Question about Ovens
Oven sensor I need to change out my oven sensor. I don't want to dismantle my whole oven if I don't have to. Could anyone tell me where I should start? Where is it located in my oven? I have a Kenmore 665.9528001. Thank you for your help.
  • dirtdobber Jan 30, 2008
    Sorry it is a Kenmore 665.95822001
  • 25 Answers
Open your oven door and look to the back and top , should see small metal bar sticking out held in by a couple screw. that is your sensor. Most of these can be change right from the front some you have to take the back panel off, just make sure that the connection on the sensor is all the way through the oven wall. And turn off power prior to working on range
Posted on Feb 01, 2008
Why does my oven turn off?
Loose wire connection or bad breaker.
Nov 06, 2017 | Ovens
Kenmore digital oven model 79095321303 temperature is wrong. Digital display on oven says 350 degrees but oven thermometer placed in center of oven (middle rack) shows 200 degrees. When I up the...
It could be one of two things either the control board or the temperature probe and I suspect the probe and that is a do it yourself job.
The oven temperature sensor on your Kenmore range is a one-piece unit that mounts to the rear oven wall with a mounting plate. The sensor is not difficult to change. You will need to dismantle the rear panel from the oven to access the mounting plate. Most appliance repair shops will have replacement sensors. It is a good idea to take the old sensor with you along with the model number of your oven. This way you will be sure to get the correct replacement sensor for your oven.
  • Unplug the Kenmore oven power cord from the wall outlet. Move the oven range away from the wall so that you can access the back of the unit. (Ask a friend to assist you to move the oven. if necessary.) The oven may use an anti-tip bracket on one of the rear legs. Push the oven toward the back wall to release the leg from the bracket in the floor. Tilt the back of the oven toward you, and pull the oven forward.
  • Remove the screws that secure the back panel to the oven with a Phillips-head screwdriver. Pull the back panel away from the unit and set the panel out of the work area.
  • 3
    Locate the mounting plate for the oven temperature sensor on the upper right side of the back of the oven. There will be a single wire coming from the back of the mounting plate and the wire mounts to a clip.
  • 4
    Follow the wire to the connector on the other end. Pull the connector on the wire to disconnect the wire from the wiring harness.
  • 5
    Remove the two screws that secure the mounting plate to the rear of the oven with a Phillips-head screwdriver. Pull the temperature sensor straight out of the oven. Unclip the sensor wire from the mounting clip.
  • 6
    Take the oven temperature sensor to an appliance repair facility to purchase a replacement. Insert the sensor end of the temperature sensor through the hole in the back of the oven. Slide the sensor all the way until the sensor mounting plate is flush against the oven. Secure the sensor with the two mounting screws.
  • 7
    Connect the sensor wire to the connector by pushing the connector until it locks in place. Snap the wire inside the retaining clip.
  • 8
    Place the back panel back over the rear of the oven and secure the panel with the retaining screws. Slide the Kenmore oven back into its working position and plug the power cord into the wall outlet.
  • Oct 09, 2011 | Ovens
    What does blinking beeping F2 mean?
    Hello there"
    The F 2 error that you are getting is telling you that the temperature sensor is going bad and needs to be replaced the temperature sensor is what senses the ovens temperature say you have it set for 350 when it is at 350 the sensor tells the oven to stop heating up and when it gets to a certain temp below that value it will make the oven heat up again
    it looks like this
    May 21, 2010 | Magic Chef 9815 Electric Single Oven
    RECEIVING A F2 ERROR CODE ON DISPLAY SCREEN. CAN ANYONE TELL ME WHAT THE CODE MEANS AND HOW TO FIX THE PROBLEM?
    the oven has had a high temp the temp sensor will need to be replaced , cost about $75 but if you look around you can find it for much less
    Apr 25, 2010 | Maytag CWE4800A Electric Single Oven
    Broken screw of Light bulb stuck in Neff Oven
    hi,,
    make sure the power is OFF. get yourself a flashlight and a small flat blade screwdriver. okay you have to make a small bend in the old light bulb screw area so you can get a pair of needle nose pliers in there to get that out, you need to get right in between the threads of the socket and the old light bulb, just enough room to get a pier of needle nose to turn the old bulb out, be careful take time
    J
    Jun 29, 2009 | Neff B1421 Electric Single Oven
    Preheat takes forever
    http://www.applianceaid.com/nuker.html
    click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
    Some ohm readings and there temperature:
    Degrees F    -   Resistance
                100 - 1143 ohms
                 200 - 1350 ohms
                 300 - 1553 ohms
                 350 - 1654 ohms
                 400 - 1753 ohms
                500 - 1949 ohms
    click this link
    http://www.applianceaid.com/elecrange.html
    Mar 01, 2009 | GE Ovens
    Need to replace light bulb in kitchen aid microwave
    KitchenAid wants $58 for the replacement bulb. I bought it for $1.99 from www.lightbulbsdirect.com and it works just fine. The Item number is Q5G412V. It is a halogen 5-watt, 12-volt bipen G-4. Replacing the bulb requires some dismantling of the microwave. At first I was nervous about removing so many parts to get to the bulb but in the end it really wasn't so bad. The only tool I needed was a Phillips screwdriver. I surfed the net a eventually found instructions left by a friendly Blogger that guided me through the whole process. KitchenAid engineers were so STUPID when they designed this microwave. It takes two hours to replace a bulb that should take 5 minutes. Oddly enough, replacing the bulb in the normal oven below the microwave oven is a piece of cake.
    Jan 19, 2009 | KitchenAid KEMC308 Electric Double Oven
    Electric Diagram for Kenmore Model 790
    Has the oven run out of control or gotten too hot? The 790 series is made by Frigidaire and those fault codes are F0 to F8. F2 indicates the temperature sensor is reading too hot. Now with the double oven models, some manufactures add an extra digit to the fault codes to indicate which oven created the fault.
    Your most likely fix is to replace the temperature sensor. The most probable locations for the wiring diagram is taped inside the bottom drawer, on the back or under side of the oven, or behind one of the panels on the back of the oven. This might tell you the room temperature resistance for the temperature sensor so you can test it with an ohmmeter and be sure that it is faulty. Try Appliance Parts Pros for replacement sensors.
    Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Ovens Logo
    79 people viewed this question
    Top Ovens Experts
    Marvin
    Marvin
    Sal De
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
