Question about KitchenAid KCMS145J Microwave Oven
Fuse location on a KitchenAid Microwave
Where do I find the fuse on my KitchenAid KCMS145JSS Microwave?
  • rickvalicent Feb 14, 2009
    the start and stop button along with the timer/clock are not working, however, the light is still on. is there a reset button and if so where?
My kitchenaid microwave oven does not heat anymore
everything else works but it will not warm anything up
Posted on Aug 06, 2011
  • 579 Answers
To check the internal fuse. Unplug the oven, unscrew and take off the cover, the fuse should be easily found in the back by the power cord. It looks like a regular fuse but is white instead of clear glass because microwave fuses are special. You'll have to measure it for continuity with a meter as a result and be sure to replace it with the same kind. (try finding them at radio shack) Hopefully there isn't something more serious also.
Hope ya fix it!
Posted on Jan 30, 2008
I have a Kitchenaid microwave model KCMS145JSS-0. It is no longer heating. What can I do to repair it?
Check the door safety interlock safety switches for proper operation. You will find them inside the cabinet.
If they have failed, the oven thinks the door is open and therefore will not turn on the heat. This is the most common reason for failure.
May 30, 2011 | Microwave Ovens
I have a microwave model #kcms145jss-o. everything works on it, but it will not heat. Thanks Ray
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 30, 2010 | KitchenAid Microwave Ovens
Where is the fuse located on a kitchaid microwave khms155l
It is located behind the key panel. UNPLUG THE UNIT FIRST.
Remove top grill (2 sinked screws on top)
Now remove the single screw on top of the key panel. Barefully slide out the keypad up and out. The smart people of kitchenaid put the dang fuse jammed between the fan housing and the right wall. Remove the entire bottom plate that holds the lights and such... I think 8 screws. Now remove 2 screws that hold down the fan housing. Now you going to have to use a screw driver and some wiggling to move the plastic housing out of the way enough to pop and slide out the fuse and replace. To test you can use a continuity tester and place it between the fuse. There is nothing visible on this fuse (250Volt 20A fuse Fast Acting I think) e.g. you can't see that the fuse is broken or not. Make sure no wires are pinched while putting it all back.
Dec 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
When I turn on the micowave; smell somthing burning
The magnetron (the part that heats the food) may be ready to burn out. If you smell the burning, you should then unplug the microwave, open it up and see if you can determine for sure that it is coming from that part. Unfortunately even if I am right, it is almost more cost effective to just replace the microwave rather than replace that part. You can run this microwave till it dies if you want, but I would be ready with a new one.
Let me know how this works out for you.
Benjamin
Apr 29, 2010 | KitchenAid KCMS145J Microwave Oven
KitchenAid KCM2145JSS-1 built-in Doesn't Heat
Everything working is a real good sign. Most likely all thats wrong with your unit is a blown fuse. Go to http://www.partselect.com/MultiModels.aspx?ModelNum=kcms145j&SearchTerm=fuse&RefineSearch=0 and you will find the fuse. It's behind the touch pad with most all the other workings. Very easy to replace and cost only $11.76. It looks like an old round glass car fuse but it's made just for micro waves. It's most likely a 20 amp fuse. To get to it, take all the screws out from the back that hols the case on. once you have removed the case you will be able to locate the fuse. Good luck.
Dec 19, 2009 | KitchenAid KCMS145J Microwave Oven
I have a Kichenaid microwave Model # KCMS145JSS-1 No lights, no readout, completly dead. Power source checked and o.k. Any thoughts?
I would suspect the fuse, the magnetron's thermal cutout / thermostat, or the oven cavity thermal cutout / thermostat.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here (just enter your model number).
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Kitchenaid owner's manuals and installation instructions here.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Aug 07, 2009 | KitchenAid Microwave Ovens
The microwave went blank without power. Is there a fuse and if so how can I replace it?
check the fuse inside the unit, open the cover and locate the fuse, it is usually inline with the power cord. and the HV line.
Jun 12, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Broken Microwaive Door
I'm assuming your correct model number is KCMS145JSS? You have a broken "release lever", part number AP3033332. It's reference number 7 on the exploded view diagram found here: http://www.appliancepartspros.com/sect/4/g/4/4g4rya32jj.gif You can order it by part number from Appliance Parts Pros here: http://tinyurl.com/gv383 If needed, you can download the owner's manual and installation guide here: http://www.kitchenaid.com/custserv/literature_search_results.jsp?searchTerm=kcms145jss If you need further help, please follow up. I appreciate your rating of this answer.
Nov 17, 2006 | KitchenAid KCMS145J Microwave Oven
KitchenAid KCMS145J Microwave Oven Logo
2,702 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
