Question about Canon PowerShot S2 IS Digital Camera
Lens won't extend
I am having a problem when I turn the on my Canon Powershot S3IS camera on. It attempts to release the lens but instead of opening it pops back and forth in the closed position and then I get a message saying "lens error,restart camera". I have done this is each shooting mode and the problem remains the same. I have as well tried changing the batteries in case it is a power probelm but to no avail.
Any suggestions?
  • Jellybeanvn Jan 30, 2008
    Thanks! What would be the safest way to open manually without damaging the camera?
  • 63 Answers
The lens is jammed meaning you are going to have to open it yourself you should onlyhave todo that once and itshould work again
Hope This Helps - Josh
Posted on Jan 30, 2008
  • Josh Howard
    Josh Howard Feb 04, 2008
    Well pretty much you are probably MAYBE going to damage he camera slightly meaning the lens might not close properly every time or something else VERY minor.
    You are going to have to try to make the lens open by turning the camerfa on the you will use your hand to pull it out 'till it stops moving then turn the camera off then back on!
    Hope this helps! - Josh
Canon PowerShot A3100 IS won't turn on
Make sure the battery is installed correctly.Try opening, then closing the cover to the memory card and battery compartment while holding pressure against it until you hear it click closed. Then try to power it up. The camera will not power up if the cover is not properly closed.
Aug 22, 2012 | Canon PowerShot A3100 IS Digital Camera
Lens error says restart camera how to restart canon S3iS camera
Hello
Unfortunately a "lens error" message is not something that you will be able to fix. This error indicates a system failure and requires the camera to be sent in for servicing and repair.
Mar 19, 2011 | Canon PowerShot S3 IS Digital Camera
My canon powershot a590 camera lens is stuck. When I attempt to start my camera I get a message saying Lens Error Restart Camera then the camera immediately powers off.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Feb 07, 2010 | Canon PowerShot S2 IS Digital Camera
Lens will not retract itself.
Since the motor is clearly running, it and the battery are OK.
I fear the mechanism is broken and needs specialist repair (if not too costly)
Dec 10, 2009 | Canon IXUS 960 IS Digital Camera
Canon PowerShot A640 lens problem
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 31, 2009 | Canon PowerShot A640 Digital Camera
I have a Canon Powershot S3IS and I recently purchased a 2x telephoto lens. When I use the telephoto lens and try to extend the distance as far as it will go, the camera shuts off and says lens error...
Did you tell the camera that you are using an external/additional lens? You have to specify it somewhere in the menu, the camera gives you some options (the lens model numbers) and you need to match it with your lens' model number.
Sep 30, 2009 | Canon PowerShot S3 IS Digital Camera
Neither viewfinder will work - nothing appears I have a Canon Powershot S3IS
It could be a stuck shutter. To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 23, 2009 | Canon Cameras
"Lens Error, Restart Camera" Lens stuck open, completely disfunctional! /sadface :(
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 17, 2009 | Canon PowerShot A630 Digital Camera
Canon PowerShot SX100 IS Lens Stuck
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solution is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Oct 14, 2008 | Canon PowerShot SX100 IS Digital Camera
Dead
Have read of same problem from numerous users on the internet. One person said this may be caused by a twisted/jammed lens. Apparently the "telescoping" lens mechanism can sometimes jam due to a drop and/or from dirt that gets in the telescoping hardware. The solution that someone gave that I read about involved telling the user to try to gently twist and/or wiggle the extended lens parts counterclockwise to try to "unjam" them. Of course that would also require having fully charged batteries, etc, before you try that, since from my experience, low battery charge results sometimes in the lens not retracting (or extending) properly also. It's worth a try anyway, since apparently your camera isn't functioning properly anyway now with its lens extended. I have a problem w/my On/Off switch not working properly, and in checking w/the Canon USA website, they wanted a minimum of $87 to "start" to attempt to fix it (whatever the problem is), and required that I pay them that much "up-front", and that I agree to whatever it then would cost in toral. I backed out and went and bought some new cameras instead, since I felt that was way too much to invest in my A70, that's already 5 years old now. Good luck w/your extended lens problem.
Jul 25, 2008 | Canon PowerShot A70 Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
85 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
