Question about Maytag Neptune MDG5500AW Gas Dryer
Neptune Dryer lint trap
We purchased our Neptune washer and dryer in may of 2005.We have not had any problems, but I noticed the lint tray housing is poorly designed. It allows a lot of lint to get by the screen and into the the centrifugal exhaust fan. I vacuum it out all the time,but it's a pain. I'm very handy and have worked on it a little, but it still gets by.
Any suggestions??
Please help!!!!
Thanks BILL
  • 2 more comments
  • tconstantine Feb 01, 2008
    Yes, I have the same problem with the lint getting past the screen. I was wondering if a gasket on the screen was missing or something.
  • Bontner Mar 07, 2008
    Yes, I have the same problem. So I have taken it out of the house to open the machine and blow out the lint. However, I can't figure out how to open the cabinet. Any suggestions
  • TelcoGuru Mar 28, 2008
    Yep, same here. Looks like a design flaw to me.
  • Anonymous Nov 18, 2008
    I have a Neptune. The lint trap was not going all the way down into the dryer..It was that way from delivery. I thought that was the way it was supposed to be until it started rising higher.
    Long story short, my dryer caught fire last week...lint in the bottom. It was cleaned out a month ago when the sensor was replaced.
    My dryer is 2 1/2 yrs old..It's electric.
    These machines are terrible!
  • 725 Answers
No gasket but I can help
krazytech
Posted on Apr 05, 2008
The lint trap on my GE dryer is moist.
Check the venting, if it is blocked or if the venting is bend it will not allow the moisture to leave the dryer and it will end up in the lint trap and on the door
Jul 26, 2012 | Maytag Neptune MDG5500AW Gas Dryer
Why are the clothes coming out of the dryer smelling musty? we have the lg tromm dle5977w
The problem might not be with the dryer, but with the washer. Let me explain. When I first got my LG w/d set, I did a web search, and found that front load washers tend to build up bacteria and mold(which one person said was staining her clothes). The solution was to leave the door of the washer open when not in use. That worked for me for the most part, but the musty smell persisted. I found that the soap tray was getting dirty(from mold/bacteria), and the area inside was even worse. So now I remove the soap tray when not using the washer. Also, some appliance stores have cleaning packs that dissolve in an empty washer load. They are supposed to clean out residue and kill bacteria that cause odor in "HE" washers that may only be noticeable from the dryer. The brand name of the product I have is "Washer Fresh", and they're about $12 for 6 "PowerPacs".
May 06, 2010 | LG DLE2514 Electric Dryer
Lint is massing toward the bottom of the lint trap
please check your exhaust vent, where the dryer air comes out of the house, this particular pattern is very indicitive of a slow moving exhaust, you may need to clean the duct between the machine and exhaust as well
Oct 22, 2009 | Kenmore 62602 Electric Dryer
Admiral Dryer: 5 cycle 3 temperature electric
Unplug Dryer
Remove back (many screws)
Clean lint from interior & Vent Chute
check for breakage & parts on dryer floor
check for burn damage (wires burned off or char)
if no burn or char:
could be the "Dryer Coil" itself broke or
a "Snap Disc" usually mounted on the coil housing.
Very Serious!!!! Replace only!!!! Do not ever bypass!!!!
Stay clear of dryer for test start
Be ready to shut it down fast in case of problems
Always replace back & vent chute
Good luck,
Vinnie
Jun 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Lint trap
http://www.pcappliancerepair.com/model-display.php This will show you how your dryer is put together. The lint has gone directly to the fan, where it could affect fan performance. You would have to remove the front off the dryer, and the cover off the fan area. It's not a bad idea to clean this area once in a while.
May 11, 2009 | Maytag Neptune MDE4000 Electric Dryer
Dryer lint throughout thr house
lint throughtout hte home is a sign tha there is a tear / or a disconnect of the dryer vent. check your venting
Feb 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer lint problem
HI bob. thanks for your question. look at your lint filter. if its torn replace the screen. its the only way to stop lint . and clean the venting to the outside, thanks the appliance doc. please rate my answer. thanks
Sep 23, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer Problem
SHUT OFF THE BREAKER to the unit then open the panel (3 Screws) that is in between the washer and Dryer you will see your venting hose ther remove the flex vent pipe from the exh duct closes Turn back on the pwr and run a load in the dryer see if it drys ok if you wil need your vent to the outside cleaned out
Jan 23, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Neptune dryer
sounds like one of your tumbler veins inside the drum is loose. there should be two or three screws holding them in
Nov 20, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
804 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
