Question about Vulcan GCO2D Gas Single Oven
Problem again with the Vulcan GCO4C
Well I got the new ignition/spark controller board. Installed it. POwered up the oven and everything looked golden. I have spark, I had gas, I had flame, I had heat and then I had er-5 failure again. I have the shell off of the oven and can hear when the onboard regulator shuts off and then restarts intermitently. It does this for a few times and then finally shuts off again and does not re-open, soon after that I get the er-05 code. I have the oven set at 500, so I know it is not reaching that temp. I placed a thermometer inside to see if it was failing at the same temp. It was not, it failed at 350 the first time and then 250 the second. Any suggestions would be greatly appreciated, so far with your help I have gotten the oven to actually begint he process of working, in my book that is a great start. Thanks in advance for the help.
  • thaddeus333 Jan 30, 2008
    Hi and thank you for your suggestions. The ER-05 code is bad ignition. Where would I check the ohms at on the probe, it is attached to the inside of the oven, correct? Please forgive my inexperience, first time doing this. Thanks again.
  • 640 Answers
Hi thaddeus,im the tech you spoke to in the first place.if you remove the bottom panel on the oven you will see screws on the left and right side,open the door and you will see 2 more screws.then pull the panel off.you then have access to the burner.you will see the pilot assembly and 2 wires going to them.the thinner wire that goes to the probe is the flame sense wire.clean that probe up with emory cloth or a fine grit sandpaper.this should do the trick,let me know.
Posted on Feb 02, 2008
    President:
  • 1,314 Answers
I wasnt in on this from the begging but have you changed the safty valve on the burners and what code is er-5 havnt had no experence with vulcan but the regulater dont run the gas the safty valve does and have you checked the probe in the oven at 70 degrees it should be 1200 ohms
Posted on Jan 30, 2008
  • robert samples Jan 30, 2008
    no problem my first time with a vulcan lol the gas safety valve could be considerd to be part of ihe ignition systems it opens off the ignighters yes the probe is in the oven cavity
Single wire igniter that sparks the oven on but flame goes out after a few seconds. Does the igniter control gas valve?
Its the other way around the valve controls the igniter so to speak
GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Mar 23, 2015 | Ovens
What is a pilot generator
Simply put, a pilot generator is a thermopile that generates millivolt power to operate a gas valve.
However, on your convection oven, yours operates on an electronic spark, which is generated by an electronic ignition control module.
Jul 29, 2014 | Vulcan SG4D Gas Single Oven
Turns on but wont ignite
Do you have power to the unit and if you do check the fuse that controls the spark.
Good luck
Will
Jul 29, 2014 | Vulcan Convection Oven - VC44EC-208-1
Pilot light issue
you cannot light the pilot on that oven manually. that oven is eletronic ignition. take off the panel under the doors, turn on the oven, and turn the thermostat to 350.
if you see sparking on both the right and left burners, you and it doesnt light, you need to see if the gas solenoid on the right side of the burner is getting power. if it is and nothing lit relace it.
if it is not, replace the ignition board
Jun 30, 2013 | Ovens
I have no spark to ignite the burner on a Vulcan VC4GD ?
check transformer....... then spark module cable for spark. if none, need spark module
Jan 18, 2013 | Vulcan Ovens
Vulcan convection oven model SG4d-1 will not ignite burners
Gas does not ignite. No spark. No Ignition light is not ON.
1. Shorted electrode on igniter/flame sense.
2. Igniter cable (high voltage) OPEN.
3. Heat relay malfunction.
4. Centrifugal switch in blower motor inoperative.
5. Transformer inoperative.
6. High limit thermostat open.
7. Interconnecting wiring malfunction.
8. Ignition module malfunction.
Sparks but gas does not ignite.
1. Gas solenoid valve off or inoperative.
2. Manual gas valve closed.
3. Gas supply OFF or insufficient gas pressure.
4. Inerconnecting wiring malfunction.
5. Igniton module malfunction.
Feb 23, 2010 | Vulcan Convection Oven - VC44EC-208-1
Vulcan convection oven has pilot lit and fan blows but no ignition. The schematic is too small, grease smeared and partly ripped to be of use. Is a schematic available or is the cause obvious to an...
The list of problems is as long as the one Obama inherited when he took over. Good news though, the most expensive part works, the blower motor! The pilot is established which rules out a gas issue. The two most common problems are, either the temp controller or the infinate switch is bad. Your unit has one or the other but, not both. Controller has several wires leading to it & has a green or tan circuit board on it, infinate switch is a small black or white 2 inch square box with 4 or 5 wires leading to it. Each one of these are mounted thru the front control panel & both have knobs. Temp board around $180, infinate switch around $45. As far as the schematic is concerned, Vulcan was bought by Hobart & they DO NOT give out schematics or service manuals.
Jul 10, 2009 | Vulcan Convection Oven - VC44EC-208-1
Ignition
If you smell gas, then check the ignitor circut first. A spark ignitor usually has a grey or orange wire, leading from the ignitor to the input circut. Try testing the terminal where the ignitor is powered, when the unit should be calling for ignition. If there is ample voltage to the ignitor, but it will not spark, shut off the power and the gas to the appliance and remove the pilot assembly. The ignitor will either unclamp or unscrew from it, and can now be replaced. Check to see if it is properly spaced (which it should be if undisturbed), or if any deposits are on it. Sometimes they can be properly spaced or cleaned to work once again.
- Ian Miller
Apr 11, 2008 | Vulcan Convection Oven - VC44EC-208-1
VulcN MODEL gc04C CONVECTION OVEN WON;T IGNITE ER-05 CODE
Like an electronic igniter for a gas grill? I believe you can pick up a replacement. Call Lowes or Homedepot. I know i have saw individual igniter's before my friends bought some for my friend and I when we were little to make potato cannons.
Jan 22, 2008 | Vulcan GCO2D Gas Single Oven
Why won't my oven ignite? Vulcan model GC04c
i can get you the error code but dont have my manual at the time.a couple things to check.do you here the clicking sound of the ignitor that ignites the gas?when you installed the regulator are you sure its on right?you should see an arrow on the regulator body and it should be pointing to the oven.also you need 10 inches of water colum (gas pressure)with a propane system where as natural you need less,regardless ill be in touch.
Jan 16, 2008 | Vulcan Convection Oven - VC44EC-208-1
Vulcan GCO2D Gas Single Oven Logo
174 people viewed this question
Top Vulcan Ovens Experts
John Tripp
John Tripp
Treefrog15
Treefrog15
Are you a Vulcan Oven Expert? Answer questions, earn points and help others
