Question about Frigidaire FGR231A Gas Dryer
NO HEAT REPLACED IGNITOR WORKED FOR 2 MONTHS .NOW BURNER LIGHTS FOR A FEW MINUTES THEN SHUTS DOWN.CAN YOU HELP
  • Anonymous Jun 18, 2008
    heat goes on for about 2 min then shuts off. i cleaned out all vents and lint traps and vaccumed out the whole inside of dryer, what do i do?
Dryer is noy getting hot
Posted on Nov 09, 2008
  • 92 Answers
Either the secondary coil is bad or the flame sensor. more common is the coil
Posted on Feb 10, 2008
My fireplace doesn't light right away, then it shuts off after a few minutes.
sounds to me like your thermocouple is loose just go to where it connects to the gas valve and tighten it most times this happens after it has been replaced, because temperature changes loosen them also make sure the pilot flame is directly on the thermocouple , sometimes dust gets in to the pilot and changes direction of the flame making it "grade the thermocouple, with the main burner on the air flow sometimes "moves the flame and the thermocouple thinks it went out and shuts down the main burner. extinguish the pilot, either blow it out with canned air, or use a q tip to reach down and dust it out then re light. should be good
Nov 16, 2015 | Kitchen Appliances - Others
Viking gas oven model # VGIC3656BSS, serial #022404-2919 takes FOREVER to preheat up. Sometimes in excess of 40 minutes. Been a problem for a while. Looks like flames at bottom do not increase when oven...
When increasing the temp. on a gas range the oven's burners do not increase flame size as the cooktop burners do. It just keeps the burner lighted for a longer amount of time.
First if you can see the burners do they light within about a min. or less. If no you probably have bad igniters which are not lighting the burners as quickly as they should or they are "opening up" (stops working) when they get too hot. In this case replacement of the igniters should solve the problem.
Second if it lights quickly but still takes a while to heat; you want to look at the burners to ensure that the flames are down both sides of the burner tube and not dancing around too much. If only part of the two sides of the burner tubes are lighted then a pluged orifice or burner tube is the most likely cause. Once cleaned it should work fine.
As with anything mechanical there are numurous possiblities for something not working correctly and above are the two most popular reasons that come to my mind.
May 17, 2011 | Viking VGRC485-6 Gas Kitchen Range
America standard freedom 90 furnace. when the thermostat call for heat the ignitor glows then burner lights but only stays on for 1-2 seconds if i shut off the furnace power for a few minutes then turn...
Check the flame sensor and/or the grounding from the burner ot the ignition control....it is not sensing the flame...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Feb 25, 2011 | Heating & Cooling
My vulcan ducted heating unit blows cold air for approx 1 minute when turned on then stops and try's again after approx 1 minute,it does this several times until ignited.It is obviously an ignition...
Two things have to occur here:
1) The ignitor has to light off the gas. A bad ignitor, or dusty burners can prevent ignition.
2) The thermocouple has to be in the flow of burning gas to prevent a safety shut-down, and has to be working.
And the obvious: you need pressure in the gas line, and the gas valve needs to be open.
Hope this helps you locate the problem!
Aug 14, 2010 | Vulcan AUW230A Heater
The unit will turn on and run fine for a few minutes then shut off. It won't immediately turn back on, almost as if it hans to cool back down first. Any ideas i have a lennox furnace
The ignitor will light, the blower will start up and run for a few minutes and then the system will shut down, and the blower will continue to run and cool down. The ignitor is not working properly, the ignitor has carbon build-up and need to be removed, cleaned all the black carbon from the ignitor with a little piece of sand paper and replaced, turn the heat back on and this should correct the problem.
Dec 12, 2009 | Heating & Cooling
Tonight my master temp 250 heated the spa to 80 degrees. I went out to jump in and saw error code E05. I shut it down and killed power for a little while. Restarted system, blower kicked on, burner light...
You are right about the ignitor. Depending on how old your heater is. The ignitor can become weak and flame rectification will be intermittent. You may have to replace the ignitor assembly or at lease check to see that it's not corroded enough to impede gas flow.
Oct 28, 2009 | Pentair Mastertemp Heater
Kenmore Oven Problem I have a Kenmore 79012 Range. The burners and broiler work fine. The ignitor comes on in the oven, but it will not light. After a few minutes I can smell gas, but the ignitor is still...
the ignitor has to be on before the gas valve opens up and until the stove recognizes a flame, if it doesnt the gas will shut off and the ignitor will cool off, If you use the self clean setting to clean the oven you will destroy the ignitor much faster because they are only rated for about 1000 degreese for just a minute and self clean keeps it around 800 for an hour or so. You may just need to replace the ignitor.
Jul 28, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Flame shuts down after 5-8 minutes
AFTER THE BURNER SHUTS DOWN THE 1ST TIME IT SHOULD COME BACK ON WITHIN 1 TO 3 MINUTES. WHEN THE BURNER TRIES TO COME BACK ON YOU'LL HEAR A CLICK AND THE GLOW OF THE IGNITOR SHOULD BE VISIBLE. AFTER 30 TO 60 SECONDS IGNITOR SHOULD FADE AND THE BURNER SHOULD FIRE. IF IGNITOR FADES AND BURNER DOES NOT FIRE YOU WILL NEED TO REPLACE BURNER COILS #279834. IF IGNITOR DOES NOT COME ON YOU WILL HAVE A T STAT OR SENSOR ISSUE. SOUNDS LIKE COILS TO ME. HOPE THIS HELPS PLEASE FEEL FREE TO CONTAT ME HUBAPPLIANCE@COMCAST.NET. PLEASE RATE MY RESPONSE.
Jun 23, 2009 | Dryers
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
Frigidaire FGR231A Gas Dryer Logo
120 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
