Question about Gupta Team Developer for PC
Small engine ran out of diesel motor will not start
  • whatman5 Jan 30, 2008
    thank you, i will look it over.
    Problem Solver:
  • 30 Answers
There is usually a primmer on the the fuel pump. a pump lever to manually refill the filter. AND/OR refill fuel tank.
you have to get the fuel to the pump again.
Posted on Jan 30, 2008
.my ford focus diesel 1.8 tdci 2009 ran perfectly. One morning it refused to start. Sprayed easy start thro intake manifold, still won't start. Checked fuses ok What could possibly be the problem
check battery with a load tester
diesel engines have to spin fast when starting
using easy start on a diesel is a sure way to destroy the engine
run the fault codes
Jan 07, 2018 | Ford Cars & Trucks
I have a ford transit van diesel 2002 It ran out of fuel due to a faulty display showing half full. I have taken to a mechanic who bleed diesel through, replaced glow plug relay and starter motor. three...
sounds like you have spent a lot of time and money on this, i'll
give you a few simple checks , will it start on a VERY small wiff of eather (starting fluid) if it does run you have a fuel problem,but most of all it will tell you that electrical portion is working that allows motor to run and confirm,fuel supply peoblem
Jul 21, 2014 | Ford Transit Cars & Trucks
Why wont my 2005 f 250 diesel won't start
diesel engines can be a real pain if you run them out of diesel and cost you a bit to get them started again, it's due to the air that gets into the injector valves. The seller should pay for the price of this or give you a refund if he is not willing to cover this cost, it's really not fair he have you come and pick it up saying it's run out of fuel, whats to say he never ran out days before which is why he's selling it! It's a job you need to get a garage to do and not as easy as just putting more diesel in. This used to be the case with older diesel engines anyway i'm unsure about the more modern ones. Good Luck...
Jul 10, 2014 | GMC Vehicle Parts & Accessories
Ssangyong actyon sports
Diesels shouldn't flood. If you ran it out of fuel you might have air in the fuel line. You can bleed the air by the fuel filter. This should help.
Nov 04, 2013 | Cars & Trucks
I tried jump starting a diesel engine with my petrol engine now my petrol engine wont turn over although the battery is good why ?
Some times the extra amperage coming from the alternator the diesel motor will burn out the electrical components of a smaller vehicle. This is why you should never jump start your lawnmowers, motorcycles, or any small engine with a full size vehicle. Check your battery, then alternator, and keep tracing it back until you find the source of the problem.
Apr 21, 2013 | 2005 Toyota Avensis Sedan
How can i fix an air lock in a 4DR5 engine. i ran out of fuel and my canter stalled. when i put diesel in the tank the vehicle is just cranking
tell type year of vechicle.some diesel engine primed at fuel filter.using small hand pump primer or using hand vacuum pump connect to fuel return line in which it will pull fuel from tank to the diesel injection pump.
Feb 15, 2012 | Cars & Trucks
My merc vito 2002 turbo diesel ran out fuel after filling with 20l and trying to start 4 60secs have no sign of any firing of engine have undone small bolt on top of feel filter attempt to start noting no...
Hey, I've got an R reg vito and they're all the bloody same. They're fitted with a "self priming pump" and i've used the quotation marks because they never bloody work! I've ran out of diesel in mine a few times due to a broken guage and it's always the same, depress pedal and for 30 second intervals crank the motor and depress the accelerator halfway. After an hour, multiple stalls and a flat battery it may choose to start. If you run out on a hill, forget it. The last time I ran out before I got pissed off and fixed the fuel guage I did just that and a handy hint if you're stuck on a hill in a vito and out of fuel is to always carry a posi drive screwdriver in your van. If you can bear the taste of diesel, unscrew the rubber hose on the clear fuel line that runs into the fuel filter on the left hand side and ****. The pipe's fitted with a n/r valve so once you taste diesel, reconnect it and crank for a bit and it'll start. If you happen to be really organised, keep a can of brake and clutch cleaner spray in your van and spray into the air intake in small bursts and it'll fire up in a second. The latter mentioned product is a must to have and works ten times better than any can of easy start. Finally when you have time I'd recommend doing what I did and fitting an inline hand primer pump to the clear fuel line which i've tested and removes the need for all of the above messing around. The simple fact is, the vitos self primer is s**t and cannot be relied upon so if you're like me and like to play petrol station poker, a £3.99 ball pump is a must.
May 24, 2011 | Mercedes-Benz Sprinter Cars & Trucks
How do i restart my peugot 206 diesel? I ran out of diesel a week ago and haven't been able to restart it since.
It depends on the diesel engine. Some need to be towed to a shop and the injector taken apart, others just need to be cranked for a minute and maybe a little starting fluid. Newer, passenger vehicles and pickup trucks generally start a lot easier than some of the older and/or larger engines.
no need to take an injector out if you ran it out of fuel, the first thing to do is to remove the fuel filter and fill it with diesel then reinstall full fuel filter next if engine does not start quickly, crack an injector line loose to bleed the air when engine is running re-tighten fuel line
Feb 28, 2011 | Peugeot Watches Gate Peugeot 206 Cc With...
Ran out of diesel 1.9 TDi 74kw. have refuelled and cranked engine for 15mins and still it won't start. there is fuel from tank to filter, to pump and return flow.
This is very important for Audi 1.9 TDI engine: IT IS FORBIDDEN TO RUN WITHOUT DIESEL FUEL IN RESERVOIR !!!
This type of engine is equipped with pump-nozzle injectors which develop up to 2050 bar injection pressure !
Remove the fuel filter, fill up with diesel fuel and put in place. After that try to start the engine with accelerator pedal to the floor. Heed of electric starter motor temperature and battery status! After 40 - 50 sec. of start attempting wait for 1 - 2 minutes for battery and electric starter motor revival. After few starting attemptions the engine must start.
Jan 13, 2010 | 2004 Audi A4
I have a 2000 ford f250 super duty and my engine turns but wont start. It ran fine the other day then i let it sit for a day then try to start it and now it wont start this is the second time it happen to...
possibly the fuel pump check the fuel pressure with a gauge on the fuel rail if its a gas motor, is it diesel if so your in luck cause im a diesel mechanic
Oct 02, 2009 | 2000 Ford F250 Super Duty Crew Cabs
Computers & Internet Logo
Top Gupta Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Gupta Computer and Internet Expert? Answer questions, earn points and help others
