Question about Garmin Nuvi 660 GPS Receiver
Loss of signal after about 10 minn of time
Hello, started having a problem with my 660, it seems as though somethings is going wrong internally on my unit, it looses sat signal and asks to verify position and will not regain signal unless you unplug the unit and leave it off for about 30min. After the 30 min, I can restart the unit, and it finds it's correct location and is fine for another maybe 10 min then again looses signal. and I have to go through the same thing once again.
any ideas? I love the unit, but this is getting old.
  • jrjohnson27 Jan 30, 2008
    Thanks for trying, but this seems to happen after a certain time period. The locations I am in are receiving a good signal and then it is dropped. You could be standing still and it still happens, complete loss of signal imput.
    any other solutions, or is this normal after 12 months?
    thanks
  • 63 Answers
If it happens around the same suburb the sattelite can't get to that area.
Or it is programmed for another location meaning : it wont display most of the places near you.
Or if its old it wasn't programmed with all the streets as new streets do get built alot.
Also this GPS is a pretty bad one as I am already dealing with 5 others They are all 660s and are the only GPS with problems.
Hope this helps - Josh
Posted on Jan 30, 2008
Changing the clock/internal time
The clock settings should be set to Auto so that the clock is set by the broadcasted signal; this will automatically update when the clocks change.
Note that Recording start and end times should be set to On Time to ensure that the broadcaster's start and end signals are used. If either of these are changed, the timing becomes manual, and functions such as Series Record are not available.
Mar 06, 2014 | Humax PVR9300T HD DVR
Have 12 V bow mount trolling motor that doesn't start working until power is on for about 5 minutes. Then when it does start, have to have the power on 10 just to keep the prop moving. Checked prop and...
Hello, You have several points to check. #1 check your wiring connections--- plug, plug socket, wiring connections internal of trolling motor, condition of wiring to battery, battery terminal connection & charge of battery. #2 borrow someones DVM (digital multimeter) and check the resistance of the speed control as you turn it without any wires connected to it. #3 if problem not found take 2 aspirin and E-mail me of test results "for further review".
Sep 18, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
My 1998 jeep grand cherokee is haveing a problem with the security system, I cant seem to get it to reset
Hello
Open the hood,,, disconect both battery cables,, let it sit for 10 minn ,,,,,,conect the battery cables,,,,,,,,,,,,,,,,,, then,,,,,,,,,
Lets try unlocking the lift gate with the key ,,,, move key back and forth 3 times. this should reset the system
Jul 14, 2010 | 1998 Jeep Grand Cherokee
I am having problems getting conected to the internet on a daily basis.When it happens the orange light on the router is flashing. Checked all connections each time & all seem ok. Please advise.
I would contact your internet service provider. There is likely something wrong with your line that is causing your router to loose signal. I don't know what type of router you have, but a loss of signal usually causes that. There are other reasons, such as, your modem is going bad, your cable from the modem to the router has an internal break in a wire, your router could be going bad as well. Try power cycling both your model and router. You can do this by unplugging them for a couple of minutes and them plugging them back in. Plug in the modem first and wait a few minutes, then plug in your router and wait a few minutes, then try getting on-line. If this is a persistent issue even after doing all of this and contacting your ISP, then I would conclude that your hardware (modem, router, &\or ethernet cables) is giving out on you.
Mar 26, 2010 | Computers & Internet
Long periods with no signal - NUVI 660
Try to take it out of the car so that it has a completely unobstructed view of the sky. See if the signal problem is resolved. If that resolves the problem then you will need to find another place to attach it to the insude of the card. If that doesn't resolve the signal problem you will need to return it to the manufacturer. They have a program where they rebuild it for a flat fee regardless of what is wrong with the device.
Apr 02, 2009 | Garmin Nuvi 660 GPS Receiver
My Garmin 660 will no longer plot a destination...
Have you loaded a lot of JPGs or MP3s on the internal memory? If so, you have reduced the amount of memory available to the 660's OS. Not sure if the 660 stores calculated routes directly to the internal flash memory, but it is very likely, since it keeps your route when you power it down.
To unload the internal memory, consider buying an SD card - they are cheap right now. As a matter of fact, I just ordered an 8GB SD card for my 660 from Amazon for $13. The 4GB and 2GB cards are available for about $7 and $3 respectively. Drrrrrt cheap!
You can access the internal memory of the 660 on your computer with the USB cable you got with the 660. The two folders to focus on are the JPEG and MP3 folders. Simply copy these folders' contents to the root directory of the SD card, and then go into each folder in the GPS memory and delete the MP3s and JPEGs you added - should work better. The 660 will recognize the files on the card if left in folders named identically to the folders in the internal memory.
If you didn't add any content to the internal memory, that is a different issue altogether, probably something to discuss with Garmin. Could be as simple as upgrading the firmware. Make sure you select the correct version though, or it could be a fancy brick! Go here for the nuvi 660:
https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=164&pID=31946
Good luck, and I hope this helped!
Jan 05, 2009 | Garmin Nuvi 660 GPS Receiver
I cannot get any TV channels on my Sony TV
It sounds like you have identified the the correct problem, as the Coax connector has probably been knocked loose from the circuit board inside the TV. If you have any knowledge on this sort of thing you can take it apart and re solder the connections. If not I suggest you take it to be serviced by a professional.
Dec 10, 2008 | Televison & Video
"No Memory Stick" error (but I never had one!)
W don't you just get a memory stick for it? Then you don't have to "write off your $300 camera as a total loss"
Dec 25, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
Garmin Nuvi 660 GPS Receiver Logo
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
