Canon PIXMA  MP530 All-In-One InkJet Printer Logo
Posted on Jan 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon mp530 getting error message 6a00
My daughter has a fairly new canon mp530 and she is getting error message 6a00. how do i fix this?
  • 4 more comments
  • Anonymous Feb 21, 2008
    same exact problem
  • Anonymous Mar 27, 2008
    This @#%^&*( printer is making me wish I had hair so I pull it out! have the 6A00 bug with my MP530, been good up to now. Can anybody help
  • Versusnja Dec 12, 2008
    Exactly the same problem here.
    Tried switching on/off.
    Tried pushing print cartriges to the right/left.
    Tried cleaning (vie maintenance menu)
  • Anonymous Jan 01, 2009
    When swicthing on of printer an error 6a00 is immediately displayed.
  • Anonymous Jan 30, 2009
    same problem returned with extended warranty---got the same model for free again with extended warrenty...ran for a year...same problem....returning it again to exchange for a different model this time.;; Have learned to buy extended warranty for printers
  • coyote2 May 11, 2010
    Do you have a solution to 6A00 error code
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 18, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
8938
Points
11
HI Guys 6A00 error usually cant't be fixed according to the service centre, I was lucky and actually bought an extended warranty, the service centre said that the MP530 are a good printer and worth fixing as they don't see many at all compared to other models and other brands. There was a broken piece of hardware that something to do with the print carriage. cheers vailey
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 24, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8906
Points
Copy and Alarm lights are flashing alternately. Any suggestions?
Anonymous
Level 3:
President:
  • Master 4,402 Answers
  • Posted on Feb 04, 2008
Anonymous
Master
Level 3:
President:
Answers
4402
Questions
0
Helped
1710983
Points
8129
A
Anonymous
I just got that error about 1 week ago. It won't clear. Unfortunately it is 3 months past its warranty period. I suggest you have Canon fix it or replace it if it's still within 1 year of you purchasing it. Remember to have your receipt!
A
Anonymous
Try find at
http://pratama.auli.biz/archives/reset-printer-model-canon-s9000-s300-s400-i550-i560-i850-i860-i865-i9100-i9950-pixma-ip3000.html
1helpful
My Canon MP530 is giving 6A00 error message and alarm light is flashing along with copy button. i have replaced empty ink cartridges with new ones. Can anyone help, please?
Error code 6A00 indicates an error occurred in the AP motor during purging operation. You need to replace sheet feed unit, logic board assy and purge unit to fix it. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Canon PIXMA MP530 All-In-One InkJet Printer Canon mp530 error 6a00
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like
1helpful
Hello
Unfortunitly this is not an easy fix. IF you still have under warranty you can contact Canon and they will fix it. If its not under warranty they can refer you to the nearest Canon Service center.
The 6A00 error is an internal error which can be caused by one of the following things.
- Sheet feed unit - Logic board - Purge unit
Good Luck
6A00 error code
Unfortunitly this isnt an easy fix. IF you still have it under warranty you can contact Canon and the ywill fix it. If its not under warranty they can refer you to the nearest Canon repair center.
- Sheet feed unit
- Logic board
- Purge unit
Best of luck..
2helpful
2answers
MP530 KEEPS GIVING US A C510 ERROR OR A 6A00 PROBLEM HOW DO WE SLOVE THIS.
6A00 means the purge assembly on the right where the printhead parks is jammed or stuck. You can look to the right if the carriage is not stuck on the right, see if there is paper or something caught in there. After that it will need a new purge assembly, around $40.00
Message: Check Printer 6A00 and message Service Error 5C10. I have rebooted, turned printer on and off, hit reset and reinstalled software.
Hello there
Error 6A00
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
1helpful
Show the code 6A00 and the printer won't print. The lcd reads check printer then flashes 6A00
That error indicates a sheet feeder error, apparently its not something you can fix yourself and you will need to send it in for repair.
You will need to send it too an Canon approved repair center, calling Canon and asking them should reveal where to send it.
2helpful
Display Shows Error 6A00 and it Doesnt Work ahead
6A00 is a problem with the sheet feed unit.
Follow Canon's suggestion, take it or send the unit UPS to the Authorized Repair Facility.
You will NOT be able to resolve the problem yourself.
ERROR 6A00
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=832&modelid=13371&keycode=2118&id=27509
this is a script error which can be fixed using this link i looked up the information for you.
just download from link this should help
2answers
old marine
old marine
ZJ Limited
ZJ Limited
