Question about Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel stove/oven
Stove elements go straight to max hot when turned on. no matter where the the temp knob is
This range has faulty simerstats they need replacing.
Posted on Mar 08, 2008
Upper oven takes forever to preheat
Deborah...all stoves have a row of fuses, usually under a strip cover. It sounds like one of the burner fuses have blown and needs replacing.If one is blown you would only have 110 volts on the element instead of 220 volts which would make the element only half as hot.
Dec 20, 2014 | Fisher and Paykel AeroTech Double OD302...
Fisher paykel problem
sounds like you have a problem with the thermostat it may need to be replaced. \you can goole appliance parts and you will see a number of dealers you can get parts from
May 04, 2014 | Ovens
How to I remove fisher & paykel range knobs
They should just pull straight off. If they're a bit stubborn get a small screwdriver, protect your stove with a rag and carefully lever under the knob edge. There is nothing fancy holding these things on, just friction and they are keyed so you cannot make a mistake when putting them back on. Cheers.
Dec 30, 2012 | Fisher and Paykel OR36LDBGX1 Range
Hi, I have a Fisher and Paykel Thyme Stove and the two big elements wont turn down, Whats wrong and can it be fixed cheap?
this is a common problem ,the switchs that turn on the elements are called thermostats,and they are faulty, an easy repair by any electrican
Sep 26, 2012 | Fisher and Paykel Ovens
Fisher and Paykel Paprika Oven Top Elements Full hot!!
No controller. The switch for each element (called a simmerstat) is what controls the heat. It is a common fault and will be fixed if you instal new simmerstat for each faulty element.
Mar 17, 2012 | Fisher and Paykel Ovens
I have the fisher paykel pepper electric stove top and oven at home. the stove is working just fine, but below it the oven turns on but it doesnt heat up. what should i do?
When you say that the oven turns on I assume that the oven indicator light is working. If this is so there will be only two likely causes for the oven not working.
Oven element is faulty - check by performing continuity test;
Wiring at oven element terminals burnt off - check visually.
If you are handy carry out the above. If not, call a repairman.
Feb 15, 2011 | Ovens
I have a Fisher and Paykel Saffron oven - stove top elements have started only working on high - unable to turn these down.
The temperature switching device has 'died', and needs replacing. This is a continual problem in these stoves (we have replaced each of ours at least once or twice in the 7 years we have had it). I will never buy another F&P oven!
The only solution is to get F&P or another repairman to come out and fix it. It cost us $AU 215 each time.
May 16, 2010 | Kitchen Ranges
Hi my Fisher & Paykel Paprika stove (Model FPRA6102AW) Needs a New Oven element, and 3 of the plates stay on Hot. Are these parts available and how much would they cost please: x1 Oven Element x3 Switch...
Yes the regulators/simmerstats are stuffed but are not hard to replace...but please turn off the power 1st when removeing the backing plate as you will kill yourself....yes you will.
Use a multimeter set on volts ac or a volt detector stick, test tester on a known live sourse 1st like a power point....switched on
Mar 05, 2009 | Fisher Ovens
Fisher and paykel B1600E multifunction stove manual
I have a PDF copy of the Fisher & Paykel B1600E user manual
Nov 12, 2008 | Fisher and Paykel AeroTech - OS302M...
Oven temperature fisher paykel
benypeny what that flash was from what I have seen over the years is your heating element on the back wall burning out. Remove the cover and you will see the element is no longer in 1 piece.
Feb 03, 2008 | Ovens
Fisher and Paykel GWL11 Top Load Washer Logo
352 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
