Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Nothing comes up on PC
I plug it in and the red light goes on but the computer seems not 2 recognize that its plugged into the usb drive as if its not there ?!!! i hope its only the computer and not the cruzer!!!
  • mendymish Jan 30, 2008
    didn't work!! it seems alot more severe than simple solutions!!! thanx anyway!!!
  • Anonymous Feb 01, 2008
    Same thing
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 74 Answers
Put into USB. Open up my computer and click on c: and "arrow back" until you see "removable divice". This is your removable USB disk. Let me know what happens.
Posted on Jan 30, 2008
  • Cynthia Charczenko
    Cynthia Charczenko Jan 30, 2008
    Really I had the same problem. Keep trying back and forth my computer to c drive and it may appear. It worked with my cruzer. Otherwise I recommed returning it for a new one. It seems like there are a lot of problems with these, but I have mine working. Let me know how it goes.
    Cynthia
How can I make my USB flash drive work again? I asked this question before but I have a Mac, not a PC. no light turns on, nothing comes out in the computer, I have tried it on different computers, i'm...
An USB flash drive is made out of a memory and extremely simple controller chip installed on a tiny board with a connector.
If the drive is completely unresponsive then the chip died. This is terminal, nothing can be done to save it or to recover what was in it.
Aug 11, 2011 | Computers & Internet
When I switch it on, it goes beep and nothing else. My pc does not recognise it in device manager. It has power as the light comes on. It does not seem to be doing anything, no vibration. using correct...
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jul 21, 2011 | Samsung Computers & Internet
I'm having a hard time getting my Flip HD to charge. It is brand new and this is the first time I've had to charge it. Sometimes the red light is on and steady and other times the red light is flashing. ...
I had this charging problem with 2 new Flip Ultra HD cameras...red light flashing..nothing on the screen after plugging in the USB port.
I removed the battery..plugged camera into USB port..pc recognized the camera... installed flipshare software..updated software...plugged battery back in..all good.
Why on earth the book doesn't mention these steps is beyond me.
Oct 11, 2010 | Pure Digital Flip Video Ultra Camcorder
VAIO desktop does not recognize Sandisk flash drive
Most probably you have a drive letter conflict? If so, right click "My computer" choose "Manage" and locate "Disk management" - here, in the middle lower panel, you should be able to find your usb-memory stick, right click it and assign it a drive letter that you're sure is not in use.
Jun 01, 2010 | Sony VAIO PCV-RS720G (027242658103) PC...
Other computers dont recognize my Maxtor OneTouch 4 Mini
Please Make sure you External Hard disk USB cable is working correctly. Your cable is probably having partial contact, so try another cable
May 30, 2009 | Maxtor OneTouch III Mini Edition 120GB...
My camera won't be recognized when it's hooked up...
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
May 17, 2009 | Olympus FE3010 Digital Camera
I plug my seagate into the computer. it turns on but then nothing
Plug one usb into your computer and the other end into the drive.
If the light comes on, all is good. The computer should install the device for you automatically. To access the drive, go to My Computer and double click on the Removable Drive. Now you can transfer files.
Hope this helps
Chris (ziraffa)
Dec 28, 2008 | Seagate Free Agent Go Small 12 GB USB...
Computer won't open program to import
#1. Reboot the computer.
#2. is the light coming on the card reader when you insert the card? If not, the computer is not recognizing the card. Make sure the card reader is plugged into a working USB port and the card is inserted in the correct orientation. If the light is coming on, simply go to "My Computer" and select the drive letter associated with the card.
May 19, 2017 | SanDisk ImageMate 12-in-1 USB 2.0 Card...
Red Light/Blue Light I/O Error
My nx2 is working again after having the "red light/blue light/I/O Error" problem. I just:
1. turned off my computer
2.unplugged the HD,
3. took out the HD from the enclosure and plugged it back into the enclosure,
4.started up my computer without the HD being plugged in
5. after my computer had been on for a minute, I plugged the HD in and my computer recognized it and had the proper mixture of red and blue light coming from the HD, indicating it's working properly.
Aug 26, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
SimpleTech 100GB SimpleDrive portable USB
Sounds like the file system on the disk is now corrupt. You may need to use a recovery programme to get your files back but nothing is for free.
Jun 17, 2017 | SimpleTech 100GB SimpleDrive portable USB...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
167 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
