Question about Reddy R155D Utility Heater
R155 and unburnt Kerosene
I used my R155 kerosene heater for years in my garage without any problems. Then the 097061-01 solid state relay went out. I replaced it with new part number 107850-01. At the same time, I also figured I would replace the filters, gasket, (HA3017) and the rotor (HA3004). When putting it back together, I used the HA1182 low pressure gauge I bought to set the psi to 5.0 psi like the manual said. Upon doing this, it would only blow out a cloud of atomized kerosene and not light. If I put my finger over the adjustment screw and let the pressure increase toward 10 psi, it would light but then go out as it returned to 5.0. I tried increasing the pressure. At ~6 psi would allow it to stay lit but your eyes burned from unburnt kerosene as it ran longer and longer. I decided to replace the other components related to the fuel air mixture (HA3010 nozzle and PP211 spark plug). No improvement. I increased the pressure to 8.5 psi which made the end cap glow slightly but it would stay lit and not put out a cloud as it tried to start. While running at 8.5, slowly you notice a sore throat and burning eyes from the unburnt kerosene. Can you help give me some guidance as to what is wrong or what to check???
  • Vicious6 Feb 17, 2008
    I have the older model which is doing the same thing, mine is the R155A. I have replaced the plug, cleaned the nozzle, replaced the fuel filter, set the fuel pressure and cleaned the lint filter and so on. I am starting to think there may be a rotor problem. It will burn your eyes out when it does run, when it does not it smokes up the entire garage. This must be a common problem with these things.
  • cjwert Feb 21, 2008
    Is there a specification for the plug gap and for the depth of the tip?
    If not, do you just keep adding shims to back up the plug until it
    won't stay lit???
    Thanks-
    Chris
    Problem Solver:
  • 19 Answers
Check plug gap and depth of the tip. The spark may be to far into the fuel spray flooding it out. DESA says use a standard spark plug washer or two for shims if needed.
Posted on Feb 21, 2008
  • Todd Gibb Feb 22, 2008
    The gap is .075 inch. No spec on depth just enough that the plug doesn't foul with carbon or become wet with fuel. Good Luck.
IS IT BEST TO USE KEROSENE OR DIESEL IN HEATERS
Kerosene is best. It's better for the machine as it's cleaner and will need less maintenance plus it won't run smokey
Feb 09, 2012 | All-Pro Kerosene Garage Shop Heaters - All...
I have an all pro 60,000 btu flex fuel heater. all pro went out business. i need a new igniter .... can anyone help me find this part ?
Try www.desatech.com. From the main page, click on kerosene heaters. Some igniters should be at the top of the page that comes up. See if one matches yours.
Jan 14, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
My electric Kerosene heater will shut off
You need to do a little maintenance. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem and where to get the parts to get your unit running like new. Most portable heater parts are the same. Also DESA went into bankruptcy but many dealers still sell parts. It is all in my tip. Let me know if you need more help.
hardrocko
Thanks for using FixYa
Feb 28, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Will not fire
this unit operates with a small air compressor at rear of motor. Remove the solid 1/8 inch plastic plug. install a low pressure gage. you should read around 5 psi
Feb 28, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Pk115t garage heater won't start
check all of the air filters and lines to start but it sounds like the CAD flame sensor.
Feb 02, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
200T would burn
During start up, a hot surface ignitor glows brightley to ignite kerosene, check to see if it is broken
Nov 08, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy R155D Utility Heater Logo
235 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
