Home Theater Speakers and Subwoofers
Problem for Home Theater Speakers and Subwoofers
Generic problem for all Home Theater Speakers and Sub...
Wharfedale 9.5 Diamond Front Speaker
By kznrob on Jan 30, 2008
My front left speaker seems to be softer than the right. Playing any movie , music I notice the right speaker is audibally louder. At an earshot from the left speaker it sounds like the mid-range intermittently "stutters and splutters". The signal comes thru broken , disappears for 1-2 seconds and the re-appears. After I give the volume a bit of a crank it "pops" and plays okay for a while and then over time it goes back to its "spluttering." The problem is intermittent , but frustrating. I have the speaker cable connected to the HF binding posts and have recently changed the cable for a better quality. It is bound correctly as well as the banana plugs in the amp are fine. After leaving it overnight and playing it the next morning , I notice the same spluttering until I rev the amp again. Please advise!
Same Problem
Aug 30, 2008
-   The problem is exactly the same as described in every detail. It is the same speaker and I could not have put the problem down more accurately.-   Guest
Solution #1
posted on Jan 30, 2008
Not Rated)
robotek
Rank: Guru
Rating: 91%, 1166 votes
you have a poor connection somewhere in your signal path. This sort f problem could be anywhere from inside the speaker box to the output stages of the amp. speaker protection relay in the amp, or even a noisy vol control or dry solder joints in the output stages of the amp. eliminate anything external to the amp by swapping right for left and test, spray the speaker protection relay in the amp with 2-26 or burnish the contacts with a piece of white business card cut to fit into the contacts. You will see deposits on the card that you have cleaned from the contacts. Carefully inspect the soldering about the output stages(heatsink area) and re-solder any poor or cracked solder joints. Good luck... these are the most common problems. I can go further in if the problem remains after you have done this. Good luck
Was this helpful?
Yes
No
Popular Solutions for Home Theater Speakers and
Questions and Unsolved Problems for Home Theater Speakers and
Answer
are the 607 jamo speakers much better than the 605jamo
Answer
I need to buy a replacement woofer for my home stereo speakers - It is a 15" woofer for a... (More)
Answer
jbl subwoofer tlx ps10 only makes a very loud humming noise everytime i plug it in
Answer
Orderd a Mackie swa 1801 7 months ago the dealer says mackie is slow in producing &... (More)
Answer
My son has just returned a pair of tannoy 605 speakers that have been unused for 10 months and now... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Home Theater Speakers and...:
Top Home Theater Spe... Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Home Theater Spe... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
