Question about Sony KP-57WS520 57" Rear Projection HDTV-Ready Television
DTV letters appear in upper left corner of screen
The letters "DTV" are in upper left corner of the screen and I cannot get them to go away.
Consult operations manual to find definition. You might use remote to access menu, then press "display off".
Posted on Apr 22, 2008
How do I fix when I touch a key to put in information and it prints a different number or letter than the one touched
Here is a way to recalibrate the touchscreen without having to go through the menus:
If your Nuvi has the problem that when you press one key but another key is highlighted, then either your touchscreen is defective or it is miscalibrated.
For example, pressing the letter "A" on the QWERTY keypad, actually highlights the letter "S" or "Q" or "Z". On the non-QWERTY keypad, this may show up as "B".
Method #1: If you can get to the main menu, press the "wrench/tools" icon and then the "Display" icon. Now press the calibrate screen button and go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Method # 2: Follow this procedure if you can't get to the main menu or any menu thereafter.
First, turn the unit OFF.
Nuvi 3xx & 6xx Series: Hold down the on/off power button and don't let go of it.
On the screen it will say "Pre-boot mode"..... keep holding the button down..... after some time you will eventually come to a screen with dots. If the screen says "Loading" and does not go to to the calibration screen with the dots, you will need to connect the Nuvi to a PC with a USB cable and rename the file "GUPDATE.GCD" within the Garmin directory to "GUPDATE.OLD". Once the file has been renamed, repeat the above procedure.
Once you reach the calibration screen, now you can let off of the on/off power button. Go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Nuvi 2xx/2xxW Series: Turn the Nuvi off. Place your finger on the upper left-hand corner of the screen and then slide the on/off power switch to the left and hold until you see the calibration screen. Note: Some 2xxW models require the procedure below for the 7xx.
Nuvi 7xx Series: Turn the Nuvi off. Touch the screen anywhere and keep your finger there while moving the on/off switch to left (don't wait for Garmin logo to come up) and then quickly moving the switch the right (lock position). After a short while, you will reach the calibration screen. Go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Nuvi 8xx Series: Turn the Nuvi off. Remove the battery from the Nuvi for at least 10 seconds. Press and hold your finger on screen, while putting the battery back in. The Nuvi will boot-up and you should see the text "Pre-boot Mode" appear on the screen. Continue pressing on the screen until pre-boot goes away and the progress bar appears. Now remove your finger. After a short while, you will reach the calibration screen. Go through the entire procedure of pressing each dot as it appears on the screen until it says "Done".
Nuvi 11xx, 12xx, 13xx, 14xx, 16xx, 24xx, 25xx Series: Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Once completed the Nuvi will display Calibration Complete
This will recalibrate your touchscreen to the LCD display.
If this doesn't resolves your problem. then your touchscreen may be defective.
Oct 10, 2015 | Garmin Nuvi 1350LMT
Motorola DCT6412 Phase III. Red light appears in upper left of oval screen. What is the meaning of the MSGS letters that appear by the red light and how is it controlled?
Take your Shaw remote control.
Press SETTINGS.
Use LEFT/RIGHT to highlight the "house".
Press OK.
Scroll-down to MESSAGES.
Press OK.
View a "message" from your cable-TV provider.
Click to DELETE the message.
The "red-light" will go out.
Oct 15, 2013 | Arris DCT6200 DTV Receiver
Garmin nuvi 1200 wont let me type the right letters
Try recalibrating the touchscreen. The procedure can be found here:
http://www.sharc.net/discus/messages/6/77.html?1315261162
Press each dot to recalibrate the screen.
Feb 28, 2013 | Garmin nuvi 1200 Car GPS Receiver
Can anyone offer any suggestions on how to delete/remove titles displaying in the upper left hand corner of my TV screen and right hand corner? For example, if I am watching a program on CITY, the title...
I believe the "Caption Vision" is selected. By pressing the "Display" button on the remote it should toggle through the choices until "Display Off" appears. That should be all.
Mar 05, 2011 | Sony KV-32S42 32" TV
I need to calibrate my Garmin Nuvi 1260T. It's been alittle off ever since I got it. I tried holding the power button for 30 seconds and waiting until the calibration screen pops up but nothing pops up. ...
In order to calibrate the screen on the Nuvi 1260T, you need to follow these few simple steps.
- Turn off the device
- Hold the upper-left corner of the screen while turning on the device
- Release the power button when the Garmin screen appears
- Continue to hold the upper-left corner of the touch screen for 30 seconds until a white screen with "Press dot" appears.
This should allow you to calibrate the screen. I hope this helps!
Mar 01, 2011 | Garmin nvi 1260T 35 in Car GPS Receiver
Video 5 / DTV disply in upper left screen will not go off.
Press Info / Display button on TV remote, on-screen display will disappear.
Sony TV Remote is required for that function, other remote wont work.
Thanks.
May 21, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
We left our 40 inch ACER televison on the same channel for a couple of weeks. Now in the upper right hand corner is an image that won't go away. Is there a fix?
Im guessing this is a plasma television. Either replace the panel(very costly) or display a bright white screen on the tv and leave it like that for a several hours.
Dec 28, 2009 | Acer AT3205-DTV 32 in. HD-Ready LCD TV
A black _ in the upper left hand corner (size of underscore)
It is what we call a "Shatted Pixel" and you can fix it by flashing your screen
Dec 22, 2009 | Dell Computers & Internet
Video Source Text remains in upper left corner of screen (video 1, video 2, etc)
If you have the original remote control, press display to get rid of it.
Hope it works.
Mar 10, 2008 | Sony KP-46WT500 46" Rear Projection...
Letters in upper left hand corner of screen
You may find it in your "Menu" button on your remote, search for anything similar to "HD Logo" and turn it off. Failing that, make sure it isn't stuck on with transparent plastic, haha.
Sep 07, 2007 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony KP-57WS520 57" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
