Question about HP Photosmart 3310 Printer
Error Press OK! to continue
Hi my name is johnny22 and I own this printer and about a week ago.It won't start up correctly.It goes thru all the normal start up procedure.It even run a maitanance on the printer.The first screen says Improper Shutdown.
To avoid damage,use the on button to shut down the printer.Do not use a power strip or wall switch to shut down.then at the end Press OK.
  • 3 Answers
Hello johnny22, this is Enday inorder to solve your problem ..try this steps....uninstall your printer and then re-install the software again.... just see if its work...
If not just reply me inorder to give you another solution....
Posted on Jan 30, 2008
Service Call 069: Error
My printer (Oki C330dn) experienced a hardware issue that placed it in a mode where it displays a 'Service Call 069: Error' on startup after the hardware problem was corrected. I used the following button combination at startup, which corrected my issue. Press and hold the BACK, DOWN ARROW, and OK buttons and power-on the unit. Continue to hold the buttons until you see RAM CHECK and some asterisks then release. This forces the unit to ignore all warnings and errors while placing it in an online mode. My printer came up to a ready state and worked normally. The next time I turned it on, it started up without any errors.
Aug 17, 2012 | Cisco Oki C330Dn Led Printer - Color -...
I get a ink system failure, hp c8180 all in one printer ?
Hi, Its a common error which comes for many individuals and we can rectify by ourselves.
Please perform the following steps. 1]Press and hold the "*" key. 2]Press the "#" key and release both keys. Display should say "Enter Special Key Combo" 3]Press and release in sequence the "1", "2" and "3" buttons.screen will say "support" R0631M 4]Press and release the right arrow button until the display says "System Configuration Menu". 5]Press and release the "OK" button. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", 6]Press and release the "OK" button.Display should say "Hardware failure status: Clear. Press OK to clear". 7]Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". 8]Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 9]Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 10]11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. 11]The error won be displayed in the printer. 12]Let us print a self test page to check the functionality of the printer.Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report
THANKS FOR USING FIXYA..FEEL FREE TO POST YOUR COMMENTS.. BEST WISHES
Dec 19, 2010 | Office Equipment & Supplies
Every time I try to print the paper jams. All the paper has been removed, turned it off, still jamming
Found this on the Web, hope it helps you.
If you find this helpful, pls rate me.
Turn your printer off for about 10 seconds, remove the printer cable and then turn the printer back-on. Does only the Green Power Light come on solid [not blinking], as would be normal, or does the Red Error Light also come on? If only the green power light comes on, then try running your printers self-test page, directly from the printer. On most epson printers you can usually run an self-test page to determine whether a problem comes from the printer itself, or possibly from your computer system. Of course if there are actually any red error lights/leds, already showing on your printer, that would indicate that there is already a problem in your printer. Not all epson printers are always the same, but the following information applies to most models. If this self-test does not actually work on your particular printer, then you should refer to your "User's Manual/Owners Manual" for the correct procedure on how to run your printers self-test page. First unhook/unplug the printer cable from the back or side of the printer. Leave the power cord still plugged in to the wall and leave the paper loaded, as normal. Turn the printer off for 10 seconds or so, to clear out any remaining DATA or information that may still have been in the printers system, from when the computer was previously connected. Normally [on most models], you turn the printer off and then you simply reach over and hold-in on the paper button, while you reach over and turn the power button back on, as normal. Continue to hold in on the paper button for about 3 to 5 seconds, but release the power button after turning your printer on. Release the paper button once you can hear and see the printer starting to initialize and start to pull-in a piece of paper. The printer will normally print out the self-test copy, which will also have a nozzle test on it. If that test fails, or cannot actually be ran because the "Red Error Lights" come on, then you know that there is an actual problem in the printer. Depending on the combination of which lights are on SOLID, or FLASHING or OFF, will actually indicate the possible service error condition. Be sure and let us know if you recently had to remove any bad paper jams, by yanking out the paper with force, especially towards the rear of the printer, in the backwards direction. There is a common problem when you get a constant jam condition, or paper won't feed in correctly after a bad jam was removed, or even when the printer or your computer thinks that the paper has not been correctly loaded. If that is the case, then its possible that a part was unhooked/unseated or even damaged, causing a possible constant paper jam condition. If you did have a bad jam, prior to the paper feeding problem, then let us know and we can try to help you further...ON THE OTHER HAND: If everything is working correctly in the printers Paper Feed Assembly, Carriage Assembly/Cartridge Assembly and the Printhead Assembly, then the self-test copy should be printed out and correctly fed thru the printer. If the self-test page prints out correctly and the nozzle test looks ok, then that indicates that your printer thinks it is working normally [as far as the self-test goes].
Thanks and Good Luck.
Jan 25, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Blurred black printing
GENERIC CARTRIDGES DO THIS.
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges.
Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc.
All Generic Cartridges, will print lines thru the words, or just print the top or bottom, and also do a mix match with the colors. That's what the Companies do., so they can keep selling the ink cartridges.
Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Cartridges for the PRINTERS.
Since you do not mention if you're getting any ERROR Code, this is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Dec 26, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
Ink system has failed error Oxc 19a 0031
Are you experiencing the ink system failure on your printer? The error is caused by air getting in the ink tubes feeding the system. This is normally cause by refilled cartridges but can be caused by any cartridge that goes very low on ink and then tries to reload ink. This reset procedure does have to be performed with a full cartridge installed. The following reset procedure will correct the issue by purging the ink tubes and flushing any air trapped in them.
Please perform the following steps in order:
1. Press and hold the “*” key.
2. Press the “#” key and release both keys.
3. Display should say “Enter Special Key Combo”
4. Press and release in sequence the “1”, “2” and “3” buttons.
5. Screen should say "support" R0631M"
6. Press and release the right arrow button until the display says “System Configuration Menu”.
7. Press and release the “OK” button.
8. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
9. Press and release the “OK” button.
10. Display should say “Hardware failure status: Clear. Press OK to clear”.
11. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
12. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
13. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
14. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
15. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
16. Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
You should be back up and running.
I hope this helps, If so pleae rate our solution
Nov 26, 2009 | HP Photosmart C6180 All-In-One InkJet...
Trouble with theme
click in this order
right click my computer
properties
advanced system sttings
continue
settings [under performance]
enable desktop composition.
ok
ok
then when ur done its possible that the glass might not be back, so go back thru all the same steps, but instead of enable desktop composition. Click
enable transparent glass.
All should be back to normal, thanks again.
Apr 10, 2009 | Microsoft Windows? Vista Home Basic...
My printer locks up
go to your printer folder, right click on the z4000 printer, go to properties, tools, and actions. Then reset the printer to factory defaults. Do this right as it starts up. This might fix your problem.
Apr 02, 2009 | Zebra Z Series Z4000 Printer
Startup
dear sir.
"checking disc comes up" this message is hard disk message and it's showing becoust missplase of harddisk thru yr laptop scoket if u know bout laptops u need to plug off then reconnect yr laptop harddisk otherwise contact system wonder near u.. it's help u.
Jan 01, 2009 | Computers & Internet
Lost my installation CD and downloaded the software from HP but doesn't work
To register .dll files follow these steps: 1. Click Start, click Run, type cmd in the Open box, and then OK. 2. At the command prompt, type the following commands, and press ENTER after each command:
regsvr32 /u sccbase.dll
regsvr32 /u slbcsp.dll
exitNote Click OK if you are prompted.
3. Restart your computer. 4. Click Start, click Run, type cmd in the Open box, and then click OK. 5. At the command prompt, type the following commands, and press ENTER after each command:
regsvr32 sccbase.dll
regsvr32 slbcsp.dll
6. Restart the computer.
Mar 10, 2008 | HP DeskJet 3940 InkJet Photo Printer
HP Photosmart 3310 Printer Logo
162 people viewed this question
Seeker5211
Seeker5211
