Question about JVC AV-21meu 21" TV
JVC TV JVC AV-21FMG3B TV HAVE DRAK SCREEN AND I CANT HARDLY SEE THE PIC AT ALL CAN YOU HELP
  • shavarn young Jan 30, 2008
    TV IS ONLY 3 YEARS OLD
  • magnoliamari Jan 19, 2009
    When watching movies with night scenes or some channels they are so dark you can hardly see the people or set props. Tried all the usual adjustments and they do not help. I have the bright and tint turned up to see all of the channels. (On standard you can hardly see any of the channels/scenes)
    MODEL JVC AV-27320
  • 579 Answers
How old is this TV?
As Tv's age, the high-voltage suffers and they get darker. You can turn up the screen adjustment on the flyback transformer and buy some time but:
My experiance is to not put money into a TV that is over ten years old. TVs stress out their electronic components worse than almost any other electronic product. After 10 years, there are so many parts that are ready to fail that your are probably wasting your money trying to get any more life out of it.
Another option is to wholesale replace the main board from an outfit like Module Exchange at 972-298-1212
Be careful on buying a new one though. Often times, these new technology ones are much worse. Always Google the model number of the set you intend to buy and add the word 'repair' or 'complaint' to see if it is one of the many models that are customer service nightmares being produced by even the most reputable companies today.
Hope ya fix it!
Posted on Jan 30, 2008
6ya staff
SOURCE:
JVC AV21AT NO SOUND PIC OK
Hi ,
Check problem is in AV mode only or both AV and RF
If both mode problem is there follow the bellow
Other wise problem May RCA cable (AV cable)
I f you are able to open TV check speaker using a Multimeter (Tv should be OFF) continuity mode,is it shows 2 ohms or below speaker is ok, problem may be audio section of your TV.
Thank you
Apr 22, 2014 | JVC Televison & Video
JVC Modle HD-61FN97 2006 65 inch tv light went out replaced it now can not adj brightness
Aside from the customer controls you might be able to turn the screen controls up a bit to get more brightness, they are on a black block inside the set.
Nov 29, 2012 | JVC AV-65WP55 65" Rear Projection...
Tv went boom
it sounds like the display may have finally gone out, however i would recommend to check other inputs (AV1, AV2, etc) by connecting a dvd player or game console. it may just be the one input that you have your cable box or coax cable connected to, so testing the other inputs will help determine this. if you get the situation with all inputs, no video but sound works, then you will either need to have your tv repaired or replaced.
Jun 05, 2008 | JVC AV-32260 32" TV
Tv trouble shooting
1)Check secondary fuse devices. 2)Check horiz output xistor=shorted? 3)replace w/equiv.or better part. 4)Check solder connects in horiz drive circuit. Replace small electrolytic filter cap in base circuit of horiz o/p==horiz drive xformer and xistor area,typically 1mf/160v,C531? 2b)not shorted==do step 4 anyway 5)still blinking?==check vert o/p,audio o/p and regulated o/p's
Oct 02, 2007 | JVC AV-A21M3U 21" TV
JVC AV-28GT1SJF
you have to get into the tv to do the adjustment. take the cover off and then look for the CRT tube and follow the yoke cables that will lead you to the printed circuit. you should see some small tiny knobs there. something like vertical phase or horizantl Phase..you need the verital to adjust the vertical size of the pic..good luck
Feb 24, 2007 | JVC AV-28-BD-5-Bl 28" TV
News ticker off bottom of screen, how to adjust?
sounds like its stretched out just a bit. Do you feel comfortable with messing around inside where theres 100s of volts??? if you do then in the vert curcuit theres a small control called the vert height control right on the printed curcuit board. adjust it slightly so you can see that full pic but not the black partm of the pic. I WOULD HIGHLY RECOMEND thaT if you have no experience with this then leave it to a pro as afterv all they will charge you a minumum beanch charge to adjust the set for you Im sure as it is a minor thing to do. good Luck
May 02, 2006 | JVC AV-30W475 30" TV
Televison & Video Logo
106 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
