LG V782W Combo DVD/Video Player - DVD won't eject
Hi could you suggest something to help with a dvd won't eject from my LG V782W Combo DVD/Video Player. The is no error code displayed. The Disk Loaded symbol is flashing.
I have referred to the user manual but had no luck.
Any help would be appreciated.
Thanks.
Nicole.
  • Anonymous Feb 02, 2008
    Have the same problem!
    My LG Combo DVD/VCR won't eject DVD ...
    Please help
    email solution to: yabani@qualitynet.net
  • debracarney Nov 02, 2008
    Sanyo disk player
Try ejecting while the dvd is playing or idling on the menu, mine will not eject from Pause or Stop modes.
Posted on Mar 06, 2013
I had the same problem with my LG DV7711P dvd player. Everything worked on the front panel but when I pushed eject nothing happened. From reading other forums there should be a manual eject button on some dvd players, which you can activate using an unrolled paper clip. My dvd player doesn't seem to have one so I pulled off the outer case and opened the drive manually-- this was surprisingly easy. There is a small rubber band ("drive belt") inside the dvd drive (mine is just below the tray as it ejects), which can stretch over time, and this causes your dvd to have the problem you are describing as an over-stretched belt doesn't provide enough tension to open the tray. You can apparently replace this belt cheaply at an electronics store, but after pulling my drive to pieces and manually opening and closing the tray a couple of times, mine seems to work fine again. It's easier than it sounds, give it a go (obviously unplug your dvd player completely first!!)
Posted on Jun 05, 2010
Hi
I am trying to set up my LG V782W but have lost my user manual.
Can you help. I need to know how to tune channels and program to record.
thanks
steve
Posted on Jul 20, 2008
DVD player won't eject and an u99 error code is displayed.
Hello
It is an internal circuit problem.
The unit fails to operate properly. Press [POWER] on the main unit to switch the unit to
standby. Now press [POWER] on the main unit again to turn the unit on.
OK
Jun 10, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
I have an LG v271 dvd/video combo player and it will not read any dvds.It just goes to a disc error then ejects it out straight away. can u help
hi,
ur dvds laser pickup unit may be faulty. first of all just clean the laser pickup unit using an ear bud. do not use any chemicals. clean only with bud. after cleaning just insert a disk and check whether is reading. if not u have to replace the laser pickup unit.
ok
Dec 13, 2010 | LG Televison & Video
Cant eject DVD's
Unplug the player and leave it off for an hour then plug it and press EJECT or OPEN/CLOSE continously until it releases the disk.
Jul 10, 2009 | LG V271 DVD Player/VCR
GoVideo DVD combo
Hi - I can record a dvd from the tv and can play it back but when I try to play a store purchased dvd it ejects the dvd and on the tv screen it says unknown disk, please, check disk again.
Aug 19, 2008 | GoVideo Go Video DVD/VCR Combo
Can I upgrade an LG v782w combo DVD/VHS unit to play DivX Discs?
Turn on the DVD player with no disk, wait until the 'no disk' label pops up then press
1. 'Pause'
2. '1'
3. '4'
4. '7'
5. '2'
if That Don"t Work Im Out Of Options
Jul 07, 2008 | Televison & Video
Go Video VR 1940 DVD Recorder + VCR - DVD disk will not eject from slot on top of flat screen TV
My sugestion is to open the dvd player cover, then after you remove it the disc cover you screw out it to remove your disc.
Apr 24, 2008 | GoVideo Go Video DVD/VCR Combo
DVD tray will not open
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Feb 25, 2008 | Dual Presidian DVD Recorder
DVD er Help
Broadcasting
Video : PAL I, B/G, I/ISECAM D/K, K1
That information is posted on LG Australia's
website that you hyperlinked to. It won't play
NTSC video because the region coding is
different - on PAL video is supported.
Sorry to be the bearer of bad news :P
Hope this helps,
Justin
Feb 19, 2008 | Televison & Video
LG V8824
the small 12 tooth gear on top of the slide motor could have a crack in it , this will lock the slide from working
Sep 21, 2007 | Sony SLV-D350P DVD Player/VCR
Televison & Video Logo
1,425 people viewed this question
Top Televison & Video Experts
