2008 Mazda Tribute Logo
Posted on Dec 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Head lights flicker slightly,trans in drive, foot on brake engine at idle.Flickering is like pulsing very rapid every few seconds.Subtle but noticeable.
hmlee390
Level 3:
  • Master 736 Answers
  • Posted on Dec 31, 2009
hmlee390
Master
Level 3:
Answers
736
Questions
Helped
279570
Points
2447
At idle the alternator can just keep up with maximum current demands .. as it regulates on and off you will see a slight change in brightness .. at slightly higher idle speeds that should go away .. if it gets worse then you might check the battery termanal connections (clean) and the alternator brush assembly and belt tension .. when at idle the current thru the brush assembly is maximum and worn burshes may start to arc ... although i would not expect significant brush wear in just a year or so .. so i suspect you are just on the edge of alternator regulation .. everything is on at once so current usage is maximum and alternator output is at its lowest because of the low rpm .. probably not a problem .. just one of those little things that bothers us until we find out what it is ..
Engine will start but shuts off right away,flickering lights of speedometer and other gauges
Could be the battery. Jump it with another car and see if it stops. Ford put the security in the Instrument panel for a few years. This flickering could be the reason in shuts down after a couple seconds.
tip
Brake Lights Dull or Flickering - All Cars
Dull or Dim Brake Light Repair: If your car has a dull or dim brake light it is dangerous to you and other drivers. A dim brake light is a mystery to most people because the bulb is working, just not correctly. First confirm a new and correct brake light bulb has been installed. Next, turn the ignition key to the "on" position and have a helper depress the brake pedal. With the bulb installed touch a grounded test light to the outer bulb holder ring. If the bulb brightness changes the bulb socket ground has high resistance and needs to be repaired or replaced.
Flickering Brake Light Bulb Repair: A flickering brake light bulb can be very distracting and annoying. A brake light flickers because the power or ground is being obstructed momentarily. The most common cause for this condition is a loose fitting bulb socket. To check for this condition remove the brake light bulb in question, while a helper hold their foot on the brake pedal move the bulb around slightly in the socket. If the bulb flickers replace or repair the bulb socket as needed to regain proper brake light bulb operation. If the brake light bulb socket tests ok wiggle the brake light fuse and wiring at the brake light bulb socket, brake light switch and turn signal switch (American cars). If the brake light bulb flickers repair the component or wiring as needed.
Preferred Procedure: Always replace brake light bulbs with manufacturers recommend replacement bulbs. If you cannot find the correct replacement bulb part number consult an auto parts store for additional manufacturer information.
Common Problems
When brake light bulbs are replaced with the incorrect bulb causing no or dim brake light operation
If the brake lights stay on continuously it could mean the brake light switch has failed or an adjustment is needed.
Bought a new alternator due my old one FAILED the test. But, I still have the problem with my head lights flickering & stereo going off then on when I accelerate to go.
Diagnosing Common Automotive Charging System Problems
www.onallcylinders.com/.../diagnosing-some-common-charging-system-...
Sep 18, 2013 - Flickering gauges. ... Problem: The charge indicator light flickers while driving. .... My alternator has been replaced for the third time in 5 months. ... I bought a new regulator but it is still doing the same thing... .... my headlights wont turn on, car runs fine when jumped, battery last for maybe 3 hours, any ideas ...
All lights Flickering/Pulsating only when motor is running ...
www.cadillacforums.com/forums/cadillac-forum/t-221843.html
Feb 11, 2011 - So i have noticed for a while now that all my interior lighting (radio, tach, even ... Installed the battery and have not had issues starting since then. ... So now ipurchased a new alternator "just in case" figuring i would eliminate the .... Interior lights and headlights still seem to pulse/flicker while idling the most, ...
Lights Flickered. Replaced Alternator. Now more flicker? - Camaro ...
www.camarozone.com/.../lights-flickered-replaced-alternator-now-more-...
Apr 22, 2013 - 20 posts - ‎4 authors
MOTOR CUT OUT , OR WONT IDLE AT STOP STREETS OR ROBOTS oIL LIGHTS START FLICKERING AND ENGINE STALLS
if this is happening when the foot is on the brake, then it is possible that the brake booster is leaking air and running the engine too lean.
check by idling without the foot on the brake
OIL LIGHT KEEPS FLICKERING WHILE IDLE
Most likely your sensor is too sensitive and detects the low oil pressure that exists in idle .... you oil pump is not functioning fully and at idle fails to produce the right pressure. Lastly,your idle could be set too low. try increasing the idle slightly (you don't want it too high) and see if that solves the flickering light problem
2005 1.0 kia picanto cel flickering wont start
Try to scan it and retrieve code from check engine light it could cause so many things. You need to start from tehere to reveal code.
My 2006 A8L 4.2 instrument cluster and a few of the front console lights such as parking sensor button, rear shade and headlight switch on the left have been flickering for months. Flickering is rapid...
I have seen this before and found the Dash insert is defective, Go to address 17 and carry out a final control segment test for the dash when the fault occurs also make sure there are no battery management fault codes.
Restriction of functions
The following are deactivated in the event of
active load intervention by the battery and
energy management system:
- Interior lighting
- Sunroof
- Light/humidity sensor
- Interior mirror
Check you ambient in car lighting settings in the mmi user functions for current settings
Park brake uses 58d terminal and the rest use 58s terminal from memory
1helpful
2answers
Start engine and engineine pops for couple of
Have the ABS pump ECM checked (it is separate from the main ECM), try to catch it early. I bought a transmission last year. This is typical 98-02 Rodeo behavior.
10helpful
3answers
Head lights and dash lights flickering on and off while driving
just replaced headlight switch and took care of problem
2answers
2002 hyundai santa fe 2.7 multi misfire number 2and 5 cylinders
OK IS THERE IS ACTUALLY A mis-FIRE THIS VEHICLE SHOULD BE SHAKING DURING IDLE AND ACCELERATION IF IT IS, here is what you do get a noid light this used to check injector pulse. This vehicle will set a misfire code if injector is not functioning efficiently or bad. A noid light is like a test light bulb can be bought at almost any auto store.SART UP VEHICLE AND DISCONNECT THE INJECTOR WIRE TO THE CYLINDER THAT'S mis-FIRING AND CONNECT noid LIKE TO ELECTRICAL PLUG. DO THIS ONE CYLINDER AT A TIME. The nod light should have a steady flickering light/consistent pattern of flickering. If there is Gap/irratic flickering or no flickering BINGO you have found your problem. NO FLICKERING= bad/broken injector wire if not broken BAD COMPUTER/ECU. IF THE FLICKERING IS CONSISTENT /GOOD = BAD INJECTOR..replace injector and solve the misfire problem. However is all the components tested are ALL GOOD. Then the only other SOURCE for a mis-fire is the camshaft sensor that provides reference for injector pulse and the crankshaft sensor provide reference for Spark pulse. JUST ON A LAST NOTE: make sure all oils are getting electrical power to them. Good Luck I know this is alot of info at once. Contact me if you need more help. Thanks fr using FIX YA
Top Mazda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mazda Expert? Answer questions, earn points and help others
