found out that this is because the LCD in your monitor has burnt out, and since you don't have a monitor to attach, the only thing you can do is to go to where you bought the laptop and either get it fixed for free or return it for a brand new one (if your warranty still stands). If not, you might as well get a new laptop. I think my warranty has expired, so I'll get a new laptop, hopefully.
Hope this helps!
~Sam.
Jun 08, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
Black 3-4 inch wide Stripe
this problem is a bad panel it needs to be replaced in some cases the panel is under warranty. check your warranty.
also the E and F buffers could be at fault I would have these replaced first.
Oct 14, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung HP-R4252 42 in. Plasma HDTV Logo
462 people viewed this question
Jerry Greenberg
Jerry Greenberg
