Question about Canon 75-300mm f/4-5.6 III USM EF Lens
Broken ring around 75-300 zoom lense
Broken ring that is attached with 3 tiny screws onto 75-300mm lense. Where can I purchase a new ring? This is the ring that accepts the filters etc.? Thank you.Pamela
  • 667 Answers
Hi Pamela,
You can order directly from Canon USA,
Canon's info: To order an internal replacement part, please call 1-800-828-4040. The hours of operation are 9:00 A.M. to 8:00 P.M. EST from Monday to Friday. When calling, speak the term "order parts" when the speech routing system asks the reason for your call. You will immediately be routed to the Parts Desk for assistance.
Posted on Jan 30, 2008
Sigma 170 500 lense not retracting lower than 300mm
One of the plastic stop paws is broken.
Jan 07, 2014 | Cameras
Problem useing the zoom on Olympus 70-300mm Lense
No, but it appears that there is a bad tooth or something in the gear mechanism of the lens. Internal issue, hopefully over time it will "go away." Cross fingers and hope it does not get any worse. I would carefully shake the heck out of it to possibly dislodge what ever it is.
Sep 03, 2017 | Olympus Zuiko 70-300mm f/4-5.6 Digital ED...
I have a Sigma 70-300mm lense which, when I attach it to my D300 gives me an error message of FEE. I was assured when I bought the lense that it would work. Am I doing something wrong?
You didn't specify which Sigma 70-300mm lens (Sigma has at least five different versions, and I'm not referring to the lens mount), but from the error message I assume the lens has an aperture ring. Turn the aperture ring to its smallest setting (largest f/number) and lock it in place. Control the aperture from the camera, the same way as on a lens without an aperture ring.
If the lens doesn't have an aperture ring, please reply to this post specifying the exact model of the lens. That's all of the numbers and letters around the 70-300mm, like AF, DGO, f/4.5, etc.
Feb 27, 2011 | Nikon D300 Body Only Digital Camera
I have a Canon Power shot S3 . Can I use a Sigma AF-Mf zoom lens 100-300mm to it. If Yes, what type adapter to use.? I also have a 35-80mm canon lens. can this be used ? Thanks.
Your camera is a fixed lens compact model. You cannot fit other lenses to it unless they are specifically designed as supplementary lenses which screw onto the existing lens filter thread.
There are no adaptors you can safely use either, the only ones would be lens reversing rings which are used to mount lenses backwards for ultra close-up macrophotography, but the weight of the lenses you propose on the end of your existing lens would break your camera.
If you wish to use interchangeable lenses then you need to obtain an SLR or an interchangeable lens rangefinder camera.
Oct 03, 2010 | Canon Cameras
Where do I send my quantaray 70-300mm for repair
You may have two options.
First, contact the place where you bought the lens from. Quantaray is mainly a Ritz Cameras brand.
Secondly, you can use third party repair shops.
I purchase some of my lenses from KEH. [keh.com]. They have a repair shop for cameras and lenses.
Attached is their FAQ site. http://www.keh.com/repair-center.aspx
Hope this helps.
Andrew
Apr 01, 2010 | Quantaray 100-300mm F4.5-6.7 Zoom Lens for...
Zoom lens is "locked"
Is there a little lock switch on the lens?? My Nikon lens all have a tiny little lock and if it accidentally gets pushed into lock position it will not zoom. Barry Brown www.coralreefphotos.com
Aug 18, 2008 | Quantaray Tech-10 70-300mm f/4.0-5.6 Lens...
My question is about a Quantaray 75mm-300mm
Slide a piece of paper partway under the ring (make sure you leave enough hanging out so you can remove it later) and see if that tightens the action some.
Another low-tech approach is to push the ring to expose the inner barrel, then attack one or more pieces of Scotch tape or masking tape.
Jul 30, 2008 | Quantaray 28-200MM F3.8-5.6 Lens for Canon...
Tamron 70-300mm lense
Make sure the aperture ring is set to the minimum f-stop number, ie f22,f32. It is usually colour coded orange
Feb 16, 2008 | Cameras
Canon 75-300mm f/4-5.6 III USM EF Lens Logo
442 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
